Originally Posted by 4runnerfiend
thanks for the help.
Tried the vacuum with a piece of 3/8" nylon hose duct taped to it... no dice.
did a drain and fill 3 times. using a clean container in order to re use the fluid. after the third try i spun the front drive shaft back and forth and then .. i guess clock wise.. which pushed the cap to the drain hole. Fished it out with with the little mechanical grabber hands.
Thank you my friends for entertaining my shenanigans.
Just saw this thread and got drawn in. Glad it ended well!
I've filled diffs & transfer cases straight from the bottle before. It's sometimes faster & easier than using my pump.
