Old 11-26-2019, 07:29 AM #1
Greenmachine86 Greenmachine86 is offline
Greenmachine86 is on a distinguished road
Ac Compressor question
Ok so this weekend i tackled the heater core replacement... so i went back together with everything, tried filling the ac back with freon, no luck. So took to a mechanic friend, they pulled it down, filled back with what i need. So i got in cranked, tried the ac, it started to like surge, and pullin the motor down. Turned off, runs fine... i watched the clutch assembly, and it was like grabbing. Any ideas, thoughts?
Greenmachine86 is offline   Reply With QuoteReply With Quote
Old 11-26-2019, 12:46 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
What do you mean by grabbing?
Old 11-26-2019, 09:31 PM #3
Almost like its tryin to seeze up But then it releases and spins
Old 11-26-2019, 09:41 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
You sure you have a good compressor and the belt is good.
Old 11-27-2019, 10:11 AM #5
Real Name: Patrick
Real Name: Patrick
So the clutch applies (it's on the front of the ac pulley), spins with the pulley, and then releases after a couple seconds?
What year and trim is your 4Runner?
Old 11-27-2019, 01:55 PM #6
toyotaspeed90 toyotaspeed90 is offline
toyotaspeed90 is on a distinguished road
The AC will turn off if there isnt proper pressure in the system. Theres a switch on one of the lines over the passenger fender, near the connection points to fill/refill AC.
Did you guys build the pressure with a vacuum pump for 30 minutes (to also evacuate any moisture) then let it hold for a couple hours to ensure no leaks?
toyotaspeed90 is offline   Reply With QuoteReply With Quote
Old 11-27-2019, 05:33 PM #7
azrex azrex is offline
azrex is on a distinguished road
Compressor
Does it repeat this cycle of turning on/off rapidly? If so, I would suspect the charge amount is incorrect. First make sure the belt is in good condition and that the tension is correct. If the belt is ok, check the pressures when the engine is running and the compressor is engaged. You should see roughly 200psi on the high side and around 25psi on the low side.
azrex is offline   Reply With QuoteReply With Quote
Old 11-27-2019, 05:40 PM #8
Ok ill check deeper into that on the pressures. The ac has been workin proper prior to changing the heater core. It would freeze you out. I have had to charge it with the store bought can periodically. I think once maybe twice since i bough the truck 3 1/2yrs ago.
Old 11-27-2019, 05:44 PM #9
Yes it seems to grab for a few seconds and then release... i have 98 truck i believe its a SR5 trim package.... dont hold me to that. I paid a local shop to do this portion for me, first thing he came back with is the valve was bad, Replaced it , and the compressor is bad🙄
Old 11-27-2019, 06:25 PM #10
Compressor
If the system worked before, there is extremely small chance that the compressor suddenly went bad. My best guess is that the system is overcharged, which seeing the pressures would tell us. A bad expansion valve would not cause the symptoms that you're describing.
Old 11-27-2019, 06:32 PM #11
Real Name: Patrick
Real Name: Patrick
Incorrect charge amount. Most likely too much refrigerant causing the ac high side pressure switch to tell the compressor to turn off to save the system from exploding.
Old 11-27-2019, 09:13 PM #12
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Quote possible. Especially if the refrigerant wasnt measured or monitored going into the system.
OP do you know if they used a machine to charge the system or if they only used gauges and a big bottle of 134a?
Old 11-28-2019, 12:17 AM #13
I tried using the bottle first, would t work... took to the shop and they have a machine that does it
Old 11-28-2019, 11:08 AM #14
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Did this AC compressor ever function properly??
Old 11-28-2019, 12:59 PM #15
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
OP, I think you'll find this video informative. Same for anyone else that doesn't know a whole lot about how the AC system works on their rig.
Since it sounds like your system was exposed to the atmosphere for a decent amount of time, the desiccants in your receiver/dryer have been saturated by the moisture that's in the air. You should have installed a new receiver/dryer.
Those DIY refill kits can work, but quite often, people end up getting it wrong like people have mentioned on this thread by overfilling the system. The only way to know it's properly charged is with an AC manifold gauge set.
back , cranked , ideas , started , surge
Air compressor question cdiset General Discussions 6 08-10-2017 01:30 PM
ARB Compressor question Okki 5th gen T4Rs 71 03-07-2017 09:30 PM
ARB Compressor Install Question Oobleck 4th Gen T4Rs 5 06-17-2014 09:55 PM
AC Compressor Oil Question rjaudi 3rd gen T4Rs 8 06-05-2010 11:44 PM
Air Compressor Question greasefingers Engines / Suspension / Wheels / Tires / Audio / Accessories 23 05-09-2005 07:26 AM
