Old 11-23-2019, 11:22 PM #1
mountainthings's Avatar
mountainthings mountainthings is offline
mountainthings is on a distinguished road
Limited Multi-mode transfer case cheat sheet
I made a cheat sheet explaining the confusing transfer case in the Limited, since I got tired of re-explaining it when the wifey or friends are going off road.
For example, why pressing the 4WD button is actually AWD... And why 4WD is ok to use on pavement but 4HI-L isn't, or the difference between H4L and L4L...
Figured I would post it and see if anyone else finds it useful! Printable PDF is attached to the post below. Suggestions for improvements are welcome.
Limited Multi-mode transfer case cheat sheet-capture-jpg
2000 Limited - Bilstein 5100 - OME 906 - Falken WildPeak 265/75R16
mountainthings is offline   Reply With QuoteReply With Quote
Old 11-23-2019, 11:36 PM #2
zcruiser's Avatar
zcruiser zcruiser is offline
zcruiser has a spectacular aura about zcruiser has a spectacular aura about
zcruiser's Avatar
Awesome chart! I love[d] the 3rd gen Ltd driveline.
I would bold Do not use on hard surfaces and Low speed only
2012 4Runner Limited, Shoreline Blue Pearl / Beige leather, RCI skid, ext rear diff breather, Derale 13504 cooler, 110K
1993 300ZX Cherry Red Pearl with some bling, K&N intake, PowerTrix suspension, 130K
zcruiser is offline   Reply With QuoteReply With Quote
Old 11-24-2019, 12:55 PM #3
Rallysport Rallysport is offline
Rallysport will become famous soon enough
Handy chart!
Also not just limiteds, all 2001-02 4x4s are multimode. Personally I think it's underrated by the conventional wisdom on this forum.
Rallysport is offline   Reply With QuoteReply With Quote
Old 11-24-2019, 06:03 PM #4
Ryance39 Ryance39 is offline
Real Name: Ryan
Ryance39 has a spectacular aura about Ryance39 has a spectacular aura about Ryance39 has a spectacular aura about
Real Name: Ryan
Great chart. Thanks for putting this together.
Good reminder for us all as we are into winter now. I might have to print it and leave it in the car for my wife lol.
1962 Mercedes 220S Heckflosse
1999 Toyota 4runner Limited - Supercharged
2001 BMW M5
1999 BMW Z3M Roadster
2020 Super White ORP
Ryance39 is offline   Reply With QuoteReply With Quote
Old 11-06-2022, 09:47 PM #5
IronYuppy's Avatar
IronYuppy IronYuppy is offline
IronYuppy is on a distinguished road
IronYuppy's Avatar
Agreed. A major leap forward in traction options. I retrofit a 2000 VF3AM into my '97 auto SR5. That multimode option is sweet. It's not too different from the locking centre diff on my 80 series (after ditching the viscous coupler in favour of the push-button centre locking diff),
Currently replacing the auto tranny with a 5-speed from a 2000 Taco, so it'll be one of just a handful of manual/multimode rigs out there.
IronYuppy is offline   Reply With QuoteReply With Quote
Old 11-07-2022, 09:53 AM #6
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
I really pondered putting a multi-mode on my 5-spd '99 when I did the transfer case doubler. But I got paranoid that it would all stack up too long and I'd be into the gas tank. And I happened to find two nice donor J-shifts before I found a multimode for mock-up purposes.
JohnMc is offline   Reply With QuoteReply With Quote
Old 11-07-2022, 11:16 AM #7
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
My 2000 came with a little transmission operating guide card in a pouch on the driver's side visor. This is a little more clearly described, though. I like the J-shift configuration but I came from a 2nd gen and have no experience with other 3rd gen versions.
Old 11-07-2022, 01:18 PM #8
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
You are right. You would not be able to fit the Doubler with the stock fuel tank and Multi-Mode. I REALLY want to do a doubler on my rig, but the fuel tank issue is the biggest hurdle to overcome. You can run a Ford 19 gallon tank in the rear, but that's a lot of work for the same amount of fuel as the stock tank.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 11-07-2022, 02:33 PM #9
The NWF Eco-crawler I'm using is a couple of inches shorter than the Marlin Taco-box, but still, it's 6 1/2(ish) inches longer, and the multimodes have the actuator sticking out of the back end of the case toward the tank.
I have a tank back where the spare used to be, but it's an aux tank, there to double the range, not flatten the belly/make room for drivetrain shens.
4wd , case , limited , post , transfer
T-case Differences (all years of 3rd gens).. transfer case, AWD, multi-mode brian2sun 3rd gen T4Rs 179 03-05-2024 09:06 AM
Feasibility of a "J"-Shift to Multi-Mode Transfer Case Swap Diagram14 3rd gen T4Rs 18 01-21-2022 12:55 AM
1999 Limited 4WD issues (multi-mode transfer case) willhaman21 3rd gen T4Rs 7 12-06-2015 11:47 PM
multi mode transfer case question Yotaoffroad27 3rd gen T4Rs 20 09-25-2014 08:37 PM
Visor Transfer Gear Shifting Cheat Sheet, Not a "how does 4wd work" thread the4tion81 3rd gen T4Rs 2 03-05-2014 01:20 AM
