Old 11-15-2019, 10:12 AM #16
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
Originally Posted by jross20 View Post
Oh wow, so you basically add a "converter" box between the systems that converts the signal by applying a correction?
Yes. And you can adjust the calibration, too.
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 11-15-2019, 01:20 PM #17
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
UltraGauge Speed Calibration
Originally Posted by Bad Luck View Post
I'm not sure if this helps, but if you have an Ultra Gauge you can calibrate to adjust it for true distance and it will change the mph on the Ultra Gauge display.
FWIW: I found this tutorial for matching the UG speed gauge with a GPS gauge. I figure the GPS is likely the most accurate we have easy access to. Add in a calculator most of us have on our smart phones and bob's your uncle.
How to calibrate distance using a GPS and a calculator:
NOTE
This distance calibration method is based on using GPS speed.
GPS speed is most accurate when driving in a straight line at a constant speed.
Step 1: Add a speed gauge (e.g. on page 1 zone 1 of the Ultragauge)
MENU Gauge/Page Menu .. Select Gauge/Page .. Select Gauges Select Page 1 Gauges
Use UP & DOWN keys to Navigate to MPH or KPH
Press MENU. This will cause the cursor to blink.
Pressing UP or DOWN change the number to 1
Press MENU to assign the Gauge to that Page 1 Zone 1.
Leave the menu by selecting Back, etc
The Ultragauge should now show the MPH or KPH on page 1
Step 2: Grab your calculator and your GPS navigation device, get in your car and head for the motorway.
Step 3: While driving at a constant high speed for at least a few seconds note down the speed readings of the Ultragauge and the GPS.
The readings are probably different.
Step 4: Find a convenient place to stop, switch on your calculator and do the following calculation: GPS speed reading divided by Ultragauge speed reading.
Step 5: Adjust the "Distance cal." factor in the Ultragauge
Menu - Vehicle Setup - Calibration - Calibrate Distance
Note the distance value shown by Ultragauge and on the calculator multiply this by the factor found in step 4
Press MENU and press UP or DOWN to adjust the distance value to the calculated value.
Press MENU to store the updated distance value. The Ultragauge now shows the new Distance cal. value
Switch off your calculator
Step 6: Take another drive on the motorway and check if the GPS speed reading and the Ultragauge speed reading at constant speed are now the same.
Step 7: If necessary make fine adjustments to the distance calibration value until GPS speed and Ultragauge speed are identical.
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 11-15-2019, 01:24 PM #18
Yeah, used all the time on motorcycles when swapping sprockets. Less often on trucks with gear ratio and tire size swaps.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 11-15-2019, 02:02 PM #19
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Ahhh. Okay, so is the gold standard to use a gps to grab the speed? Basically how do I figure out how fast I am actually going so I can calibrate it...haha.
Old 11-15-2019, 04:18 PM #20
I used phone GPS to verify, but I calculated what the correction factor should be based on tire size.
Original tire size: 225/75-15 = 28.29" diameter
New tire size: 265/70-17 = 31.61" diameter
31.61 / 28.29 = 1.117x or about 12% bigger. I applied a 12% correction using the calibrator, and the speedo read the same as it used to (67=65mph actual).
Speedometer generally read just a bit high (for legal reasons), so that's where I left it. Often, odometers (and OBD-II reported speed) is nearly perfectly accurate.
Old 11-15-2019, 04:19 PM #21
Bad Luck Bad Luck is online now
Real Name: Patrick
Real Name: Patrick
GPS plus flat straight road. Somewhere that you can maintain a good constant speed. Preferably higher speeds if your area allows it. The higher the speed you can maintain the more accurate your reading will be.
Bad Luck is online now   Reply With QuoteReply With Quote
Old 11-15-2019, 06:52 PM #22
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
So the 1996-2002 USDM 4Runners do not have the speed sensor that's located near the tip of the transfer case?
Speedometer calibration cannot happen through the ECU/OBD-II port. Not only is the ECU not programmable, the speedometer SENDS the signal to the ECU, not the other way around.
On ABS equipped 3rd gen 4Runners (almost all of them), the system goes like this:
ABS wheel speed sensors -> ABS computer -> Gauge cluster -> ECU (and 4WD computer, diff lock ECU, etc.)
To calibrate the speedo (and the speed the ECU sees and reports via OBD-II), you need to interrupt the signal between the ABS computer and the gauge cluster and use a calibrator there.
I chose the Dakota Digital speedometer calibrator, and installed it in the passenger kick panel next to the ABS computer:
EDIT: Also note that gearing will have no effect on the speedometer, since the speed signal is taken from the wheels, not the transmission/transfer case output. Only tire rolling diameter will change the speedo reading.
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 11-15-2019, 07:59 PM #23
For the most part, no. Some of the early base models had no ABS, and they did get the speed sensor.
Old 11-16-2019, 03:32 PM #24
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 has a spectacular aura about Doc2012 has a spectacular aura about
Doc2012's Avatar
The other option to do this is to add a Tacoma speed sensor into the transfer case, and run a corrector.
This is what I did when I swapped to manual hubs, and a 8.4” Tacoma axle with my 63” Chevy leafs.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
Old 11-25-2021, 04:47 PM #25
Option01 Option01 is offline
Option01 is on a distinguished road
Originally Posted by BoomerBob View Post
On a recent road trip I noticed my GPS had a very different reading than the speedo. At 80 mph, a common cruising speed here in the Southwest, my speedo read 89. The difference gets worse the faster the speed. It's only 3-4 mph difference at 40.
I haven't been able to find a definitive answer but, after reading as much as I can find on these forums, I'm suspecting that for the 4Runner models that came with both the 15" and 16" rim sizes, the stock speedos are all calibrated for the base 225/75R/15 tire size giving the ones with 16" rims a low speedo reading.
Option01 is offline   Reply With QuoteReply With Quote
Old 11-26-2021, 12:29 AM #26
jross20's Avatar
jross20's Avatar
Show in case anyone is curious I wanted to share...
About a year ago I literally spent countless hours trying to get things calibrated correctly until I finally came to the conclusion that recalibrating a 3rd gen is pretty much nigh impossible.
Old 11-26-2021, 09:37 AM #27
Real Name: Patrick
Real Name: Patrick
My speedometer sync's up perfectly with the 265/70R17's I have on my 4Runner right now.
Old 11-26-2021, 04:18 PM #28
Thanks for chiming in! I may save me the same countless hours as I'm kind of a perfectionist with stuff like that. One question though, can you tell me if/why the Dakota Digital device shown earlier in the thread was not a good option for you?
1999 SR5 V6/Auto 4WD
4.88 Gears, Front/Rear E-Lockers
1" Body Lift, 2" Suspension Lift, 285/75 R16 Tires
Old 11-26-2021, 04:31 PM #29
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
I've been thinking of using 265/75R16 tires instead of 265/70R16 size tires. That would mess up the speedometer an odo readings a little bit.
I have a base model 4runner with no ABS, is calibrating the speedometer any easier?
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 11-26-2021, 04:46 PM #30
Real Name: Patrick
Real Name: Patrick
Your speedometer will be off by about 3 percent. In other words, speedometer shows 70 mph you might be doing 72 mph. This is assuming your speedometer shows the correct and accurate speed with 265/70R16 tires.
difference , mph , odbii , speed , speedo
URD MAF Sensor Calibrator Hadelson 5th gen T4Rs 261 04-18-2022 03:00 PM
URD 7th injector kit with URD AFR calibrator Dinabox For Sale: T4R Items 7 04-17-2013 01:08 AM
URD MAF Calibrator SCRUED 3rd gen T4Rs 0 01-22-2009 04:07 PM
