Old 12-02-2019, 01:40 PM #16
3bears 3bears is offline
Real Name: Joshua 3 Bears
3bears is a jewel in the rough 3bears is a jewel in the rough 3bears is a jewel in the rough 3bears is a jewel in the rough
It would bug me to have it in there, and aside from what tim said about little pieces jamming into sliding mechanisms etc...what about soft parts like seals
hopefully you can fish it out and if not, like said, drop your TC and rotate it around till it drops out hopefully..... or hopefully doing so does not jam it in place
as far as taking it to a shop and asking their opinion..some shops might just see $$$$$$$$$
" oh man...you got to pull it out and completely take apart..and while we are at it , might as well get new bearings chains and seals "
2001 SR-5...bone stock ( for now) bought 12/10/20. silver, cloth, sunroof.
2000 SR-5 V6 Auto . TOTALED 10/22/20. Desert Dune, Spectre intake, Borla muffler, Magnafine tranny filter, B&M cooler, 3 inch lift with tundra springs, billies, lc springs tokico shocks, DRL delete, Big 3 wire, full roof rack, TBU, Swapped in Elocker , all synthetic fluid. block, oil pan and tranny heaters, other small junk
Old 12-02-2019, 01:43 PM #17
APhelps APhelps is offline
APhelps has a spectacular aura about APhelps has a spectacular aura about
If you're going to pull it and take it apart, it would be foolish not to put new bearings and seals in it to say the least.
APhelps is offline   Reply With QuoteReply With Quote
Old 12-02-2019, 01:48 PM #18
Just out of my own curiosity, how did this happen anyways?
Old 12-02-2019, 01:53 PM #19
4runnerfiend's Avatar
4runnerfiend 4runnerfiend is offline
4runnerfiend will become famous soon enough 4runnerfiend will become famous soon enough
Just doing a standard drain and fill. Wanted to see if the bottle would fit up in the space. Like I said my mind was somewhere else. Stuck the bottle in with out removing the cap, so the cap popped off when I took it out.
IG: @4runnerfiend- 1999 SR5: ELocker Retrofit, 5th gen front springs-tundra 5100's, Built Right UCA's, LC 8 wraps-Fox 2.0 with CD adjuster, Rokmen lower links, rear swaybar delete, Savage skids, Savage Rear tube bumper, TruckShopSD Sliders, Eimkeith PHC, ARB diff breather, F/R DuroBumps, 285 BFG KO2, Doug Thorley Headers, yellow top, ARB single compressor.
4runnerfiend is offline   Reply With QuoteReply With Quote
Old 12-02-2019, 02:10 PM #20
Makes sense.
For future reference a fluid pump goes a long way with gear oil. These are cheap and work halfway decently (mine doesn't screw on most bottles though :/)
https://www.oreillyauto.com/detail/b.../w1139/4613599
Old 12-02-2019, 02:10 PM #21
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of
mtbtim's Avatar
Real Name: Tim
If you can't force it out with gear oil, I really think you should try the borescope and flexible grabber tool idea I mentioned in post #4. It's only a $50 investment and that borescope and grabber tool could come in handy in the future. Who knows, maybe you could get the borescope and the grabber tool in at the same time and you could literally see how you need to manipulate the grabber tool to get onto the cap. For me, I'd invest the $50 for the chance to get it out and not either have to pull the transfer case or roll the dice like you were thinking of doing and let the gears grind it up.
I do like the other ideas with using a shop vac or air compressor but I'd worry that you might end up sucking or pushing the cap into a tight area and then you wouldn't even be able to get to it with a grabber tool. Right now, the cap might sitting in a spot really easy to get to.
Anyway, that's my two and a half sense on this situation you got yourself into.
Old 12-02-2019, 03:15 PM #22
I agree, I would put new bearings etc in too...I was just being sarcastic that if he took it to a shop for an opinion....it might go further then needed
too too many shady shops out there that do work that does not need to be done
Old 12-02-2019, 03:17 PM #23
kind of like popping a cap off a beer bottle ?
yes those cheap pumps are worth having....
Old 12-02-2019, 06:50 PM #24
brillo_76's Avatar
Real Name: Jon
brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold
brillo_76's Avatar
Real Name: Jon
Could be worse. Years ago I had a 1990 Camry that lost its transmission. So I found a donor car that just had a rebuilt transmission before it was sideswiped.
I swapped the engine and transmission and put rebuilt cv joint axles in this fwd Camry.
It wasn't a week and my driver side axle came out. It would not stay in. Here the axle broke right were the clip was and that was in the transaxle...
They transaxle ground it up or it got wedged in something and I drove that ride until the car rotted up. Rockers completely rotted out. Many years after that axle broke off.
That is plastic lid. I guess if your super concerned you could pull the transfer off and split it to get it out.
Things happen at least it wasnt hard steel like a section of axle in there. ;)
1997 4X4 V6 5 Speed Sr5 4 Runner (97 5 speed )
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
Old 12-02-2019, 11:31 PM #25
BrianSD_42's Avatar
BrianSD_42 BrianSD_42 is offline
Real Name: Instagram: briansd_97r
BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice
BrianSD_42's Avatar
I'm no expert but ..... I don't see how this realistically is going to cause any damage. It should get ground up by the gears eventually and as far as shifter linkage goes you would notice if anything got jammed up and even then it wouldn't cause permanent. I'm just lazy though and wouldn't pull it apart for something like this. Drive it for 2 weeks then drain and fill again.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giantís robe, Upon a dwarfish treasonous thief.
BrianSD_42 is offline   Reply With QuoteReply With Quote
Old 12-03-2019, 12:53 AM #26
4Reak Show's Avatar
4Reak Show is just really nice 4Reak Show is just really nice 4Reak Show is just really nice 4Reak Show is just really nice
4Reak Show's Avatar
Let the shaming begin! Any help is appreciated. Feel free to bash
Alright I'll do my best. But remember, you literally asked for it (interlock fingers and hyper-extend to crack knuckles):
You probably try to use a fresh ketchup bottle without taking off the safety seal also. And then I bet you go back to the store saying it's a faulty cap.
What would you have done if the bottle tip with cap DIDNT fit during your ingenious dry-run test fit? Would you have returned the bottle thinking that cap was the wrong size. "Ummm excuse me autozone clerk, I asked for TOYOTA gear oil. This bottle didn't fit". Sort of like how a diesel nozzle won't fit in a gas filler neck. (Or is that vice versa maybe? I don't have a small d!ck, so I've never owned a diesel)
I bet you'd go write a f*ckin blog about how gear oil quart tip/cap manufacturers are singling out Toyota owners with their non-insertable shipping caps. Jesus. I'm actually glad it did fit or we'd have a whole different snowflake thread going on here.
At what point did you actually feel like giving up on life knowing that you totally botched a 2 bolt, 2 quart monkey-f*cking-a-coconut job? I'll give you credit that you at least showed enough brain activity to stop everything and consult an online forum of total strangers before even attempting to remedy it yourself.
Here's an option: why not jam it into 4lo, and climb the steepest hill you can find. 1) it allows you to make sure you didn't ruin your transfer case like you ruined any form of mechanical credibility you were hanging onto and 2) you can then use gravity to help remove the cap. (Don't forget to set your e brake and put it in park, and also don't forget to practice walking and chewing gum at the same time).
Alright that's all I have for now in terms of being a prick.
For helping: yes use a bore scope and the mechanic finger. You could use a tiny zip tie and attach the camera to the finger in such a way to be able to see exactly what you're grabbing.
If not, bend a coat hanger or tie wire and just wiggle it around in a manor to try and knock the cap all the way down towards the drain.
Final is to remove TC. If you have money to burn and it's a gamble you can afford, roll with it. All likelihood it will do zero damage. But I don't chance it. Especially if you take this rig to remote locations. My luck, it would be fine for 3 years and then exactly in the middle of a trail long after I forgot about it would chew up a seal and leave me stranded.
Old 12-03-2019, 11:51 AM #27
I'll have to admit my first thought was to jam a wire coat hanger in and run it in 4 lo with out any oil. Feel like that would have solved my problem real quick.
Old 12-03-2019, 11:58 AM #28
thanks for the help.
Tried the vacuum with a piece of 3/8" nylon hose duct taped to it... no dice.
did a drain and fill 3 times. using a clean container in order to re use the fluid. after the third try i spun the front drive shaft back and forth and then .. i guess clock wise.. which pushed the cap to the drain hole. Fished it out with with the little mechanical grabber hands.
Thank you my friends for entertaining my shenanigans.
Old 12-03-2019, 12:57 PM #29
Soneill's Avatar
Soneill Soneill is offline
Soneill will become famous soon enough
Soneill's Avatar
Way to go!!!
2011 SR5 4x4, Toytec Ultimate w/ SPC UCA's, Shrockworks Front Bumper, 285/70/17 BFG KO2, NFAB Steps
Soneill is offline   Reply With QuoteReply With Quote
Old 12-03-2019, 01:53 PM #30
rallypoint_1's Avatar
rallypoint_1 rallypoint_1 is offline
Real Name: Bill
rallypoint_1 is on a distinguished road
Real Name: Bill
Yay!!! Donít do that again.
1998 T4R SR5 V6 2wd Evergreen Pearl OME 880 Toytec 1/4" spacer OME 906w/OME20mm(10mmx2)spacers Bilstein 5100 BFG KO2 31's Satoshi mod 1.5" BL(Fat Pats)
My 4Runner build:
http://www.toyota-4runner.org/3rd-ge...8-sr5-2wd.html
rallypoint_1 is offline   Reply With QuoteReply With Quote
case , gears , ground , plastic , transfer
v8 transfer case swap to 6cyl transfer case? V8RUNN 4th Gen T4Rs 23 09-11-2020 01:40 AM
FS 3rd Gen '01-'02 Transfer Case Actuator $50 + Transfer Part Out, Idaho Falls, ID BanditJunior For Sale: T4R Items 1 05-01-2019 01:57 PM
RCI Transfer Case Skid doesn't have Transfer Case Drain Hole boyfester RCI Metalworks 1 01-09-2018 08:35 PM
WTB: 4th gen V6 transfer case shift motor/transfer case drewskie88 Want to Buy/Trade 0 01-11-2016 12:41 PM
Advance Adapters 50-5705 Transfer Case Adapter 700R-4 To A Toyota Transfer Case 21 To NMRunner Classifieds - buy & sell (no commercial ads please) 0 08-18-2010 11:42 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
