Originally Posted by silver4est
...what to do with the white wire that provides switched power to the light switch? the wire that Piaa says to tap into the high beam headlight wire....
That wire hookup is optional, only if you want the switch lighted. If so, Piaa says headlight wire so the switch light only gets power when the headlights turn on.
But what is turning the relay on? Usually a relay goes to switched power so the output power isn't On all the time and one doesn't forget to shut it off because it's switched power like say the ignition. Luck and enjoy the Runner.
