Old 11-16-2019, 06:12 PM #1
bdjcl bdjcl is offline
bdjcl is on a distinguished road
broke a mystery wire doing valve cover gaskets
It's a single wire that goes down the back of the engine. It broke when I was trying to lift the monstrosity of the wiring harness out of the way to remove the valve covers.
I am attaching a picture of the wire in question circled in red. That's not my wiring harness, but an imagine of one for sale that clearly shows the wire. It comes down out of the middle plastic piece that joins the 2 plastic pieces that go over each valve cover. Any ideas?
broke a mystery wire doing valve cover gaskets-s-l1600-jpg
'98 Corolla LE 193k miles
'98 4Runner Limited 215k miles
bdjcl is offline   Reply With QuoteReply With Quote
Old 11-16-2019, 08:23 PM #2
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I'm pretty sure that's the wire that plugs into the coolant temp sensor for your dash coolant temp gauge.
Old 11-16-2019, 09:08 PM #3
I think you're right...bummer. I hope I can splice it
Old 11-16-2019, 09:38 PM #4
bingo...here's a thread I found that shows where the single wire I broke plugs into the back of the manifold
https://www.toyota-4runner.org/3360685-post9.html
Old 11-16-2019, 11:58 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
You can splice them as the wires are copper so you can even solder and heat shrink it..
Old 11-17-2019, 12:24 AM #6
4Reak Show's Avatar
4Reak Show's Avatar
Pretty sure that temp sender just has a male spade connector on it. Strip and crimp a basic female spade connector onto the wire. Easy peasy.
I've had to do it before as the OEM connector does become brittle of several hundreds of thousands of miles sometimes.
Old 11-17-2019, 02:05 AM #7
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
You're correct. It is just a simple female spade connector on the wire.
Old 11-17-2019, 05:16 PM #8
yep, didn't have enough wire coming out of the wiring harness. I tried to splice it in but it came loose when I was reassembling everything. Left it disconnected for now, pisses me off. At least I have a bluetooth temp reader
Old 11-17-2019, 07:00 PM #9
good idea. I guess I'll have to take the plenums back off to be able to get back there, huh?
Old 11-20-2019, 10:34 AM #10
Naturally, I dropped the tiny plastic plug that goes into the sensor and can't find a part number for it. I wonder if an auto parts shop would have one.
This is the part number of the sender itself: 83420-16020. I need the plastic plug piece that plugs into it.
broke , harness , valve , wire , wiring
valve cover gaskets 01thunder 3rd gen T4Rs 12 11-23-2013 09:18 AM
Any other gaskets I should replace when doing to valve cover gaskets? michaelreed 4th Gen T4Rs 0 07-23-2013 09:08 AM
Valve Cover Gaskets 4RUN0326 3rd gen T4Rs 6 04-22-2013 02:32 PM
Valve cover gaskets SJC 3rd gen T4Rs 16 08-02-2012 12:29 AM
Which Valve cover gaskets? mitfan311 Maintenance/Detailing 0 11-15-2009 09:43 PM
