Old 11-14-2019, 06:03 PM #16
19963.4lsr5 has a spectacular aura about 19963.4lsr5 has a spectacular aura about
Here is what I use for acetone. I have a qt can I suck it out of. .
Old 11-14-2019, 06:42 PM #17
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc is just really nice gamefreakgc is just really nice gamefreakgc is just really nice gamefreakgc is just really nice gamefreakgc is just really nice
Real Name: Jerod
Originally Posted by trackntrail View Post
Did you smog your truck with cataclean in the tank? Or run the tank of cataclean through and then smog it on fresh gas?
Run it through the tank completely then refill with gas & smog.
'98 4Runner SR5 - 4x4 5VZ-FE Supercharged - 222k miles, JDM engine @ 221k
AEM F/IC 6 Piggyback, 2.1" pulley at 11 PSI, Go-Fast Parts
Old 11-15-2019, 02:01 AM #18
T.Tech T.Tech is offline
T.Tech is on a distinguished road
I thought there was a year that it had egr but I might be thinking of another vehicle with a 5vz. I owned a vehicle that threw the mil for the catalytic converter below threshold when I used anything but shell 91 octane fuel, I believe the additives in helped clean the converter and keep it above its limit.
T.Tech is offline   Reply With QuoteReply With Quote
Old 11-15-2019, 03:00 AM #19
4Reak Show's Avatar
4Reak Show is a jewel in the rough 4Reak Show is a jewel in the rough 4Reak Show is a jewel in the rough
4Reak Show's Avatar
Failed smog test
I'm fairly certain no 4Runner 3.4's have EGR. Some year CA Tacoma 3.4's do I believe. Something about an SUV being a passenger car vs a truck and having different standards. I read it somewhere.
Here's where I saw it
https://people.well.com/user/mosk/im...ma_ECUs_v2.pdf
Someone compiled a list and it says 2wd Tacomas have EGR. 4wd don't apparently. At any rate, if OP doesn't have it, it makes no difference.
Old 11-17-2019, 03:42 AM #20
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a jewel in the rough TheDurk is a jewel in the rough TheDurk is a jewel in the rough
MY GARAGE
TheDurk's Avatar
MY GARAGE
No OBDII 5VZ-FEs have the EGR. Since no 4Runners before 1996 had the 5VZ-FE, no 4Runners with that engine had the EGR as all are OBDII. Pre-1996 T-100s with the 5VZ-FEs have it, for example. Those little elbows with the caps on the top of the throttle body connect to the EGR when they are present.
My Backyard Frame Swap
Old 11-17-2019, 12:10 PM #21
G_Raw G_Raw is offline
G_Raw is on a distinguished road
Just passed smog, barely though. Read at 478 with the highest value allowed being 508. This was at the 15mph reading. Honestly they always tell me to change my cat when it gets this close. I agree with others here. Change oil, clean MAF and EGR. Run that thing long and hard to heat up well and you should pass. I normally hit a smog spot in the Oakland where I live after driving home from a day trip in Tahoe. This week was the first time I hadn't slogged after a long drive ( 40 minutes of running around doing domestic errands). I suspect if I did an hour or so of freeway speeds it would pass easy.
G_Raw is offline   Reply With QuoteReply With Quote
Old 12-14-2019, 09:40 PM #22
mkzg mkzg is offline
mkzg is on a distinguished road
So I finally passed.
Here is what I did
Seafoam The intake
Seafoam through gas tank
Drove 300 miles
Tested and failed - numbers actually got worse
Replaced Cat
Numbers immensely improved across the board - still failed due to high nox only
Replaced front o2 sensor
Passed with good numbers
So...in the end it required a seafoam treatment, cat and o2 sensor
mkzg is offline   Reply With QuoteReply With Quote
cat , failed , injector , seafoam , smog
Failed smog test twice. Need advice. StreetCreeper 3rd gen T4Rs 22 05-21-2019 12:24 AM
Failed smog test...Any cheap quick fix ideas? Dbiz 3rd gen T4Rs 18 07-27-2018 01:51 AM
Failed Smog Test (CA), Mismatching E.O. Sticker BirdieKing 3rd gen T4Rs 7 06-25-2016 07:24 PM
Failed smog...barely failed hc and c0 Saint75 So Cal 6 01-13-2014 10:52 PM
Need help with failed smog test locovino Maintenance/Detailing 10 01-08-2013 09:34 PM
Copyright © 2019
