Old 11-14-2019, 01:40 AM #1
MarkBlack's Avatar
MarkBlack MarkBlack is offline
Real Name: 1997 4RUNNER
MarkBlack is on a distinguished road
MarkBlack's Avatar
Swapping a 2002 steering wheel in a 97
I’ve seen many clean 2000-2002 steering wheels at the junk yard. I personally think they look a lot cleaner than the 97. Has anyone done it? The guys at the junk yard said it’s easy to take off, but how easy is it to install?
MarkBlack is offline   Reply With QuoteReply With Quote
Old 11-14-2019, 12:01 PM #2
dcshipwreck dcshipwreck is offline
Real Name: Dan
dcshipwreck is on a distinguished road
Real Name: Dan
should just be a matter of rewiring the air bag and cruise if needed, I did it on my 97 subaru impreza I installed a 07 sti wheel and had everything working just had to rewire it.
dcshipwreck is offline   Reply With QuoteReply With Quote
Old 11-14-2019, 06:32 PM #3
STI_MECE's Avatar
STI_MECE STI_MECE is offline
STI_MECE will become famous soon enough
STI_MECE's Avatar
Yes its pretty easy.
I had to pull the cruise control switch from my 2000 steering wheel and put it on a 2002 steering wheel.
You can pull the pins from the connectors and put im into the new steering wheel you get.
You might want a puller to get the steering wheel off, and you need a torx bit, i forgot the size, t30 maybe?
and a 18mm socket IIRC.
You can get the steering wheel off with your hands, if you have controlled forced, like me I didnt need the puller lol
2000 SR5 4x2 Resto/Maintenance
STI_MECE is offline   Reply With QuoteReply With Quote
Old 11-14-2019, 09:40 PM #4
infamousRNR's Avatar
infamousRNR infamousRNR is offline
infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light
you could also consider swapping the clock spring to avoid chopping up ALL of your wires, but repining or splicing your cruise control wires should be that bad either.
Are you sure its an 18mm??? I'm pretty sure its a 19mm nut holding the steering wheel on the steering shaft
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
infamousRNR is offline   Reply With QuoteReply With Quote
Old 11-15-2019, 08:33 AM #5
STI_MECE's Avatar
STI_MECE's Avatar
Maybe you are right, thats why I said IIRC lol
Repinning the wires was not bad at all, that white connector comes apart if you press down in the right areas. If you look at the connector closely you can see where it comes apart. It took me maybe 10 minutes for the whole thing.
Old 11-15-2019, 10:17 AM #6
Tinigunner11's Avatar
Tinigunner11 Tinigunner11 is offline
Real Name: Austin
Tinigunner11 will become famous soon enough
Real Name: Austin
I have a 2000 steering wheel in my 97. All you need is the wheel and the clock spring. Cruise control stalks are the same. Great mod to get rid of the 2 post steering wheel! You’ll need a 19 mm socket and a T25 Torx bit.
1997 4runner, OVER 360K miles, Bilstein 5100 and FJ80 suspension, Polaris light bar, custom full length roof rack, plus some interior mods
I've had more 3rd gens than I can count at this point
Tinigunner11 is offline   Reply With QuoteReply With Quote
Old 11-15-2019, 10:36 AM #7
DreadPirateJon's Avatar
DreadPirateJon DreadPirateJon is offline
DreadPirateJon is on a distinguished road
My pop's 97 T100 has a very similar 4 spoke wheel to the post MCA 4runner. I was wondering if that may be a swap where you dont need to repin the connectors.
97 5spd with elocker
Build Thread https://www.toyota-4runner.org/3rd-g...st-bucket.html
2 inch Lift (Bilstein 5100 F&R, 99 Talls F, OME R), 33 Inch Tires
Rebuilt Engine, Doug Thorley Headers, Gibson Catback
DreadPirateJon is offline   Reply With QuoteReply With Quote
Old 11-15-2019, 01:40 PM #8
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
I must be a dinosaur, I had several chances to grab a later steering wheel for my '97, but I like the '97 better - it provides a clear view of the cruise and and headlight stalks. These are totally hidden by the extra spokes of the 4 spoke wheels. But maybe it's just my geometry .
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 11-15-2019, 01:53 PM #9
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Nobody mentioned pulling the battery first... please do that. There's a live airbag in the wheel and when there's things like re-wiring going on you don't want to be in front of that thing with your face there if something goes wrong.
I part-out 4Runners on the side and even I don't fool around with anything in the safety restraint system with the battery connected.
Also, not sure if this matters but the airbags in the 97 are not the same as a 00-01 airbag, which is not the same as an 02 airbag. Just a heads up.
326WHP 347TQ
easy , junk , steering , swapping , yard
FS: Houston, TX, 2002 4Runner OEM Steering Wheel 150 STI_MECE For Sale: T4R Items 3 10-01-2019 11:14 AM
WTB: 3rd Gen 2002 4runner Sport Edition Emblems and Leather Steering Wheel MN 024rnrSport For Sale: T4R Items 0 09-09-2018 10:59 AM
2002 tan steering wheel and air bag 4x4runner2002 For Sale: T4R Items 0 10-29-2012 04:37 AM
Swapping a 4th gen steering wheel to a 3rd gen, Possible? juiceboxer Engines / Suspension / Wheels / Tires / Audio / Accessories 3 08-27-2009 12:48 AM
