Old 11-16-2019, 03:53 PM #16
T4Rchadly's Avatar
T4Rchadly T4Rchadly is offline
Real Name: chad morrison
T4Rchadly is just really nice T4Rchadly is just really nice T4Rchadly is just really nice T4Rchadly is just really nice
T4Rchadly's Avatar
Originally Posted by UnderFire View Post
We had a similar problem with a high mile 99 Tacoma, never got to the bottom of it. Would fire back up up till about 20 minutes of sitting, after that it would crank and never start, until it sat around an hour. Then it cranks back up like nothing ever happened.
We swapped around everything. Injectors, FPR, fuel filter, plugs, wires, coils, crank and cam sensors, coolant temp sensor, fuel pump relay, swapped the ECU, checked all the grounds on both harnesses, nothing ever fixed or even vaguely improved the symptoms.
Sent from my JSN-L23 using Tapatalk
super weird
T4Rchadly is offline   Reply With QuoteReply With Quote
Old 11-16-2019, 06:44 PM #17
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
Originally Posted by 19963.4lsr5 View Post
You never swapped the ICM?
On American cars that could be a flood condition from a bad injector or three.
There are only two sensor grounds I’m aware of. They are on the plenum. The ground strap between the head and body just ensures a good engine ground with the chassis. It’s part of the ground from the negative post to fender. You can’t rely on power passing through the engine and trans mounts.
Flooding was my first thought when it showed no stored codes. That's what I started with was a known good set of injectors and FPR. I also did swap the little igniter module. Literally anything that could be swapped that had to do with ignition, fuel, timing or air got swapped out with known good parts and it made zero difference. The only thing that we never swapped was the fuel pump.
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 01-30-2020, 01:37 AM #18
T4Rchadly's Avatar
T4Rchadly's Avatar
**** issue resolved per installing new injectors. Have not had any issues since. Coming upon 4,000 miles/3-4 weeks****
Old 01-30-2020, 02:55 AM #19
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Hey there man, I have the same issue! Do you have the part numbers for the injectors? What do they run price wise?
Old 01-30-2020, 08:43 AM #20
sawguy50 sawguy50 is offline
sawguy50 is on a distinguished road
same here...would like part #s...aftermarket? By the way I'm back with a slightly different handle and low post count since my house burned down. Starting over on all accounts.
sawguy50 is offline   Reply With QuoteReply With Quote
Old 01-30-2020, 10:07 PM #21
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
If extended crank issue occurs. I would check the fuel pressure at the rail. Make sure your fuel filter is good. Granted this is after a through check of ignition system as well.
Old 02-04-2020, 03:53 AM #22
T4Rchadly's Avatar
T4Rchadly's Avatar
had installed brand new OEM fuel pressure regular, denso fuel pump, and OEM fuel filter beforehand. as i said i diagnosed and repaired the issue
Old 02-04-2020, 03:57 AM #23
T4Rchadly's Avatar
T4Rchadly's Avatar
OEM Toyota Part #: 23250-62030
i obviously only recommend OEM Toyota injectors if you havent taken a look at my build thread. im pretty against aftermarket cheaper parts.
fuel , oem , operating , starts , temp
Help! NO START NO Crank Issue El_Jefe_83 4th Gen T4Rs 36 09-01-2020 01:47 PM
Insidious Issue with Failing Crank blairracd 3rd gen T4Rs 2 08-25-2019 01:03 PM
05 4.7 V8 has intermittent extended crank time on cold/hot starts. Utah_4runner 4th Gen T4Rs 61 11-21-2018 03:57 PM
Extended crank — cheap fix? OrRunner 3rd gen T4Rs 10 10-01-2018 04:49 AM
No start/no crank issue. Need help danb3 3rd gen T4Rs 4 01-25-2018 09:40 AM
