12-01-2019, 10:02 AM
key fobs help
BEFORE SOMEBODY GOES OFF ON ME I did the search, read the threads, watched the video, kicked the tires, burbped the beebe... and still the !@#$%^&*!! DOES NOT WORK.
Given that I have followed the instructions, does anybody have any idea why?
2001 Sr5 V6 2WD
"...The closer you get, to the meaning, the sooner you know, that you're DREAMING..." (Black Sabbath - HEAVEN AND HELL)
12-01-2019, 10:13 AM
WHAT doesn't work? Cripes, I don't even know if you're talking about the vehicle side or the fob side of the equation.
Post details. The more, the better. Without gobs of details, no one can help. And since I've been through this myself, I know, for an absolute fact, that EVERYTHING you need to know, has been posted already.
12-01-2019, 10:17 AM
It could be broken or have a dead battery. If it's new then maybe this video will help.
YouTube
2001 2wd - Daily Driver
12-01-2019, 01:36 PM
That makes 2 of us - I don't know ether. Bought 2 new fobs. Can not get them to program...
Is it even possible my truck does not have remote door locks? Logical place to start. It says SR5 on the lift gate but it is a bare-bones trck - no leather, no moon roof... no extras I can see.
2001 Sr5 V6 2WD
12-01-2019, 02:20 PM
Yah, the procedure is very tedious and specific. Miss a step and you'll have to start all over. On the 8th try...mines worked. And didn't work on the 9th try when I wanted to add another fob in the system.
I would think being a new than 00 rig it would have that lock and unlock feature.
12-01-2019, 02:23 PM
Well, you're the one who has read all the form posts, watched all the videos, etc... That means you've seen all of this information already, right?
How did you know which of the 2 different versions of key fob to buy?
Best I can offer is that if you can't get the vehicle into programming mode, go into a dealer and ask them if your particular vehicle even had it as an option to begin with.
12-01-2019, 02:26 PM
Inside the engine bay passenger fender has the theft detergent horn and wireless door buzzer. If you have these then you have the wireless door lock system.
Attached are the pages of the fsm that I have used to program the key fobs. There are separate procedures for adding a key fob.
12-01-2019, 03:19 PM
Real Name: Jon
Real Name: Jon
Do you have these stickers on your door windows. Do you have the RS3000 or RS3002 module under your drivers seat?
If the answer is no. I would call a local Toyota dealership and they can verify with your VIN. If you have keyless entry or not
3 of my 5 do not have this. So its quite possible you do not have it or you may.
Might be a good first step. As if you do not have the module. Those FOBS will never program.
12-01-2019, 03:33 PM
2001 Sr5 V6 2WD
Unless a dealership added a module to have an aftermarket remote door lock fobs then you don't have it. Mine had a "Karr" brand module which you see in the Southwest; mostly in Cali. I took it out because I couldn't get the auto door locks, which I hate, to stop working. I couldn't get a "Karr" fob to work so I removed it from under the kick panel under the steering wheel. Very easy to do. The auto door locks stopped working and I was a happy camper. I have to use a key all the time but that's okay. There are other effective anti-theft devices one can use when going to high risk areas.
You may benefit from looking at the specs of your T4R.
Specs
12-01-2019, 04:52 PM
Real Name: Jon
Real Name: Jon
I believe my were added on as they are limited. My 01 is a sport and I verified with my local Toyota dealership via the VIN and it has it
I say this because they clipped into wires and added a relay brick under my steering wheel. I cant see that being this way off a factory floor. However, maybe they all are ad on the the 1996 - 1998 style.
My SR5 [ non limited ]do not. I am sure some of the higher end SR5 may have the add on.
12-01-2019, 06:49 PM
Specs
Remote lock/unlock not present. Problem solved. Thank you sir
2001 Sr5 V6 2WD
12-01-2019, 07:09 PM
Easy to add with an aftermarket system
12-01-2019, 11:32 PM
Location: Off grid in the middle of the middle of nowhere
Real Name: Phineas
Real Name: Phineas
Originally Posted by brillo_76
Can even add the remote start option. So your rig is all warmed up for you in these winter months. :] My mother and father in law have both their vehicles equipped with remote start.
My wife has remote start.
She makes me go out and start it.
1997 Limited
And an otherwise mean barn cat that likes to ride in it.
(And Vanwagons, but we keep that quiet around here).
12-02-2019, 01:54 AM
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
