Old 11-03-2022, 05:37 PM #1
cvan1971man cvan1971man is offline
cvan1971man is an unknown quantity at this point
Po304, po442, po420
Got a 2002 4runner that just threw these codes out. This is my first time handling a OBDII scanner.
I am guessing that I have a bad O2 sensor. I borrowed a Foxwell OBDII scanner from a friend. After I figured out how to use it, I got these error codes. See 1st picture.
The 2nd picture shows the test results. The "O2 B1 S2" was at zero with just the acc on. When cranked the O2S B1 S2 fluctuated up and down.
The O2FT B1 S2 stayed at 99.15 both on ACC and when idling.
Long FT #1 fluctuated up and down as well.
I am hoping that there is someone smarter than I - Is this a bad O2 sensor, if so, which one is it - Upstream or Downstream?
The 3rd picture is running the Foxwell on the Catalytic Converter to see what it said. O2S B1 S2 was at 0.00 and AFS B2 S1 was at 3.29. I did not test this one while idling. I can if it was a bonehead move.
IS THERE A BETTER WAY TO DETERMINE WHICH O2 SENSOR IS OUT? OR AM I BARKING UP THE WRONG TREE!
Po304, po442, po420-20221103_161717-jpg  Po304, po442, po420-20221103_161057-jpg  Po304, po442, po420-20221103_161004-jpg
cvan1971man is offline   Reply With QuoteReply With Quote
Old 11-03-2022, 07:59 PM #2
heat's Avatar
heat heat is online now
heat will become famous soon enough heat will become famous soon enough
heat's Avatar
You have three different issues, of which only #3 might relate to the O2
sensors. Picture 1 gives you starting points for diagnosis.
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is online now   Reply With QuoteReply With Quote
Old 11-03-2022, 08:12 PM #3
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Work on the miss first, either a plug - most likely, coil (though you'd have 2 misses since 1 covers 2 cylinders. Switch coils around to see if miss changes and go from there. Luck.
Old 11-03-2022, 09:41 PM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
A bad coil can cause a misfire on only one cylinder since there are two sides to each coil pack. It happened to me and it took me a long time to track it down. Only misfired when it was hot on cylinder #3.
Old 11-04-2022, 12:19 AM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
On the cylinder that's misfiring. You can swap it with another coil to see if it miss moves with the coil. As you be using same plug and wire. This can help eliminate which Part is bad. If it stays at that cylinder it rules out the coil and leaves only the wire or plug causing the issue. If it moves with the coil. The coil is causing it.
Old 11-04-2022, 11:44 PM #6
spartacus's Avatar
spartacus's Avatar
Could also be a bad injector, unburned fuel causing the other code.
Old 11-07-2022, 12:02 PM #7
New error codes
So, I replaced the #1&4 Coil - did not fix the problem - still have a misfire code
- replaced the spark plugs
- Replaced the downstream O2 sensor - I thought a bad O2 sensor could cause rich fuel conditions which could cause the plug to foul. When I ran the OBDII scanner, it looked like that sensor was not fluctuating and I thought it might be bad - it did not fix the problem.
- Now getting new error codes - see picture below.
Any ideas?
Po304, po442, po420-20221107_092839-jpg
Old 11-07-2022, 02:21 PM #8
Real Name: Patrick
Real Name: Patrick
Any ideas?
Do a compression test. If your compression is good then I would suspect #4 fuel injector is bad.
acc , foxwell , o2s , picture , test
2002 4Runner PO442 Code cvan1971man 3rd gen T4Rs 3 03-24-2022 12:41 PM
Emission problem PO442 pgf545 3rd gen T4Rs 0 06-05-2015 08:47 PM
Po420 code. Need help! Homegrown-Yota 3rd gen T4Rs 8 03-20-2013 06:46 PM
Po442 4runnerfevr 3rd gen T4Rs 0 04-20-2012 09:24 PM
Po420 alp 3rd gen T4Rs 5 03-17-2011 11:53 AM
