Old 11-16-2019, 03:13 AM #16
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
Originally Posted by MarkBlack View Post
I was talking with this guy from Iran today and told him about how my miles were rolled back. He started telling me the best way to clean your motor and catalytic converter is to mix mineral spirits with your gas every 50k miles. I’ve searched all over the internet and can’t find anything about it. Is this guy crazy or is this an actual thing?
He said to run a quart with a full gallon of gas. Not just a tablespoon. A full quart.
I'd be careful about putting any oil additive into the gas; Mystery Oil included. The purpose of the cat is to burn off any small particulates so it doesn't come out your exhaust pipe as unburned fuel or other byproduct.
Cleaning the carbon off piston tops is an unneeded exercise in futility. The only thing that will happen is a very slight increase in compression ratio will develop over time. Better to just use a PEA fuel system cleaner that dissolves crude in the passages and injectors.
The other reason to not try to break apart the carbon build-up is it will go out the exhaust right to the cats and clog those small holes and since it's carbon from the cylinder it will probably not burn up and pass through the cats.
My guess is the guy from Iran is used to a different kind of exhaust system in Iran. They might not even have cats required there. Almost certain they don't have smog tests every year or two. On a non-cat vehicle running some mineral spirits through the system wouldn't hurt anything but it probably wouldn't help anything too.
I had an older neighbor years ago who used to say that using a tank full of premium gas was better than using an occasional bottle of fuel system cleaner. The exact opposite is actually true. Also if you buy from a name brand station like Chevron/Texaco/Mobile/Shell; you never need to add any fuel system cleaner. They have that stuff added to their gas which is partly why it's so much more expensive than the JollyMart station like I normally use. And yes; I do add a bottle of quality fuel system cleaner once in a while. Especially if I notice my car is turning over longer before starting.
As far as cleaning the engine; just change the PCV valve and air filter regularly and use a synthetic oil. If the engine is kinda dirty from a PO not changing the PCV valve; just do more frequent oil changes for a while like at 3k instead of 5k. Do that 3 times and you have the engine about as clean as you can possibly get it. If you want to give it a jump start on getting clean; add a can of BG EPR before you change the oil and run for 15 minutes. Better yet; get these three products to do all the things that Iranian guy said would clean up your engine and make it run better. They are kinda like a tune up in 3 cans. If you notice a significant difference; redo it every year or two.
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 11-16-2019, 05:33 AM #17
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Originally Posted by BoomerBob View Post
...The purpose of the cat is to burn off any small particulates so it doesn't come out your exhaust pipe as unburned fuel or other byproduct. ...
Sorry. Got stuck on purpose of cat. While it Could also be for what your referring to it's chemical purpose is to Convert nitrous oxides into carbon dioxides, which are "safer" for humans (except for that warming of the planet idea). Hence the name catalytic converter. Will it attempt to burn things passing thru it, sure.
Luck and enjoy those Runners.
Old 11-16-2019, 09:09 AM #18
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
Marvel Mystery Oil works good at cleaning up stuck gunk. When grabbing a motor for a swap and they've been sitting for a while sometimes they will have valve tap knocking n stuff. Getting some Marvel Mystery Oil in the intake, fuel tank, and crankcase will take care of it and loosen things up. Scrap yards will tell you this if you call and complain a motor you bought from them is tapping.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 11-16-2019, 11:30 AM #19
BG products are great. I always have a few cans of 109 on hand.
Old 11-16-2019, 01:01 PM #20
The Cold War Kid's Avatar
The Cold War Kid The Cold War Kid is offline
The Cold War Kid is on a distinguished road
Originally Posted by 19963.4lsr5 View Post
I’ve added enough home brew stuff to my gas that to me mineral spirits it probably the least most conservative non standard additive I’ve ever used. Many said acetone would blow up my current rig. I have more miles with acetone than most put on their vehicles in their lifetime.
Acetone is good. I use it regularly - always, in fact. But you don't seem to know how to use it. Start with 3 fl. oz. per 10 gallons of fuel. Keeping a running score, adjust the mixture until the fuel mileage peaks. Do this slowly, as "fill her up" mileage is not all that accurate and averaging is necessary.
There are other things that, in SMALL AMOUNTS, can improve mileage and combustion. Naphthalene is one. Use 100% naphthalene moth flakes. (You need to crush moth balls and that gets boring 3 heaping teaspoons per 50 gallons of fuel. Nice if you mix the acetone and naphthalene first.
BE CAREFUL! And don't get busted for bomb making or a meth lab. Seriously. Buying that stuff can get you searched, at the very least.
2001 Sr5 V6 2WD
"...The closer you get, to the meaning, the sooner you know, that you're DREAMING..." (Black Sabbath - HEAVEN AND HELL)
The Cold War Kid is offline   Reply With QuoteReply With Quote
Old 11-16-2019, 01:11 PM #21
BoomerBob's Avatar
BoomerBob's Avatar
You can probably get away with using MMO on these old engines but I'd avoid it on anything made in the last 10 years. YMMV, FWIW, JMHO. It's a good product IMHO. I have a bottle of it in my garage too.
Old 11-16-2019, 03:15 PM #22
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
What kind and quantities of mixtures are you using in your gas tank?
Are you getting any significant MPG or performance boost?
Are you using non-ethanol gas?
Saw this website, kind of fascinating but hard to believe.
"Hydrogen Electrolysis Free Information Web Site dedicated to those who want to do something about the wasted fuel their engines do not burn"
And drill down to this link:
Free Energy Now: Acetone in Fuels - Double Your Mileage
Old 11-16-2019, 03:42 PM #23
I played the acetone for Fuel milage game in the mid 90’s with my 93 ZX7, Dodge Daytona, and my 94 Ram with the Cummins. I now use it for a constant fuel system cleaner, it’s 150 octane, and its ability to absorb water( to counteract ethanol). I just put 2 2oz syringes in at each fill up. On my Saturn I do notice my LTFT is two more negative than what I normally run. But my mpg was not noticeably better. Too many variables to ever be able to associate it with an increase in mpg.
Ive used every flammable solvent in my lawnmower....MEK was my favorite.
gas , guy , miles , mineral , spirits
Those running LC 7 wraps in the rear, what coils are you running up front? the walrus 3rd gen T4Rs 13 03-08-2019 03:08 AM
Mineral Basin trip report KidVermicious Classic T4Rs 16 07-11-2012 12:56 PM
WTT: '06 Sport Running Board/Tubes for SR5/Limited Running Boards thirstyturtle Want to Buy/Trade 6 09-14-2011 06:38 AM
Switching from mineral to synthetic engine oil. Flush? paraordnance 4th Gen T4Rs 4 05-22-2009 11:55 PM
