12-01-2019, 07:08 PM
Plastic cap lost in Transfer case now what
Let the shaming begin! My mind must be somewhere else. Long story short red cap/cover from gear oil fell into full plug on my 1999 j shift transfer case. Not sure if it will just get ground up from the gears or if I need to figure out how to fish it out. Any help in appreciated. Feel free to bash
IG: @4runnerfiend- 1999 SR5: TRD Supercharger, ELocker, Wheelers T1 Coils-tundra 5100's, Built Right UCA's, LC 8 wraps-Fox 2.0 with CD adjuster, Rokmen lower links, Savage skids, Hot Metal Fab Front Tube bumper, Savage Rear tube bumper, TruckShopSD Sliders, DuroBumps, RidgeGrapplers, Doug Thorley Headers, yellow top, XRC 12k, ARB single compressor.
12-01-2019, 07:22 PM
You could try removing the drain plug and flushing it out the bottom
12-01-2019, 07:25 PM
I couldn’t even see it with the drain plug open. Might be able to flush it out with a bunch of fluid. Was hoping someone has had this happen to them before. Humm
12-01-2019, 07:51 PM
Real Name: Tim
Real Name: Tim
Nope, you're uniquely stupid. Just kidding. Relax man.
The only thing I can think of is you could buy yourself on of those affordable borescopes, maybe something like this: https://amzn.to/2DwT9Zc and go in through the fill plug and see if you can spot it. If not, try going in through the drain plug. if you do spot it, you can use one of those claw pick up tools like this: https://amzn.to/2DBZjY0 to go fishing for it and with a little luck you'll retrieve the cap. If you want the best chance at getting it out, this is what I would do.
12-02-2019, 04:10 AM
Real Name: Keith
Real Name: Keith
I'd ask a real transmission repair technician if they think it's a serious concern.
I suspect it isn't.
You're talking about that little HDPE cap from the gear oil bottle vs. hardened Japanese steel gears, sprockets and a chain.
Without expert advice, I'd let it grind up and then maybe change the gear oil at a slightly shorter interval for peace of mind.
12-02-2019, 06:10 AM
Just turn the transfer over and shake it... a did that when I dropped a 9mm in.
dont ask
"Sadly, unlike the Bill of Rights, the UDHR has no 2nd amendment, rendering it useless. Remember that."
2person xUN diesel T4R equipped for long distance touring w/ light-duty off-roading. 1000kms range w/ subtank
Check out my FB page Toyota 4Runner Bulgaria
12-02-2019, 10:56 AM
I suspect it isn't.
Good thought. Yeah I was thinking a little plastic bottle cap VS. Heavy duty gears... plastic just isn't going to win.. obviously it is ideal to not have it in there.
12-02-2019, 10:57 AM
dont ask
haahahah!
12-02-2019, 11:00 AM
Originally Posted by mtbtim
Thanks for the advise. I'm going to get some cheaper gear oil and try and flush it/ fish it out. hopefully, since it will probably float, it will flow out with the fluid. if not I'm just going to let the gears chew it up and spit it out.
Will update.
12-02-2019, 11:21 AM
Will update.
Sounds like a good plan.
If it stays in there I'm sure the gears and chain won't even notice!
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
12-02-2019, 12:51 PM
Real Name: Tim
Real Name: Tim
Will update.
I don't know dude. You might very well regret deciding to leave it in there and let the gears chew it up. The transfer case isn't just a box with big gears turning. There's parts that need to slide freely like the shifter linkage inside the transfer case and I wouldn't want to bet any fragments of the plastic cap aren't going to wedge into a spot that will cause problems.
Honestly, if this happened to me and I couldn't fish it out, I'd do what
@ pavelvoivoda
said and pull the transfer case out and dump it on it's side to get that freaking cap out. Maybe I'm wrong and it's not a big issue but I wouldn't risk it. Pulling the transfer case is pretty easy. Disconnect the driveshafts, disconnect all the electrical connections, get the rear cross member out of your way, unbolt it from the trans and that baby is out.
12-02-2019, 01:01 PM
@ pavelvoivoda
Humm....
12-02-2019, 01:14 PM
See if you cant use an air compressor to blow through the drain hole and see if it lifts up enough to grab it from the fill hole.
2011 SR5 4x4, Toytec Ultimate w/ SPC UCA's, Shrockworks Front Bumper, 285/70/17 BFG KO2, NFAB Steps
12-02-2019, 01:19 PM
Try putting a shopvac over the drain plug but don't suck straight into the vacuum, go thru a 5 gallon bucket first. Could also step the hose down to a smaller size and put a bend in it to fish around the bottom, can also reverse it and blow in the top. Bet you won't do that again, good luck.
12-02-2019, 01:28 PM
This might be a great excuse to buy one of those borescope cameras, to see if you can find out where it went. Then you could use one of those flexible grabber jaw tools to get it out maybe.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
