Old 11-19-2019, 12:31 PM #1
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
Surging/Hunting/Bucking
I have been working on a 2001 Sport 2wd with what I can best describe as a Surging problem at about 1800 to 2800 RPM. I happens under moderate acceleration best felt when going up a grade. The engine is 10,000 miles off a fresh rebuild and has been running great until this point. At idle the engine runs smooth outside of the RPM listed there is no miss it has good acceleration. I have swapped the A/F sensor, MAF sensor and Throttle Body. Air cleaner spark plugs and wires are all new condition all quality parts. The 4runner was fine I left it for 4days upon my return I noticed the Surge. I find no rodent damage in the engine compartment or at the Evap system. Any Ideas would be helpful. I have been looking at previous threads and have nothing that will help me resolve the issue.
plcfcng is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 05:55 PM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Check for any CEL codes or pending ones (using an odb2 reader)?
Fuel filter?
Do you periodically run any fuel system cleaner?
Let us know.
Old 11-19-2019, 09:03 PM #3
plcfcng's Avatar
Real Name: michael
plcfcng's Avatar
Real Name: michael
I have replaced the fuel filter no pending CEL and no I have not used a Fuel system cleaner.
Old 11-19-2019, 10:00 PM #4
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
This sounds electric or computer related to me. A poor ground or battery terminal connection could do this at certain rpms. A failing battery can also cause strange issues. Another thought was a vacuum leak of some kind. Any cracked hoses or connections?
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 11:14 PM #5
negusm negusm is offline
negusm will become famous soon enough
Define "quality parts"?
Did you swap the TPS too?
negusm is offline   Reply With QuoteReply With Quote
Old 11-20-2019, 03:05 AM #6
plcfcng's Avatar
Real Name: michael
plcfcng's Avatar
Real Name: michael
No vacuum leaks, pcv valve new I can do a voltage drop test but I cleaned terminals and made sure ground was solid when I installed the engine as far tps goes I switched it with the one on my wires 2001 still had ht problem.
Old 11-20-2019, 04:15 AM #7
BoomerBob's Avatar
BoomerBob's Avatar
I'd say a fuel pressure test would be a prudent check at this point.
How new are the plugs and wires? Is it possible one or two of the plugs accidentally got their gap changed during install or are possibly going bad. Having a spare coil or coil set might be a good thing to eliminate them.
I've had vehicles run fine unless they were under load. The issue was some kind of resistance with spark. Usually a plug, wire, or coil pack.
Just trying to eliminate possibilities. These kind of issues can be a bear to track down much like intermittent electrical problems. The worst of the worst to find but usually easy to fix once found.
Old 11-20-2019, 01:13 PM #8
plcfcng's Avatar
Real Name: michael
plcfcng's Avatar
Real Name: michael
as far as quality parts plugs and sensors are denso or factory parts in a swap with my wifes 4runner.
Old 12-19-2019, 04:58 PM #9
plcfcng's Avatar
Real Name: michael
plcfcng's Avatar
Real Name: michael
Well after a few weeks of trying to figure this one out I let my friend who is a master tech have it. After a couple of hours he figured out I had a partly clogged CAT. I had considered this was the problem but it would rev out clean in neutral so I thought my CAT's were good. I should have put my vacuum gauge on it so off to the muffler shop it went 675.00 later she runs great again.
Old 12-19-2019, 05:34 PM #10
jgue467's Avatar
jgue467's Avatar
Thanks for updating with your Fix - many don't do that.
So how many miles do you suppose the cat had on it? Just wondering cuz mine is still holding out at 320K....
Luck and enjoy the Runner.
Old 12-19-2019, 06:42 PM #11
BoomerBob's Avatar
BoomerBob's Avatar
How much oil does it use between oil changes, synth or dino oil, and at what mileage do you change it. Also does this vehicle see mostly city, highway, or about 50/50?
Dang cats are expensive!
Old 12-19-2019, 07:06 PM #12
plcfcng's Avatar
Real Name: michael
plcfcng's Avatar
Real Name: michael
I just rebuilt the engine a year ago and it uses no oil. As far a the age of the cat's build dates on the cat 7/16 for both so you could do the math it may have had about 30,000 about 10,000 but on by me. What may have shortened the CAT life was a blown head gasket it also looked like they used a head gasket sealer. The sealer may have coated the CAT's shortening there life. It has two new MAGNAflow's on them now. I have seen this condition pop up as I did research on how to correct it with no common answer so I hope this can help the next person with this condition. Again if I had done a VAC gauge test I would saved myself alot of head ache.
Old 12-19-2019, 08:04 PM #13
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Cant you clean the cat out with cataclean??
Lots of folks had success with getting the cats to function properly again. However, maybe it's too carboned up. I look into a way to clean them before replacing. Way too new to be bad. ;)
Old 12-22-2019, 01:05 AM #14
plcfcng's Avatar
Real Name: michael
plcfcng's Avatar
Real Name: michael
I have seen videos about cleaning them I just didn't want to take the time to do it. While 675.00 is a bit of change I feel not making a car payment I could spring for the CAT's.
acceleration , engine , quality , rpm , sensor
Low idle / sometimes bouncy - hunting - surging idle / clicking with bounce Jhelms 3rd gen T4Rs 6 08-20-2015 05:39 PM
90 3.0 Bucking when cold caferacer73 Problems & Warranty Issues 0 08-27-2013 07:59 PM
Hunting a TE is like hunting for unicorns DDM4 5th gen T4Rs 43 01-04-2012 07:26 PM
bucking at load nhurt Problems & Warranty Issues 2 06-24-2011 08:24 PM
Bucking at low speeds? Dous 3rd gen T4Rs 44 08-29-2010 06:47 PM
