Old 11-12-2019, 07:10 PM #1
TheLincolnGreen TheLincolnGreen is offline
TheLincolnGreen will become famous soon enough
Rear main seal estimates
Got a few estimates today and thought I would share the info.
2000 3.4 4WD
The estimates ranged from $689 to $998.
$60 in parts + cost of an oil change + 8 hours labor.
Also had one shop quote me a timing belt kit replacement. $1100. I was told this one first, so the Rear main repair seemed cheap at only $700....
TheLincolnGreen is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 08:00 PM #2
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
Why the oil change? Do they plan on doing it while the engine is running?
/s Sorry for the snark. I know shops charge a lot for their services because they have a high overhead; more so in some neighborhoods than others. Still; those are some high numbers for the area I live in. Obviously not there though.
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 08:47 PM #3
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
I would think at least 5 hours to R&R tranny to get to rear seal and do all the clean up associated. Fluids and parts add to it. I can see 700 .
Old 11-12-2019, 08:54 PM #4
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Have you considered doing the job yourself? We have a 3-Part Video series that will help you get the trans out of your way so you can get the flex plate off and the rear main seal swapped out.
Here's Part 1 to the Trans Replacement Series:
To learn how to get the rear main seal out, you could consult the beginning of the video below:
Old 11-12-2019, 08:58 PM #5
The Cold War Kid's Avatar
The Cold War Kid The Cold War Kid is offline
The Cold War Kid is on a distinguished road
2000 3.4 4WD
How about $5?
Brake fluid swells rubber (neoprene).
Pour a SMALL can of brake fluid (dot 3) into your engine. Drive it a couple days, then change the oil. Given that the engine has a modern style seal, it's quite likely this will rejuvenate the seals (all of them, including valve seals) and fix the problem.
I've done this many times in my life. Never caused a problem and almost always worked. Do it. Don't do it. Just trying to help.
Now people will go nuts telling you this will ruin your engine, etc. etc. etc. It will not. But it will clean your engine, like few other things can.
2001 Sr5 V6 2WD
"...The closer you get, to the meaning, the sooner you know, that you're DREAMING..." (Black Sabbath - HEAVEN AND HELL)
The Cold War Kid is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 09:10 PM #6
Originally Posted by The Cold War Kid View Post
How about $5?
I may try it. The issue I see is with the dried toyota seals. They are more like bakelite at this point, and I'm not confident that they will absorb anything.
As far as the quotes being high, I guess it's the area. All three are small shops known for being reasonable.
Old 11-12-2019, 09:31 PM #7
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
How about $5?
Old time mechanics used tranny fluid to reduce/eliminate a smoking engine, it can't hurt and just might help. They poured in a quart trans fluid to 5 quarts motor oil.
Old 11-12-2019, 09:45 PM #8
BoomerBob's Avatar
BoomerBob's Avatar
Scotty Approved
FWIW: Scotty Kilmer highly recommends this product to swell seals and stop them from leaking.
https://smile.amazon.com/ATP-AT-205-...3609357&sr=8-1
I don't know how good this main seal stop leak is but Bar's a well known brand. They do constant testing and improvements to keep up with the latest technology.
https://smile.amazon.com/Bars-Leaks-...3609380&sr=8-3
Old 11-12-2019, 11:08 PM #9
Real Name: 3 Bears
Real Name: 3 Bears
I think some of the solutions listed above are only gonna buy time and not fix a thing for long term.
so put in juice, swell seal so it does not leak, pressure wash so all looks good, then sell
or put in juice to buy time, then get tools and parts , then fix it right
Old 11-13-2019, 01:31 AM #10
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
just to throw some numbers your way... i got a marlincrawler clutch kit for $300 when they had a sale. from amazon i got a engine rebuild kit for $65 which came with a rear main seal, and a set of bando belts for $29. my mechanic and i dropped the transmission and did the clutch, throwout bearing, pilot bearing and rear main seal since it's *right there*, for $650. i separately got new belts, which we also changed out toward that labor total.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 07:11 AM #11
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
I have seen the ATP 205 used and it works, but takes at least 500 up to 2000 miles to start working. But is it a cheaper alternative than replacing the rear seal? Yep.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 01:41 PM #12
DAWG NATION DAWG NATION is offline
DAWG NATION is on a distinguished road
I feel your pain...
Just got the same bad news today (Rear Main Seal Leak).
Even if i could afford it right now, not sure i want to spend more money on Big Bertha. She has 229K miles on the clock and who knows what else could go wrong.
I was looking at Lucas Stop Leak but i have seen a few people suggest the ATP AT 205 so i think i'm going to try the AT 205 solution for now and see what happens...
Good Luck!
DAWG NATION is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 02:03 PM #13
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Lots of good suggestions that can possibly do the job for cheap. It just feels such a rip off to spend $700 on an oil leak.
I've had good results with stop leak in my power steering system in the past.
326WHP 347TQ
Old 11-13-2019, 03:08 PM #14
HiLife HiLife is offline
Another way you could possibly save is to ask a mechanic your comfortable with if is able to the job off the books. Do this only with shops/mechanics who has done work for your in the past cause no receipt is part of it.
Another way is to ask a auto trade school. Some teachers would be happy to throw the rear main seal job at the students.
Old 11-13-2019, 03:53 PM #15
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
OP, how bad is the oil leak anyway? If it's not that bad and you don't mind the oily mess, doing nothing is an option as well. Adding oil to your engine is pretty easy.
estimates , main , rear , shop , timing
Rear main seal?? sport05 3rd gen T4Rs 21 04-24-2020 03:33 PM
Rear Main Seal Job soundmanlpte 3rd gen T4Rs 3 02-04-2019 06:45 PM
Rear main seal HELP superdavebigD 3rd gen T4Rs 1 03-14-2018 09:21 PM
Rear main seal? shocar4 4th Gen T4Rs 3 11-05-2012 10:34 PM
Rear Main Seal Steve8v92 Classic T4Rs 0 04-27-2009 09:19 PM
