Old 11-26-2019, 02:39 PM #31
Riceye Riceye is offline
Riceye will become famous soon enough Riceye will become famous soon enough
Originally Posted by 4Runner4Leon View Post
I doubt that torquing the bolts would help with a leak in an FIPG seal, but it's worth a shot.
Yeah, but it really can't hurt to check the torque on the oil pan bolts. I'm seeing 52 in/lb in a criss-cross pattern.
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
Riceye is offline   Reply With QuoteReply With Quote
Old 11-26-2019, 03:51 PM #32
You know, I have no doubt some folks can do it in 2 hours. What I do doubt is how they would go about doing it - like you, I am about doing it right rather than doing it fast. Sort of like my alignment saga, haha.
I don't think that you could get a 4Runner engine out in 2 hours, at least not by yourself. With a couple guys who know exactly what they are doing, maybe... But that goes out the window if there is even 1 problem (frozen bolts, etc.).
I was working with 3 other guys (two professional mechanics, two 'normal' guys) and we had a Subaru engine out and back in (fixed clutch) in about 2 hours. Subarus are a bit easier though...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 11-26-2019, 04:46 PM #33
STI_MECE's Avatar
STI_MECE STI_MECE is offline
STI_MECE will become famous soon enough
STI_MECE's Avatar
this is about an oil leak not how much time it would take to remove an engine.
although, I did it in 4, with another guy who i had to give instructions on what to do, and tools in a bucket. I had to hacksaw shit off lol but thats on a 4x2, with front diff in the way removing engine would take longer. and the last bell housing bolt was in a bind so much it destroyed my biggest half inch drive.
If I really tried, and all things went smooth I say a solid 2-3 hours is reasonable.
2 hours if you got anything you need and you know exactly what to do with pneumatic. There is nothing to taking these out.
Its so simple. lol
2000 SR5 4x2 Resto/Maintenance
STI_MECE is offline   Reply With QuoteReply With Quote
Old 11-26-2019, 04:58 PM #34
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
No worries, I'm not planning on pulling the motor over a small seepage . It's just this topic came up on the other thread where the poster had to pull the pan, and one respondent said that he can pull a motor faster than drop the pan on a 4wd truck. Neither seems like fun, so I'll to diagnose some more, but let sleeping dogs lie if I can't easily fix it.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 11-26-2019, 06:32 PM #35
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
Thanks for the feedback guys. It's definitely not a bad leak, more of a "controlled seepage" as Jaguar helpfully dispositioned their 70's XJ6's, but I digress.
I dug a little further; the power steering pump and reservoir, are totally dry, so it's definitely an oil leak. The block is dry higher up, so it's not valve covers. I'm a bit puzzled by oil above the gasket line, but I guess it can creep up. Here's another picture; it's right behind the AC
I'm leaning to it being the oil pan, which I have no plans to address at the moment (I read that it's a toss up between dropping the front diff or pulling the motor, none of which appeal to me at the moment after spending a quality weekend under the truck refreshing the front end):
I doubt it's the crank seal, as I replaced it within the past two years when I did the timing belt. Of course I could have screwed it up, but it seems to not be coming from that area.
Did you use dealer parts or an ebay kit or aftermarket?
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 11-26-2019, 06:34 PM #36
Originally Posted by brillo_76 View Post
I am just curious. What type of oil are you using with these engines seeping and getting worse?
Been using Mobil1 5w30 for the last 6 or 7 years with everything bone dry. Only noticed this seepage a few months ago.
99 SR5 v6 4WD
11 SR5 v6 4WD
Old 11-26-2019, 09:04 PM #37
Real Name: Leon
Real Name: Leon
It was OEM. I just inspected the underside of the crankshaft area - it appears dry. I don't think that's where it's seeping from, but dye will tell (hopefully).
Old 12-17-2019, 11:32 AM #38
Real Name: Leon
Real Name: Leon
I have an interim update - put on about 500 miles with the UV dye, and so far no sign of it in the seepage. So either it hasn't worked its way out yet, or it's not motor oil.
I'll clean all the residue off, and start monitoring again.
Old 12-17-2019, 12:31 PM #39
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
If mine were that clean I wouldn't know what to do. But in the rust belt so it keeps components from rusting .
Old 03-22-2022, 05:36 PM #40
psea17 psea17 is offline
psea17 will become famous soon enough
did you ever find the leak? wondering how well the dye worked too.
'98 4Run SR5 v6 4x4-Orig Owner
Manual Transmission
Bilstein 5100 (front/rear)
OME 890 Springs (rear)
'99 Tall Springs (front)
psea17 is offline   Reply With QuoteReply With Quote
Old 03-23-2022, 11:48 PM #41
fatherohenry's Avatar
fatherohenry fatherohenry is offline
Real Name: Mark KN6TZI
fatherohenry is a jewel in the rough fatherohenry is a jewel in the rough fatherohenry is a jewel in the rough
I can vouch for the dye. My only suggestion would be to make sure you're able to keep checking if it doesn't show up right away. It didn't show up for me after the first couple drives. Then it rained for a week and by the time I got back under to check again, the dye was everywhere making it impossible to pinpoint the source. I spent hours wiping everything clean by hand and got very familiar with where my hands and arms would and would not fit (was taking mental notes with oil cooler and starter in mind).
'96 T4R SR5 | 4WD | Auto | 199 TBU | 262k+
fatherohenry is offline   Reply With QuoteReply With Quote
Old 04-04-2022, 08:28 PM #42
thanks for the input.
just cleaned up everything i could reach and added the dye today. going to check to see if i can determine where the leak is. i'm pretty stumped. half moon looks clean as could be. the cam shaft seal was replaced when i did my timing belts. not seeing any source for the leak yet.
Manual Transmission
Old 04-05-2022, 06:30 PM #43
Real Name: Leon
Real Name: Leon
Still haven't found the cause, so it's still on my to-do list. I am planning to replace the oil cooler lines and seals soon, so I'll have a close look in that area when I do the work.
engine , fluid , oil , pan , replaced
Water Leak Mystery Morphyne General Discussions 27 12-11-2017 05:26 PM
Mystery Coolant Leak, please help jrtredo 4th Gen T4Rs 3 03-02-2017 09:42 AM
Mystery coolant leak Deezil 3rd gen T4Rs 6 11-05-2016 10:11 AM
Mystery ATF Fluid Leak rockyMTNvagabond 3rd gen T4Rs 3 01-28-2015 11:31 PM
HELP! Mystery Fluid Leak M.A.R 4th Gen T4Rs 3 04-30-2011 11:50 PM
