Old 11-14-2019, 04:05 AM #1
T4Rchadly's Avatar
T4Rchadly T4Rchadly is offline
Real Name: chad morrison
T4Rchadly is just really nice T4Rchadly is just really nice T4Rchadly is just really nice T4Rchadly is just really nice
T4Rchadly's Avatar
Extended crank issue 3.4l
ive searched through threads and cant find exactly what i need:
my 3.4L 4runner has an issue where it long crank starts (cranks a lot before it starts) after atleast 20 minutes sitting from operating temp. if i let it sit overnight or more than 5 hours it starts up as normal, every time. any help? im starting to think it could be a coolant temp sensor if its only after achieving operating temp? it use to be more intermittent but im able to duplicate it almost every day now.
no codes, other symptoms, vehicle runs great no idle issues no bogging no fuel smell no power loss
ive replaced-
OEM STARTER
OEM FUEL PUMP
OEM FUEL FILTER
OEM FUEL PRESSURE REGULATOR
CLEANED IAC
CHECKED BOTH LBJ'S
INJECTOR CLEANER
RED TOP BATTERY
T4Rchadly is offline   Reply With QuoteReply With Quote
Old 11-14-2019, 05:53 AM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Does 'long' equal more than 5 spins? That's the "standard" for mine yet every once in a while it will fire up on less than 1 spin.
Old 11-14-2019, 11:53 AM #3
OrRunner's Avatar
OrRunner OrRunner is offline
OrRunner is on a distinguished road
OrRunner's Avatar
Mine also long cranks- around 5 turns- and I replaced the fuel pump/regulator, did general maintenance (plugs, maf clean, tbody clean etc) to try to resolve it and never made any difference to the concern. Eventually I decided it doesn't seem to be hurting anything and am just going to live with it.
OrRunner is offline   Reply With QuoteReply With Quote
Old 11-14-2019, 01:11 PM #4
T4Rchadly's Avatar
T4Rchadly's Avatar
im talking like 10-20 cranks lol
Old 11-14-2019, 01:14 PM #5
T4Rchadly's Avatar
T4Rchadly's Avatar
yeah if it was a 5 cranker id be able to live with it too! im shipping my truck from alaska to seattle in january and living in the boonies of idaho skiing. would like to fix the issue while i have my shop and tools before i have nothing
Old 11-14-2019, 01:31 PM #6
How many seconds on the starter does that equal?
Do you have some injectors dripping and causing a partial flood condition that needs cleared with the long crank when it’s hot?
You can look at inlet air temp and engine temp after the engine sits overnight. They should be the same or within 10 degrees after sitting 8 hours or more.
Old 11-14-2019, 02:33 PM #7
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Issues only showing up when hot can also indicate a wiring issue. Heat creates extra resistance in the wire and can cause the ECU to not see the voltage signals it needs. Do you have any damaged or pinched wires in the engine bay? Have you cleaned off the grounds and battery terminals with rubbing alcohol?
326WHP 347TQ
Old 11-14-2019, 03:03 PM #8
wtfemery's Avatar
wtfemery wtfemery is offline
wtfemery will become famous soon enough
wtfemery's Avatar
definitely check your grounds, I used to have an old bronco that would ONLY start after it sat for at least 2 hours. I went around and replaced the old rusty grounds (and starter wires) with thick gauge welding wire and it started right up on the first crank every time.
1997 4x4 SR5 3" Lift @254,000 miles
I welded my own bumper!
wtfemery is offline   Reply With QuoteReply With Quote
Old 11-14-2019, 03:59 PM #9
ScottyBoi ScottyBoi is offline
ScottyBoi is on a distinguished road
Where are all the grounds, exactly? I can see the one attached to the plenum on the driver's side, and another one to the firewall on the passenger's.
ScottyBoi is offline   Reply With QuoteReply With Quote
Old 11-14-2019, 04:34 PM #10
Real Name: Jerod
Real Name: Jerod
Yes, there's a block to firewall in the back as well as as the plenum on the driver's side for the diagnostic port (this one gets dirty due to being removed for repairs). There is also your battery ground on the fender which is the most important, this one helps the most. For starting, the lower engine harness that goes from the battery to the starter on the passenger's side has a ground that attaches to the bottom of the block. This one gets real grimy and oily over time and could cause starting issues as well. I think it may be a double ground though since I think it also grounds to the battery cable to fender.
There's also an ECU ground inside the cabin but unless you dunked your 4Runner in a lake this one should be clean.
326WHP 347TQ
Old 11-14-2019, 05:59 PM #11
Great, I'll take a look at those and give'm a clean. Thanks!
Old 11-14-2019, 10:45 PM #12
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
We had a similar problem with a high mile 99 Tacoma, never got to the bottom of it. Would fire back up up till about 20 minutes of sitting, after that it would crank and never start, until it sat around an hour. Then it cranks back up like nothing ever happened.
We swapped around everything. Injectors, FPR, fuel filter, plugs, wires, coils, crank and cam sensors, coolant temp sensor, fuel pump relay, swapped the ECU, checked all the grounds on both harnesses, nothing ever fixed or even vaguely improved the symptoms.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 11-14-2019, 11:41 PM #13
You never swapped the ICM?
On American cars that could be a flood condition from a bad injector or three.
There are only two sensor grounds I’m aware of. They are on the plenum. The ground strap between the head and body just ensures a good engine ground with the chassis. It’s part of the ground from the negative post to fender. You can’t rely on power passing through the engine and trans mounts.
Old 11-16-2019, 03:51 PM #14
T4Rchadly's Avatar
T4Rchadly's Avatar
performed big 3 mod and didnt make difference, checked the block, checked ecu ground even it has never seen deeo water, checked plenum grounds again.
Old 11-16-2019, 03:52 PM #15
T4Rchadly's Avatar
T4Rchadly's Avatar
im beginning to think its also an injector issue. it has dealership repair orders from og owner stating they were leaking and performed reseal kit on all injectors
fuel , oem , operating , starts , temp
Help! NO START NO Crank Issue El_Jefe_83 4th Gen T4Rs 36 09-01-2020 01:47 PM
Insidious Issue with Failing Crank blairracd 3rd gen T4Rs 2 08-25-2019 01:03 PM
05 4.7 V8 has intermittent extended crank time on cold/hot starts. Utah_4runner 4th Gen T4Rs 61 11-21-2018 03:57 PM
Extended crank — cheap fix? OrRunner 3rd gen T4Rs 10 10-01-2018 04:49 AM
No start/no crank issue. Need help danb3 3rd gen T4Rs 4 01-25-2018 09:40 AM
