Old 11-15-2019, 01:28 AM #1
MarkBlack's Avatar
MarkBlack MarkBlack is offline
Real Name: 1997 4RUNNER
MarkBlack is on a distinguished road
MarkBlack's Avatar
Running Mineral Spirits with Gas?
I was talking with this guy from Iran today and told him about how my miles were rolled back. He started telling me the best way to clean your motor and catalytic converter is to mix mineral spirits with your gas every 50k miles. I’ve searched all over the internet and can’t find anything about it. Is this guy crazy or is this an actual thing?
He said to run a quart with a full gallon of gas. Not just a tablespoon. A full quart.
MarkBlack is offline   Reply With QuoteReply With Quote
Old 11-15-2019, 02:47 AM #2
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
I’ve heard of diesel in the engine oil before draining and filling but not mineral spirits in the gas tank.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 11-15-2019, 05:58 AM #3
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Wouldn't that be about the same as say Seafoam? That stuff goes into gasoline, motor oil and intake systems. Why not use what everyone else in America uses to clean out engines with?
Also - use only as directed on can yet you can also use Startron, far cheaper and more effective. I get it on amazon - https://www.amazon.com/dp/B00EZNZ6B6/ref=emc_b_5_i
Now for just engine insides, full synthetic cleans out well and does it slowly too. Just don't be in a hurry, it didn't get how ever it is overnight.
Luck and enjoy that Runner.
Old 11-15-2019, 06:28 AM #4
Sky Sky is offline
Sky will become famous soon enough Sky will become famous soon enough
Sky Sky is offline
I'd vote "crazy".
What is it you are trying to clean from your motor? Adding anything to the gas will not clean the "motor" just the fuel system.
PEA based fuel additives such as Techron and Regane do a fantastic job on the fuel system. Any of the "top tier" rated gasolines will help clean a fuel system over time. In my area Costco has the least expensive gas and the lowest price that is top tier.
Sky is offline   Reply With QuoteReply With Quote
Old 11-15-2019, 09:06 AM #5
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
This..just use seafoam.
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 11-15-2019, 09:47 AM #6
Sky Sky is offline
Sky Sky is offline
Not saying it doesn't work, but Seafoam's active ingredient is isopropyl alcohol and a light oil. You can DIY it for far less money, a quart of 99% isopropyl is around $2. If you are putting it in the gas you don't need the oil.
Old 11-15-2019, 10:11 AM #7
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Just water sprayed/misted into the intake works pretty well at cleaning the cylinders/pistons. When water heats/gets compressed it turns to steam and can break away built up crud.
Check it out on youtube.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 11-15-2019, 12:43 PM #8
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
I can see why he says a quart per gallon every 50k. That's a strong mix. It probably works, but he is probably talking from experience on older, simpler carb engines. I wouldn't do that strong of a mix with efi. I've heard of people doing this in smaller quantities though.
Old 11-15-2019, 01:06 PM #9
spartacus's Avatar
spartacus's Avatar
If thé motor is running good in spite of high milage then keep changing the oil and filter every 5k and send in an oil sample for analysis and go from there. Why mess with the engine just because someone said something.
Old 11-15-2019, 01:18 PM #10
Marvel Mistry oil is mostly mineral oil.
I run 4oz of acetone in the gas at fill up. Been doing it to all my vehicles since the mid 90’s.
Old 11-15-2019, 01:57 PM #11
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
I agree with above, stick to on the shelf products sold in the automotive aisle.
Personally, I've had great experience with Seafoam, Seafoam spray, and Royal Purple Atomizer. Also used CRC's Guarenteed to Pass cat cleaner with great results.
326WHP 347TQ
Old 11-15-2019, 05:37 PM #12
sportscarfan's Avatar
sportscarfan sportscarfan is offline
sportscarfan will become famous soon enough
https://www.youtube.com/watch?v=5icTmYItwiE
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
sportscarfan is offline   Reply With QuoteReply With Quote
Old 11-15-2019, 07:01 PM #13
Riceye Riceye is offline
Riceye will become famous soon enough Riceye will become famous soon enough
This doesn't sound right. Even if I were sure mineral spirits may be safe as an additive (I'm really not sure of this), one quart per tankful sounds more realistic. I'd worry about the effect on O2 sensors and cat.
If carbon removal from cylinders is your goal (to restore compression to lower, non-pinging level due to carbon deposits) I suggest seafoam through a vacuum line.
Seafoam treatment
If you feel your cat does, in fact, need help, Cataclean used properly has worked for me in the past.
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
Riceye is offline   Reply With QuoteReply With Quote
Old 11-15-2019, 08:24 PM #14
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
I say crazy. I’ve driven Toyotas for the past 1.3 million miles and have never added anything to the fuel. If my engines were dirty inside, it never showed up as operational or performance problems. I kept up with oil changes pretty well, with the occasional lapse, and never knew if my engines were clean or dirty on the inside. I never had to open one up. In my view, starting to add mineral spirits because someone says so, especially when you can’t find any supporting information, is an invitation to troubles that you don’t yet have.
thennen is offline   Reply With QuoteReply With Quote
Old 11-15-2019, 10:27 PM #15
I’ve added enough home brew stuff to my gas that to me mineral spirits it probably the least most conservative non standard additive I’ve ever used. Many said acetone would blow up my current rig. I have more miles with acetone than most put on their vehicles in their lifetime.
gas , guy , miles , mineral , spirits
Those running LC 7 wraps in the rear, what coils are you running up front? the walrus 3rd gen T4Rs 13 03-08-2019 03:08 AM
Mineral Basin trip report KidVermicious Classic T4Rs 16 07-11-2012 12:56 PM
WTT: '06 Sport Running Board/Tubes for SR5/Limited Running Boards thirstyturtle Want to Buy/Trade 6 09-14-2011 06:38 AM
Switching from mineral to synthetic engine oil. Flush? paraordnance 4th Gen T4Rs 4 05-22-2009 11:55 PM
