11-25-2019, 05:11 PM
#31
Location: Stationed in Camp LeJeune, home is Conover, NC
How to Build the Ultimate Winter Vehicle (3rd Gen) for $10,000
Originally Posted by brillo_76
quote
quote
Originally Posted by 19963.4lsr5
quote
You both spelt COPPER, which is an element.
I knew you meant COOPER, but couldn’t help myself.
And it’s Doc. Can’t call myself a SailOr; never stepped foot on a Navy ship in my 8.5 years.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
11-25-2019, 05:13 PM
#32
Stupid Tapatalk.
11-25-2019, 05:24 PM
#33
Originally Posted by Doc2012
Stupid Tapatalk.
It looks like you were enlisted (not an officer) by your rate patch. I know a few that were in and never set foot on a ship. Sadly I wasn’t one of them.
I don’t police auto correct as much as I should.
11-25-2019, 05:36 PM
#34
I was. FMF Corpsman, HM3.
11-25-2019, 05:42 PM
#36
-he said he spent 500 on suspension on fox shocks. they only make stuff in the front. cheapest is 480. he said he used them on all 4 corners. fox doesnt even make rear shocks for the 3rd gen (source: http://www.ridefox.com/dl/truck/FOX_TRUCK_APP-GUIDE.pdf, pg 29)
-his first reason for buying a bumper is for deer. that isnt what bumpers are for, but okay. doesnt mention you need a bumper like this to easily mount a winch in the front.
-spends a 10th of his budget on lights, only to fit covers over them that reduce output by 15%. do you want to see or not?
-dont you think something like a front locker for 1k would be better suited off for the snow than some pricey lights?
-can do rear seal work, but you wont do the brakes yourself?
-emergency gear, no budget for any cold weather stuff in case you get stranded? or are we just supposed to assume you have all of this stuff already?
oh my absolute favorite part about this story? i recognize that name anywhere; i present you with this lovely tweet by the author:
Wes Siler on Twitter: "Because of the #ClimateCrisis, I had a colleague’s brother sterilize me: https://t.co/89BsfuFLRp"
i wont be taking any sort of advise from this guy.
99 4runner limited; imperial jade mica
IG: mesooohoppy
11-25-2019, 06:16 PM
#37
Originally Posted by RandyBobandy
I run hella 700s with an upgraded wiring harness to handle 130 watt bulbs and they are extremely bright, I don’t think I would ever spend $1000 on a set of lights.
I’d also add a locker or limited slip to that list, I have a lunchbox locker that is awesome in the snow and allows me to climb icy hills in 2wd that a lot of vehicles can’t get up even with awd, though tires help too
Can you let me know what wiring harness you ended up with? I started looking into this towards the beginning of the year but got distracted with other projects.
11-25-2019, 06:40 PM
#38
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I got this one and run it with a 30 amp fuse with hella 130w bulbs, it is a drastic improvement over the light output of the 55w bulbs that come with the lights, and the harness is much nicer too.
11-26-2019, 04:22 AM
#39
Not a bad price! How much of a PITA was the swap?
11-26-2019, 10:24 AM
#40
It isn’t any harder than installing the wiring harness that comes with the lights, the hardest part for me was I bought LED switches and wanted them to come on with the dash lights so I had the open up the dash and splice into a wire to power the switches
11-26-2019, 06:42 PM
#41
It takes a while getting used to the ABS. You should have seen the first time I drove my 09 tocuma on fresh snow. I tried to drive it like the 98 Tocumas in 2wd or the older toyota pickup trucks drove in the snow. I had all the VSC lights on TRAC lights on and was sideways on the road in less then a min. Then I figured out what all this changed and was able to drive it with no issues.
I've never had a problem with ABS in other vehicles but on the 3rd gen it seems to be really poorly designed. It works ok on fresh snow but in packed snow, ice, slush it basically turns off my brakes until I do a leg-press on the pedal. I have to play it super careful on ice and start feathering it like 1/4 mile from a stop. Brake system is in good shape otherwise and I even tried replacing the ABS rings and stuff like that. I've read other people complaining about it and some people have just pulled the ABS fuse. Heard a lot of complaints about the 3rd gen VSC too, but my 99 doesnt have VSC.
99 SR5 v6 4WD
11 SR5 v6 4WD
11-26-2019, 08:39 PM
#42
I just took my trucks snows to the house. One tire has a bubble. They were worn below the siping on two of the 4 tires anyway do they only had the studs going on.
18 years at 80-90psi may have taken its toll.
11-26-2019, 08:50 PM
#43
Real Name: Jon
Real Name: Jon
Bogus. New Tires for you it's looking like.
11-26-2019, 08:52 PM
#44
Real Name: Jon
Real Name: Jon
I dont have issues with my ABS on my 98 and it rarely even kicks in. So you pull your fuse on the ABS in the winter?
11-26-2019, 10:04 PM
#45
Do you remember where the ABS fuse is? Is it under the little panel under the dash by the drivers side door?
2001 2wd - Daily Driver
