11-14-2019, 06:03 PM
#16
Here is what I use for acetone. I have a qt can I suck it out of. .
11-14-2019, 06:42 PM
#17
Real Name: Jerod
Real Name: Jerod
Originally Posted by trackntrail
Did you smog your truck with cataclean in the tank? Or run the tank of cataclean through and then smog it on fresh gas?
Run it through the tank completely then refill with gas & smog.
11-15-2019, 02:01 AM
#18
I thought there was a year that it had egr but I might be thinking of another vehicle with a 5vz. I owned a vehicle that threw the mil for the catalytic converter below threshold when I used anything but shell 91 octane fuel, I believe the additives in helped clean the converter and keep it above its limit.
11-15-2019, 03:00 AM
#19
Failed smog test
I'm fairly certain no 4Runner 3.4's have EGR. Some year CA Tacoma 3.4's do I believe. Something about an SUV being a passenger car vs a truck and having different standards. I read it somewhere.
Here's where I saw it
https://people.well.com/user/mosk/im...ma_ECUs_v2.pdf
Someone compiled a list and it says 2wd Tacomas have EGR. 4wd don't apparently. At any rate, if OP doesn't have it, it makes no difference.
11-17-2019, 03:42 AM
#20
No OBDII 5VZ-FEs have the EGR. Since no 4Runners before 1996 had the 5VZ-FE, no 4Runners with that engine had the EGR as all are OBDII. Pre-1996 T-100s with the 5VZ-FEs have it, for example. Those little elbows with the caps on the top of the throttle body connect to the EGR when they are present.
My Backyard Frame Swap
11-17-2019, 12:10 PM
#21
Just passed smog, barely though. Read at 478 with the highest value allowed being 508. This was at the 15mph reading. Honestly they always tell me to change my cat when it gets this close. I agree with others here. Change oil, clean MAF and EGR. Run that thing long and hard to heat up well and you should pass. I normally hit a smog spot in the Oakland where I live after driving home from a day trip in Tahoe. This week was the first time I hadn't slogged after a long drive ( 40 minutes of running around doing domestic errands). I suspect if I did an hour or so of freeway speeds it would pass easy.
12-14-2019, 09:40 PM
#22
So I finally passed.
Here is what I did
Seafoam The intake
Seafoam through gas tank
Drove 300 miles
Tested and failed - numbers actually got worse
Replaced Cat
Numbers immensely improved across the board - still failed due to high nox only
Replaced front o2 sensor
Passed with good numbers
So...in the end it required a seafoam treatment, cat and o2 sensor
08-09-2022, 11:17 PM
#23
I was in same situation
'97 240k miles, runs great. Failed NOx @15mph (@648, max is 515)
I tried:
-Cleaning MAF
-Cleaning throttle body manually w/ cleaner and shop towel (had a little residue)
-Replacing *Front/upstream** O2 sensor (see note below)
Tested again, failed NOx @15mph (@599). Improved 7% or so but still not passing.
Then I tried:
-Replacing *rear* O2 sensor. Realized that I had originally put the upstream o2 sensor in the downstream position. Corrected positioning (though they seem the same - Bosch Exact Fit for both) ultimately replacing both O2 sensors.
-Used SeaFoam cleaner shot into the trottle body/intake (~10 minute spray). I used this recently, maybe 10k miles ago, never got crazy smoke out the tailpipe and didnt this time either.
Tested again, PASS! NOx @15mph (@161!) Great improvements to all other numbers.
I sorta wish I would have done Either the Seafoam or the O2 sensors so I really knew what was the culprit, but I am guessing the Front O2 sensor.
Anyhow, that was my process to success.
And also, fu*%k those nuts on the O2 sensors! none of my wrenches would fit, had to use vice grips, such a pain. But it done now!
