Old 11-24-2019, 07:33 PM #31
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Nope, no codes were present nor did I expect any. Nor did I hear any noises. But at that time the POS Aisin fan clutch bearing was drowning out any other sounds. Can you get underneath while in P/N and hear the origin of the noise?
Yes, the stall test is a test to test the tc, though as in my case it passed yet the TC was bad.
I don’t know if anyone rents a tranny pressure gauge. I am not even sure the FSM gives numerical parameters for a pass/fail. I do know specific tranny FSMs for the a340 are listed on Fleabay from time to time.
Exhaust original?
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 11-25-2019, 10:20 AM #32
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by SaulG View Post
Where is Trans cable adjustment?
No trans cable to adjust on 2001-2002. OP has a 2002.
I'm sure you and OP know this, but for others who stumble upon this thread in the future: a line pressure test doesn't test torque converter failure or flexplate failure. A line pressure test is for checking the transmission fluid pump operation (and also the correct way to set the transmission throttle cable to set line pressure).
Old 11-25-2019, 01:47 PM #33
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Exhaust original?
When I was underneath over the weekend the sound seemed to be in the general bell housing region but not convincing enough to be definitive. That's when I started to consider the exhaust/manifold since an issue there can create similar symptoms from what I've read. It's also possible the slight slipping I thought I experienced a few nights ago could have been poor acceleration due to an exhaust leak? To my knowledge the exhaust is original. The previous owner had all records of maintenance from Toyota & didn't see any mention of a new exhaust.
I've been flipping through my FSM for stall test instructions but haven't found it yet.
If the FSM doesn't give numerical parameters for pass/fail trans pressure test, is it worth doing or safe?
I had no idea what a line pressure test tests for so thank you for the clarification.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 12-04-2019, 04:24 PM #34
fourfive's Avatar
fourfive's Avatar
Update:
I got a pending P0770 code, Shift Solenoid E malfunction, last night on my drive home. Shortly after I noticed my trans temps seemed about 10-20* hotter. Started a new thread specific to that code since I can rule out the flexplate for now.
P0770: Deciding on repair options
FSM P0770 & solenoid testing procedure:
http://www.teamtoyota4x4.org/archivi...at/cip0770.pdf
FSM torque converter testing procedure:
http://www.teamtoyota4x4.org/archivi...ccadp/insp.pdf
Old 12-16-2019, 01:12 PM #35
fourfive's Avatar
fourfive's Avatar
Inspected my flexplate after dropping my transmission this weekend. Flexplate looks good & no signs of cracking. Thought about getting a new one but decided to keep the original and just replace the transmission. I'm guessing my rattling noise was from the torque converter.
Auto transmission compromised if flexplate fails?-flexplate-jpg
flexplate , rattling , symptoms , time , transmission
97 auto to 99 auto transmission swap thegipper 3rd gen T4Rs 17 05-23-2017 05:13 PM
Auto Door Lock Fails to Operate K0nfusion 5th gen T4Rs 4 04-18-2017 11:54 AM
SR5 with no rear differential lock - how compromised? neowig 5th gen T4Rs 22 12-22-2016 07:40 PM
Flexplate Replacement PSA Neil_R 3rd gen T4Rs 7 12-27-2015 09:48 PM
TPMS compromised message General Discussions 22 08-27-2010 05:59 PM
