Old 11-21-2019, 06:46 PM #16
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Originally Posted by Kanoe View Post
I hear what you are saying. My corolla was sticky when I bought it. Just take a little silicon grease on a wooden match stick and get it into the latching mechanism. From memory there is a ball on a spring that catches in divits to do the holding. I was able to do it on the corolla without disassembling anything. I assume the 4runner is similar. With a flashlight you should be able to see in there enough to do it. Worst case you might have to crack open the column surround which is not too hard to do. Any of the videos (Tims) that show removing the steering column show how to get this open.
Good luck.
To quote myself.
Just get a little silicon grease on the pivot and you'll be good as new for years to come. At least try it before you tear into anything. The 2 minute solution before the 2 hour solution I always say.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 11-21-2019, 07:18 PM #17
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
To quote myself.
Nothing wrong lubing the pivot .
However, I believe I changed mine in less then 5 to 10 minutes tops. It's that simple.
As I changed it twice because my Chinese one was junk it wouldn't stay actived around turns.:/
found , maf , sensor , spray , work
3rd gen turn signal lever TN $50.00 Daddycreswell For Sale: T4R Items 2 07-15-2019 09:19 AM
Shift lever collar will not turn to reinstall. ShooterMcGavin 3rd gen T4Rs 24 05-20-2016 11:07 AM
turn signal steering column creak Bourbonator 5th gen T4Rs 1 11-15-2012 03:41 PM
Key hole feels sticky/ doesn't want to turn? 20034RunnerV84x2 4th Gen T4Rs 7 11-27-2011 12:53 PM
Noise from the steering column when I turn left and right Mabuse 4th Gen T4Rs 2 03-26-2010 10:21 PM
