12-03-2019, 09:20 AM
#16
Did you replace the entire starter or just the solenoid?
12-15-2019, 09:47 AM
#17
I ended up replacing my starter.
Thanks everyone for your input to my starting problems. Just wanted to leave a resolution to my issue for others to see.
12-15-2019, 10:44 AM
#18
If yours does the same thing (clicks one or many times then starts like no problem) then it needs Just these:
Amazon.com: Victory Lap ND-36SOL Solenoid Repair Kit: Automotive
Yes the starter has to come out, not that tough really like everyone makes it seem, yet far cheaper and w/b more reliable than most after market starters.
Luck and enjoy the Runner.
12-15-2019, 01:49 PM
#19
Real Name: Leif
Real Name: Leif
we had this plague in our outback. we changed out everything from the starter relay to the cable terminators, cleaned everything very thoroughly to ensure good contact... and it was the starter. so the solenoid repair kit that
@ jgue467
alludes to above may be useful for yours. a mechanic we discussed this with, said sometimes the starter develops dead spots where contact isn't exactly great. that might be a factor here... who knows.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
12-15-2019, 03:38 PM
#20
Originally Posted by 19963.4lsr5
If you have a helper have them hold the key in start and reach in the passenger and hit the starter with a hammer. If it starts spinning the instant you hit it it’s starter tine...
Not necessarily. Don't jump to conclusion.
What are other symptoms?
Voltage readings?
All connections good?
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
12-15-2019, 03:41 PM
#21
Originally Posted by gamefreakgc
When the starter contacts wore out on mine, it would at least made a little "click" of the relay activating. If you are not even hearing that, the juice isn't making it even to the relay.
Agree.
12-15-2019, 04:05 PM
#22
My Saturn when I had a bad starter didn’t make a klick. So after replacing the ignition switch and the clutch safety interlock switch and still had the problem I replaced the starter and problem went away.
12-15-2019, 04:17 PM
#23
Originally Posted by photoleif
... a mechanic we discussed this with, said sometimes the starter develops dead spots where contact isn't exactly great. that might be a factor here... who knows.
The plunger after thousands of repeated beatings against the copper contacts wins by flatting the copper so much it does not make sufficient contact to pass enough current, hence the "click". Then after trying again and again, the plunger moves the copper contact just enough for sufficient current to pass to the starter. A new contact and your're back in business for quite some time.
Mine has survived to 320K but I've helped 2 other buddies change the contacts (actually it's only 1 contact that wears but may as well change both)....Luck all.
12-15-2019, 04:59 PM
#24
Real Name: Tim
Real Name: Tim
Hmmm, I guess Ol' Timmy was right on this one. I reckon I sometimes get lucky with my Toyota forum diagnosis. OP, glad you got it fixed and you're rig is back on the road.
Good job fixing the problem on your own. You saved yourself lots of money turning your own wrenches. Next time though, consider just swapping out the contacts and plunger. If you starter was the original Denso, it's far superior to any other aftermarket crap that auto parts stores sell. If you got a remanned Denso, then you did good.
02-25-2020, 03:12 PM
#25
Was this resolved? If so how was it fixed?
02-26-2020, 12:33 AM
#26
The resolution is clearly stated in the thread. I suggest you read the thread rather than asking an OP who has not been back since December. Did you read any of the other six threads you posted the same question on?
We love helping people but we expect folks to expend a minimum of their own effort.
My Backyard Frame Swap
11-22-2022, 05:36 PM
#27
97 4Runner SR5, Automatic
I have a similar issue. I already changed the starter and starter relay, to a new one. I checked the battery it's 12.14v output. All lights works, radio works. When I try to start it, you hear one click, NO crank ( at all), NO multiple clicking sound like battery is dying but you hear humming when holding the ignition to start. I tried moving the vehicle and tried to start it again ( nada). I tried starting I on neutral, nothing. The 4runner was just working 4 hours ago, I came home Parked it and it won't start anymore. Any thoughts? Thank you for your expert assistance or knowledge to share 🙂 at this point I hit rock bottom coz I have no idea what else to check 🤷
11-22-2022, 08:45 PM
#28
Originally Posted by Rosali
I have a similar issue. I already changed the starter and starter relay, to a new one. I checked the battery it's 12.14v output. All lights works, radio works. When I try to start it, you hear one click, NO crank ( at all), NO multiple clicking sound like battery is dying but you hear humming when holding the ignition to start. I tried moving the vehicle and tried to start it again ( nada). I tried starting I on neutral, nothing. The 4runner was just working 4 hours ago, I came home Parked it and it won't start anymore. Any thoughts? Thank you for your expert assistance or knowledge to share at this point I hit rock bottom coz I have no idea what else to check
Replace the starter (OEM or Denso reman) or rebuild it yourself (new solenoid and contacts. Normal stuff...
Edit... it may still just be intermittent - try the key to START for 1-2 seconds at a time multiple times until the starter spins. You basically are trying to find a spot where the starter contacts and solenoid have enough contact to run the starter (the solenoid spins a bit each time it is actuated).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
