11-19-2019, 10:51 AM
What Color Should I Paint My Flares?
Previous owner did a number on this truck before I got ahold of it, one of which being the cheapest Maaco paint job in an ivory-ish cream thats so bad you think of spoiled milk when you see it. New paint is on the to-do list but those type of funds are not available ATM so I figured I’d at least spray the flares. I’ve been thinking about colors ever since I got the truck but haven’t put much time to it, so I’m asking for help. I was playing around with what blacks I had laying about: Matte, Satin, Gloss, Semi-Gloss and Matte Clear but am not feeling too fond of the extreme contrast. I haven’t got any lying around, but flying around in my head is some sort of grey (gunmetal, metallic, stone?) or brown or green?
I would love to hear what color(s) you’d use if this was your truck.
‘97 SR5 2x4 177k | Front: Bilstein 5100+toytec 600# /Rear: Fox 2.0 Performance Series Struts+SuperFlex coils, JBA UCA, Whiteline LCA bushings, OEM Ball Joints, Tie Rods, and Front Links, 2nd Gen Rear Links, T-Belt, T-Stat, Water Pump, B&M 70268, 295/70/17 Nitto Trail Grappler Wrapped GX470 wheels, UltraGauge, Trans Temp Gauge, HID Retrofits, Recycled Barn-Door Cargo Drawers, Home-made Doggy Divider, Satoshi Inspired Grille, Max-life ATF, Toyota Red Coolant, 5w-30 Pennzoil Ultra Platinum w/20% HD Hyper-Lube, eBay Window Visors, Tint, $20 Walmart Keyless Entry, Cheap Alpine H/U and Speakers, Bed Liner’d frame, and a whole bunch of fishing gear.
11-19-2019, 02:30 PM
It looks like those are the "skinny black" flares that were unpainted from the factory. If you want them to look OEM, go SEM Trim Black. Anything else is up to you...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
11-19-2019, 02:32 PM
Real Name: Jon
Real Name: Jon
I would leave them black. Well at least until you see what color you end up with on the rig itself.
I always wanted to paint a 3rd Gen Raceway Blue. But doubt I ever will paint one different from its original color..
Creame is a hard color to visualize other colors with in my opinion. White would show all the dirt on your flare. Silver may work.
11-19-2019, 02:39 PM
Real Name: Tony (no surprise)
I generally feel that fender flares look best the same color as the bumpers, and on Limiteds, the "connected" side cladding along sides...
2000 Limited, E-locker
Maintenance/Build Thread
11-19-2019, 02:52 PM
@ brillo_76
I do have a couple cans of metallic silver. I wish I knew how to edit photos. Would make this whole situation a lot easier.
Thanks for all of the replies. Hoping for more suggestions. These “skinny flares“ are SR5 flares, correct?
11-19-2019, 04:03 PM
Yes. There was a later 'wide' SR5 flare too that was painted and matches the width of the Limited flares but without the door cladding.
11-19-2019, 09:11 PM
I also vote to leave them as is for now. Hard to decide what you want to do with the fenders until you decide what to do with the rest of the paint.
11-19-2019, 10:33 PM
Real Name: 3 Bears
Real Name: 3 Bears
hot pink
or leave them black
