Originally Posted by davidoff
Apologies if this information is readily available and I'm just not finding it...
Anyone know how the weight of a fully fueled 2000 4wd SR5 is distributed with regard to weight over the front and rear axles? I'm playing with the idea of getting a 4wd pickup for the sake of having a big open bed for hauling stuff, but traction in snow with the bed empty is a concern, and I have no idea how to gauge the difference between how my 4runner behaves in this regard, and a pickup that may have less weight over the rear axles, with an empty bed.
Thanks.
Andy
When I was shopping for a 3rd gen 4R I also test drove some 1st gen taco's. I will say the taco's were MUCH easier to spin tires in than the 4runners. I do not know if this applies to all of them or just the ones I drove.
BUT, here is how you fix that if you do want the truck. Get some 2 by 4's, like 2-4 of them. Then 3-6 PVC pipes with end caps. Lengths depend on your truck bed.
Fill the pipes up with sand and then drill holes in the 2 by 4's to hold said pipes and to keep them from rolling all over. You can add pipes in sets of 2 to add weight to the back. A pipe filled with said won't have "waves" like water wood, so I recommend sand over water.
