Old 11-18-2019, 02:13 PM #16
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
I thought I had a brake booster issue, but did not. But in research saw that OEM went anyplace from $70 to 800 bucks. the 800 being Toyota not an aftermarket OEM. All seem to come with check valves . However when a Toyota check valve alone is 60, makes you wonder about quality of a complete brake booster with check valve only $70.
If your new booster is not Toyota...maybe its the booster being a new one but funky
Old 11-18-2019, 02:46 PM #17
řlaf řlaf is offline
řlaf is on a distinguished road
Thanks! It's definitely OEM, just not sure if its new or refurbished. Paid 690 for it through my shop. I also went ahead and bought (and returned) a new check Valve and Grommet from the dealer, to eliminate that. Even though the new booster came with one.
I'm planning on disconnecting the ABS tonight, just as a measure of eliminating that as a possibility. But as stated earlier, the hard pedal occurs way before the ABS would ever kick in.
řlaf is offline   Reply With QuoteReply With Quote
Old 11-21-2019, 01:21 AM #18
Bumping this up, to see if anyone can confirm vacuum readings on their intake plenum. I read just 17 in on mine, which seems low. Should be 20 I believe? Could this lead to a loss of vacuum (hard pedal) when I stomp on it?
Thanks!
Old 12-09-2019, 01:01 AM #19
I solved the panic stop issue.
Seems like my pads and rotors were glazed (I had less than 1 yo Stoptech drilled and slotted rotors and ceramic pads, which had been recommended to me. No clue on how the glazing happened. A new set of OEM pads and rotors gave me some good bite back on panic stops.
The other remaining issue I'm still grappling with is a hard pedal on cold starts, particularly when at high elevation. Booster and check valve are new OEM. System has been flushed. Calipers are working. Rear brakes are adjusted. ABS is working.
The only thing I'm seeing now is that my engine vacuum at the plenum nipple is only 11 in, at a cold morning at 10,000ft. This might not be enough to clear the booster of any air. I started a new thread about that ...
- olaf
Old 12-09-2019, 09:16 AM #20
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
- olaf
I wonder if you need to put a vaccuum assist pump on when your at high elevations. So your vaccuum is where it's supposed to be.
abs , bled , booster , brake , pedal
Hard Brake Pedal During Panic Stops - Brake Booster? Friday88 3rd gen T4Rs 23 11-01-2019 04:15 PM
Brake pedal hard to push down shoota 3rd gen T4Rs 40 04-23-2019 09:26 PM
Need help diagnosing Brake pedal “give” at stops Rancho5 3rd gen T4Rs 18 09-10-2018 05:16 AM
Hard Brake Pedal? Brake Accumulator? beatadrum 4th Gen T4Rs 2 02-17-2018 12:33 AM
Brake pedal hard to push? jarnld Classic T4Rs 5 05-14-2008 12:59 PM
