Old 12-02-2019, 08:59 AM #16
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I am thinking about putting it the wife van. As my in laws really enjoy theirs. As my wife looses her heat quickly. If your rig doesn't have the keyless entry and your after it. That might be the way to go. Well it's just a thought anyhow.
Old 12-02-2019, 09:49 PM #17
The Cold War Kid's Avatar
The Cold War Kid The Cold War Kid is offline
The Cold War Kid is on a distinguished road
Originally Posted by brillo_76 View Post
Do you have these stickers on your door windows. Do you have the RS3000 or RS3002 module under your drivers seat?
If the answer is no. I would call a local Toyota dealership and they can verify with your VIN. If you have keyless entry or not
3 of my 5 do not have this. So its quite possible you do not have it or you may.
Might be a good first step. As if you do not have the module. Those FOBS will never program.
Many vehicles have only one wiring harness. It has the wiring for all available options. If those options are not installed the plugs for them are still there.
I just wonder if the modules your pictures show (above) have a plug (wiring) in vehicles not endowed with remote lock/unlock?
If so, all I would need to do is to find a module...
2001 Sr5 V6 2WD
"...The closer you get, to the meaning, the sooner you know, that you're DREAMING..." (Black Sabbath - HEAVEN AND HELL)
The Cold War Kid is offline   Reply With QuoteReply With Quote
Old 12-02-2019, 10:21 PM #18
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Your rig is a 2001 or 2002 correct?
I believe they changed them in the later years. My photos are on a 1998 and I think they may have even dropped the stickers in the later years as well. :-( I think it went to the driver side kick panel instead of under the seats as we had a major change in the wiring in 1999 with the creation of the multiplex communication system.
I discovered this after I posted these photos as I have the pre 1999 and a 2001 in my fleet.
However, your thinking is correct. If your truck has the wiring plugs then the modules would be needed.
However, sometimes other things may be missing like fuses etc relays you name it.
So its not always as easy as it was for the Toyotas in the 1980s when all the trucks had the same wiring harnesses and you could just plug things in and they would work.
Research will have to be done and lots of things verified before I would say it would work.
I was bummed when I found out they changed the harnesses and left things out to save money. That all changed in Toyotas in the 1990s.
I had a 1998 tocuma sr5 5 speed manual at the time and wanted to add cruise control and my local parts dealer said it cant be done because most of the wiring harnesses didn't have the wires in them anymore. Unless your vehicle came with it.
So sadly, you may not have the plugs and wiring there or have only sections there. The 3rd gen 4 runners had a few different wiring harnesses and they are not the same from 1996 thru 2002. 1996 thru 1998 similar. 1999 thru 2002 similar but not exact.
Old 12-03-2019, 06:45 AM #19
Yeah - it's a 2001 sr5 2x4
I can't help but wonder how you know all this. Are you a line mechanic at a toyota dealership?
Another guy posted a link to a features list and there I saw only the limited models have remote entry. They were 4x4 only and cost 10k more.
My "rig" in purring now - still waiting for the other shoe to drop with the weird noise and the screaming on freezing mornings but other than that it's going good.
I was looking for a suv type vehicle for a while. I liked the sequoia but the fuel use and the NASTY thing with the air pump scared me off. I'm allergic to gm vehicles - never had a single one that was worth a (!). So I bought this truck. I really don't like the dinky interior but if it is as reliable and immortal as they say, I guess I can tolerate it.
And... so it goes. Thanks for sharing what you know
2001 Sr5 V6 2WD
Old 12-03-2019, 08:52 AM #20
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I am a hobby mechanic that have owned Toyotas for almost 30 years and started working on them when I was 14 years old.
We do have many users on here that are daily mechanics. Not me though. Its just a hobby.
I own 5 of the 3rd gens.
Anyhow. Your harnesses and locations will have to be verified.
I am suspecting your rig will not have the plugs.
I will look at my 2001 and see if it was moved or not. I thinking it was but that will tell me for sure.
Old 12-03-2019, 09:32 AM #21
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
Similarly frustrating, possibly more, we have a vehicle (not a T4R) where the remote lock/unlock works sometimes. Not often.
We are now Neanderthals and use the actual key to unlock the door(s).
Rockin it old school.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 12-03-2019, 10:37 AM #22
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Probably have some broken wires in your drivers door or tailgate under the boot.
Most of mine are key only no fob. ;)
Old 12-03-2019, 10:41 AM #23
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I did look no stickers on my 01 sport and no module under my seat. Maybe another user can confirm this. I am thinking it went under the driver side kick panel now. However, not 100% on that location.
Old 12-03-2019, 11:35 AM #24
levee-11's Avatar
levee-11 levee-11 is offline
Real Name: Levi
levee-11 is on a distinguished road
levee-11's Avatar
Real Name: Levi
Lok under the drivers seat. If there is a black box, I think that is the security system. I know that's what it is on my 1998, so it might be moved to inside the dash for your year. If you have the box, you should have the security system. Correct me if I am wrong, I don't think the security system was standard on SR5s
levee-11 is offline   Reply With QuoteReply With Quote
Old 12-03-2019, 11:51 AM #25
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Unfortunately not all sr5 have the security system. Actually none of mine do except the limited and my sport.
I believe it's an add on feature in the 1996 through 1998. From what I found out thus far.
The Sr5 package itself has a default set features. Like tach. Power windows, power locks.
Your system is exactly like mine RS3000 if its dealer installed [ 1998]
This is why we have 2 different fobs on the 3rd gen spectrum.
I think the change went down in 1999 but I am not 100% sure on that.
Old 12-03-2019, 02:49 PM #26
wtfemery's Avatar
wtfemery wtfemery is offline
wtfemery will become famous soon enough
wtfemery's Avatar
for anyone still wondering, you can check what system you have/if you have one or not by going on the toyota owners website and making an account with your VIN.
Mine came from the previous owner with just a plain key but according to my specs, "V3 V.I.P.-RS3000 SECURITY SYSTEM" was installed at the port by Toyota. So, hopefully I can program a new fob without issues. just have to figure out black or gray...
1997 4x4 SR5 3" Lift @254,000 miles
I welded my own bumper!
wtfemery is offline   Reply With QuoteReply With Quote
Old 12-03-2019, 03:05 PM #27
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yup or by checking with your local dealer.
The problem comes in when things get removed or changed.
You can also goto a local dealer with your title and get the builds sheets as well. Comes in handy if you need the key code provided PO didn't rekey the rig.
So which year is yours?
Old 12-04-2019, 01:25 AM #28
wtfemery's Avatar
wtfemery's Avatar
yup or by checking with your local dealer.
You can also goto a local dealer with your title and get the builds sheets as well. Comes in handy if you need the key code provided po didn't rekey the rig.
Sent from my sm-j337v using tapatalk
1997 sr5
Old 12-04-2019, 11:46 AM #29
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
1997 sr5
Maybe not. See this: Toyota VIP RS3000 System Remote 1998 & Up - TOY8110_B - Keyless-Remotes
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
@#$%^& , beebe , instructions , key , work
Wtb 3rd gen key fobs hec983 Want to Buy/Trade 8 01-24-2014 02:50 PM
3rd Gen Key Fobs $35 FL lilsid112 For Sale: T4R Items 7 11-30-2013 04:05 AM
Cheap Key Fobs Whiplash Willy 5th gen T4Rs 27 05-18-2013 11:18 PM
Key fobs buckin 3rd gen T4Rs 3 12-26-2012 12:52 PM
Do you need new key fobs? 3rd gen RS keyless system fobs here Qyota 3rd gen T4Rs 5 06-24-2010 11:41 PM
