Old 12-05-2019, 10:42 PM #31
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Great deal glad your Transmission is running smoother. This is why a lot of people are using proven dextron compatible fluids and why so many stick as close as they can dexron II or III fluids.
Now I wonder how many people out there got their transmission fluid exchanged and have T4 or WS in there.
Thank you for reporting back and feeling us informed. We greatly appreciate that.
Old 12-05-2019, 11:04 PM #32
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
Yeah, the fan clutch could be going out, so replacing it might be the ticket but if you do install the trans fluid cooler; a fluid thermostat might be perfect for your climate. I'm installing one in my 01 too because I've noticed the external cooler does keep the trans fluid a bit too cool.
Amazon.com: Derale 13011 Fluid Control Thermostat Kit: Automotive
Check out this video to see if your fan clutch is like the one on this rig.
https://www.youtube.com/watch?v=N3DitIVc1n8
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 12-06-2019, 02:41 AM #33
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Not positive on the 340 tranny but generally speaking 3rd gear is a straight through with the minimal work being done by the tranny. It’s often the coolest running gear.
I’ve run Valvoline Max Life in my 3rd gen AT’s for a bit with great results. One with north of 330k on the tranny.
You can also buy solenoid kits that are easy to install if your TC isn’t locking/unlocking properly. I’ve had luck with the internet off brand ones.
Might also drop your pan and inspect/replace your filter. There are two versions (deep and shallow sump) with differing ports. Despite what Toyota claims, they aren’t lifetime. At least check to confirm the PO’s filter work.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
color , fluid , pink , throttle , transmission
Weird ac and transmission problem dm88 4th Gen T4Rs 1 07-08-2017 11:41 AM
Transmission issue? Weird symptoms, help! Rocket61 4th Gen T4Rs 4 09-29-2013 03:20 PM
Weird Transmission Shifts? CapeCod4runner 4th Gen T4Rs 4 06-12-2013 08:46 PM
weird fan issue T4R_Bass 3rd gen T4Rs 3 01-11-2011 03:10 PM
Weird issue skc0651 Problems & Warranty Issues 2 02-14-2008 01:01 AM
