Old 12-01-2019, 08:54 PM #1
debnova debnova is offline
Real Name: Debbie
debnova is on a distinguished road
Real Name: Debbie
Arrow 04 heater fail, temp gauge stays put - Please look-
My 04 SR5 is not giving heat, so I came here first, since the more expensive cost of Heater Core is near impossible for me. Also, my dash temp gauge stays in one position, in the middle. No heat, but I hear fan. Are there any further clues I can get to figure out the issue?
I'm hoping it's low anti-f, bad thermo or cheaper fix. I am NOT mechanical (could you tell lol). I would have to use a mechanic, either independent or the Dealer.
Meanwhile, tomorrow I will come back here AFTER I have checked a few things mentioned in other threads about similar issues. Ironically, I am going to sell it, so of course things go wrong. It's been a great vehicle, only one repair and a battery change. I admit to NOT doing much maintenance on vehicle, except oil changes regularly. THANKS.
debnova is offline   Reply With QuoteReply With Quote
Old 12-01-2019, 10:19 PM #2
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Might have better luck in the 4th gen 4runners section as this is the 3rd gen section. (1996 - 2002)
However, mostly if your antifreeze is full and everything else seems normal. Your heat valve that controls the flow of antifreeze to the heater core is not letting the antifreeze flow through the heater core or your controls are not letting the air flow through you heater core.
As I am not super familiar with 4th gen heating system.
brillo_76 is online now   Reply With QuoteReply With Quote
Old 12-05-2019, 09:27 AM #3
Piney's Avatar
Piney Piney is offline
Location: Off grid in the middle of the middle of nowhere
Real Name: Phineas
Piney is on a distinguished road
Piney's Avatar
Real Name: Phineas
Yah, if it was a toyota cargo van I'd check low coolant, wire being off the heat valve or a bad spider (the dash control mechanics) or a stuck open T-stat.
Not sure where I would start on a 4th gen 4Runner.
1997 Limited
And an otherwise mean barn cat that likes to ride in it.
(And Vanwagons, but we keep that quiet around here).
Piney is offline   Reply With QuoteReply With Quote
heat , heater , temp , things , vehicle
TRD boost gauge and trans temp gauge? BulletToothTony 3rd gen T4Rs 0 10-15-2019 07:34 PM
98 4runner 4 cyl. gas gauge and temp gauge top hat 3rd gen T4Rs 2 07-05-2017 03:56 PM
3rd gen T4R pillar mounted gauge pod and outside temp gauge, $60, Denver CO Martinjmpr For Sale: T4R Items 2 06-04-2014 05:59 PM
2001 SR5 2WD - Bubbles in Tach gauge and Temp gauge tenro1 3rd gen T4Rs 7 01-01-2014 07:07 PM
Tach, Fuel Gauge, Temp Gauge, Oil Pressure Gauge, Alternator Quit Working silentrunner Classic T4Rs 3 10-05-2013 12:51 PM
