Old 12-01-2019, 10:59 PM #1
WeakSauz WeakSauz is offline
WeakSauz will become famous soon enough
Steering wheel shimmy diagnosis help (with video!)
2000 SR5 4x4
230k on the clock
Trying to chase down an annoying steering wheel shake that occurs from 60-75mph. I am beginning to wonder if itís a tire balance issue, or even a bent rim. I am not sure if the shop I had balance these did it correctly (road force?)
Here is a video of the steering wheel itself.
YouTube
The video doesnít really do this justice- youíve really got to look hard to see the shake. But, in person is a different story. Itíll rattle ya pretty good.
New parts on the truck front end:
- New oem LBJs, outer tie rods, new oem steering rack with poly bushings, new sway bar end links and bushings, diff drop, new eibach struts/coils, tires are now 1 yr old (KM2s), rotors are new and not warped, alignment is in spec
Given all the new parts, itís pretty much gotta be a tire balance issue right?
2000 SR5 4x4, Auto | Millennium Silver and Moon Mist | Eibach Pro Lift Stage 1- Struts and Coils | Powdercoated Tundra Steelies | Tundra brake upgrade | 255/85/16 BFG KM2 | Gen 1 Roll bar | Shrockworks skids | ARB Onboard Air | Gen 1 Taco Manual Hubs with ABS retained | Alpine Double Din with Apple CarPlay, Full Alpine speaker set and in-dash Amp
WeakSauz is offline   Reply With QuoteReply With Quote
Old 12-01-2019, 11:07 PM #2
mtbtim's Avatar
mtbtim mtbtim is online now
Real Name: Tim
mtbtim is a splendid one to behold mtbtim is a splendid one to behold mtbtim is a splendid one to behold mtbtim is a splendid one to behold mtbtim is a splendid one to behold mtbtim is a splendid one to behold mtbtim is a splendid one to behold
mtbtim's Avatar
Real Name: Tim
9 times out of 10, it's wheel balancing. I'd seek out a place that does Road Force Balancing.
mtbtim is online now   Reply With QuoteReply With Quote
Old 12-02-2019, 01:57 AM #3
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
A quick way to find out if it's a wheel balance issue like it normally is; is to do a tire rotation if you have a couple of jackstands and a large hydraulic jack that will lift one end up at a time. I suppose you could lift one side up at a time using one jackstand and a smaller jack.
Could even put your spare on one of the fronts then swap it to the other side if you still had the vibration. Of course that assumes the spare is balanced well.
I chased my vibration problem for a long time until I did a rotation and I had the wheels balanced first. The road balance is a good option but a good balance guy can do a good job if they want to. A lot of the time they will get within 1/4 oz and call it good but it isn't. Tell the balance guy is has to be right on the money because the fronts are very sensitive to being even a little off.
If you get into mud sometimes; check the inside of your wheels for a clump of dried mud. That'll throw it off too. I cleaned the inside of my wheels while I had them off at home and was surprised at all the build-up of dirt and brake dust. I expected the brake dust but not that much dirt. It was uniform but still more than I expected.
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 12-02-2019, 09:59 AM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck has a spectacular aura about Bad Luck has a spectacular aura about Bad Luck has a spectacular aura about
Real Name: Patrick
@WeakSauz Like others have said it's likely a tire balance issue. I would try rotating your tires and test driving, and also making sure there isn't any mud or debris buildup on the rim causing the balance to change.
Do you have any slop/play in the steering wheel?
2000 Limited V6 Auto E-Locker
balance , itís , steering , video , wheel
Steering wheel shimmy FIX thegame7 4th Gen T4Rs 1 08-23-2019 04:44 PM
Steering Wheel Shimmy Samm25 4th Gen T4Rs 4 06-20-2018 05:20 PM
Steering Wheel Shimmy wakeboardwhan 4th Gen T4Rs 18 11-29-2011 07:33 PM
Steering wheel shimmy turkeyman 3rd gen T4Rs 20 08-26-2011 04:43 PM
shimmy in steering wheel??? kennyb3030 3rd gen T4Rs 4 03-09-2008 04:06 PM
