19963.4lsr5, brillo_76, gamefreakgc, mtbtim, negusm, nissanh, RAD4Runner, snowninja, T4R2014
Old 12-03-2019, 09:20 AM #16
latuk latuk is offline
latuk is on a distinguished road
Did you replace the entire starter or just the solenoid?
latuk is offline   Reply With QuoteReply With Quote
Old 12-15-2019, 09:47 AM #17
Smile I ended up replacing my starter.
Thanks everyone for your input to my starting problems. Just wanted to leave a resolution to my issue for others to see.
Old 12-15-2019, 10:44 AM #18
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
If yours does the same thing (clicks one or many times then starts like no problem) then it needs Just these:
Amazon.com: Victory Lap ND-36SOL Solenoid Repair Kit: Automotive
Yes the starter has to come out, not that tough really like everyone makes it seem, yet far cheaper and w/b more reliable than most after market starters.
Luck and enjoy the Runner.
Old 12-15-2019, 01:49 PM #19
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
we had this plague in our outback. we changed out everything from the starter relay to the cable terminators, cleaned everything very thoroughly to ensure good contact... and it was the starter. so the solenoid repair kit that @jgue467 alludes to above may be useful for yours. a mechanic we discussed this with, said sometimes the starter develops dead spots where contact isn't exactly great. that might be a factor here... who knows.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
Old 12-15-2019, 03:38 PM #20
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
Originally Posted by 19963.4lsr5 View Post
If you have a helper have them hold the key in start and reach in the passenger and hit the starter with a hammer. If it starts spinning the instant you hit it it’s starter tine...
Not necessarily. Don't jump to conclusion.
What are other symptoms?
Voltage readings?
All connections good?
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 12-15-2019, 03:41 PM #21
RAD4Runner's Avatar
RAD4Runner's Avatar
Originally Posted by gamefreakgc View Post
When the starter contacts wore out on mine, it would at least made a little "click" of the relay activating. If you are not even hearing that, the juice isn't making it even to the relay.
Agree.
Old 12-15-2019, 04:05 PM #22
My Saturn when I had a bad starter didn’t make a klick. So after replacing the ignition switch and the clutch safety interlock switch and still had the problem I replaced the starter and problem went away.
Old 12-15-2019, 04:17 PM #23
jgue467's Avatar
jgue467's Avatar
Originally Posted by photoleif View Post
... a mechanic we discussed this with, said sometimes the starter develops dead spots where contact isn't exactly great. that might be a factor here... who knows.
The plunger after thousands of repeated beatings against the copper contacts wins by flatting the copper so much it does not make sufficient contact to pass enough current, hence the "click". Then after trying again and again, the plunger moves the copper contact just enough for sufficient current to pass to the starter. A new contact and your're back in business for quite some time.
Mine has survived to 320K but I've helped 2 other buddies change the contacts (actually it's only 1 contact that wears but may as well change both)....Luck all.
Old 12-15-2019, 04:59 PM #24
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Hmmm, I guess Ol' Timmy was right on this one. I reckon I sometimes get lucky with my Toyota forum diagnosis. OP, glad you got it fixed and you're rig is back on the road.
Good job fixing the problem on your own. You saved yourself lots of money turning your own wrenches. Next time though, consider just swapping out the contacts and plunger. If you starter was the original Denso, it's far superior to any other aftermarket crap that auto parts stores sell. If you got a remanned Denso, then you did good.
Old 02-25-2020, 03:12 PM #25
SR5_4Runner SR5_4Runner is offline
SR5_4Runner is on a distinguished road
Was this resolved? If so how was it fixed?
SR5_4Runner is offline   Reply With QuoteReply With Quote
Old 02-26-2020, 12:33 AM #26
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
The resolution is clearly stated in the thread. I suggest you read the thread rather than asking an OP who has not been back since December. Did you read any of the other six threads you posted the same question on?
We love helping people but we expect folks to expend a minimum of their own effort.
My Backyard Frame Swap
Old 11-22-2022, 05:36 PM #27
Rosali Rosali is offline
Rosali is on a distinguished road
97 4Runner SR5, Automatic
I have a similar issue. I already changed the starter and starter relay, to a new one. I checked the battery it's 12.14v output. All lights works, radio works. When I try to start it, you hear one click, NO crank ( at all), NO multiple clicking sound like battery is dying but you hear humming when holding the ignition to start. I tried moving the vehicle and tried to start it again ( nada). I tried starting I on neutral, nothing. The 4runner was just working 4 hours ago, I came home Parked it and it won't start anymore. Any thoughts? Thank you for your expert assistance or knowledge to share 🙂 at this point I hit rock bottom coz I have no idea what else to check 🤷
Rosali is offline   Reply With QuoteReply With Quote
Old 11-22-2022, 08:45 PM #28
Originally Posted by Rosali View Post
I have a similar issue. I already changed the starter and starter relay, to a new one. I checked the battery it's 12.14v output. All lights works, radio works. When I try to start it, you hear one click, NO crank ( at all), NO multiple clicking sound like battery is dying but you hear humming when holding the ignition to start. I tried moving the vehicle and tried to start it again ( nada). I tried starting I on neutral, nothing. The 4runner was just working 4 hours ago, I came home Parked it and it won't start anymore. Any thoughts? Thank you for your expert assistance or knowledge to share �� at this point I hit rock bottom coz I have no idea what else to check ��
Replace the starter (OEM or Denso reman) or rebuild it yourself (new solenoid and contacts. Normal stuff...
Edit... it may still just be intermittent - try the key to START for 1-2 seconds at a time multiple times until the starter spins. You basically are trying to find a spot where the starter contacts and solenoid have enough contact to run the starter (the solenoid spins a bit each time it is actuated).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
clutch , crank , start , starter , time
2010 no-start upon first crank. Second try starts Argyle Edison 5th gen T4Rs 5 06-20-2019 09:07 PM
05 4.7 V8 has intermittent extended crank time on cold/hot starts. Utah_4runner 4th Gen T4Rs 61 11-21-2018 03:57 PM
Starter rapidly clicks on crank twa318 3rd gen T4Rs 17 12-06-2016 01:37 PM
4runner wont start, only clicks Spencer 3rd gen T4Rs 19 10-06-2012 03:48 AM
