11-25-2019, 04:22 PM
Head gasket vs bad coil/wires
Going to potentially look at a 97 weds. It has a misfire, cyl 3. Guy says it just needs new wires. How am I to know it only needs wires vs needing a new head gasket just by looking at it?
2000 T4R SR5 Black-Sold
2003 Toyota Tacoma TRD-Sold
2006 T4R Sport, V8, Shadow Mica. OME lift. JBA UCAs. Firestone bags. 265/70/17 BFG KO2. FN fx pro wheels.- Sold (mistake)
2007 Lexus GX470, Dobinson 2'', Firestone bags, TRD Pro wheels, General Grabber ATx
11-25-2019, 04:32 PM
Real Name: Jordan
Real Name: Jordan
Look for oil frothing under oil fill cap. Look for low coolant, dirty coolant, etc. If the misfire goes away after warming up this could indicate HG leak.
100% way to find out? Bring a boroscope with you and look in 3rd cylinder.
11-25-2019, 04:35 PM
Real Name: Jon
Real Name: Jon
White smoke when you fire it up and run it for a while. Antifreeze level. Oil level and smell.
Unless you do a compression check and antifreeze leakdown tests, it's sometimes hard to verify if head gasket leaking.
Engine would have to goto full operating temperature as well.
If at night and dark you can mist the wires and look for any arching.
Why not just fix the wires, coils if that causing the misfire.
Maybe an injector plugged too causing misfire or even a bad spark plug.
It could be a pile of things causing a misfire and just looking at it makes it kinda hard to find the exact cause.
11-25-2019, 05:43 PM
I use a combustion leak tester to check out used cars. I've heard it isn't always the most reliable test but its quick and easy to use. Look for common HG symptoms others have mentioned but the leak tester I linked is nice to have & they're pretty cheap. I've seen cheaper leak testers in the $30-$40 range.
Combustion leak tester:
https://www.amazon.com/UView-560000-...s%2C146&sr=8-7
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
11-25-2019, 09:36 PM
All great info. Thanks guys
11-25-2019, 11:27 PM
The exhaust would produce a sweet smell if the head gasket has failed with antifreeze entering the combustion chamber .
11-26-2019, 11:48 AM
+1 for this. also ask him to not run the car for a while before you check it out so you can hear a cold start. it'll produce more white smoke on the start if the vehicle has sat and more coolant has had a chance to drip and collect in the cylinder.
11-29-2019, 12:10 AM
I am starting to think my head gaskets are toast
all 6 cylinders were good at 170ish but I guess I need to pull the heads
11-29-2019, 10:05 AM
Real Name: Patrick
Real Name: Patrick
That's a little low, but still good. Why do you think you need to pull the heads?
11-29-2019, 11:05 AM
I think generally speaking, any time you hear the statement "It just needs" you can go right ahead and assume the end of that is "a whole bunch of work"
If it just needed wires, I wonder why he didn't spend 30 bucks and a few minutes to get it running tip top. Surely it would be worth more that way.
1997 4Runner SR5 4X4 5MT elocker.
2005 Echo Hatchback 5MT.
1990 Volvo 740 Turbo sedan.
1991 Volvo 740 wagon.
2000 Mercedes E55 sedan.
11-29-2019, 01:48 PM
Real Name: Jon
Real Name: Jon
Valid point. That phrase "It just needs" tells you it needs some serious
Yes like mine, Just needed some Frame work...LOL.
11-29-2019, 01:52 PM
Real Name: Jon
Real Name: Jon
Even or close to even is always very good for even lower compression.
As like Bad Luck why do you think you have to pull the heads??
You don't have a dead cylinder?? Is it because the compression is at 170??
11-29-2019, 04:48 PM
Real Name: 3 Bears
Real Name: 3 Bears
yep , if they are all about the same...even if low but equal..I would just suspect tired rings...but I sure would not start pulling stuff apart unless I had other issues
other issues like one dead or lots lower hole....fluid loss or cross contamination...a miss you cant fix otherwise with other fixes
11-29-2019, 05:19 PM
Real Name: Jon
Real Name: Jon
Sometimes we dont have a choice. I 100% agree but if I have a choice of leaving an engine be or tear it apart. I will leave it be for as long as I can. However, this is me. Others can do as they wish it's their rigs. ;)
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
