Old 12-05-2019, 03:12 AM #16
Mackalicious Mackalicious is offline
Mackalicious is on a distinguished road
Originally Posted by 04rnr View Post
I agree with both statements, "IF" it is the exact same thing, Why, pay $75 for a name when you can get the exact same thing for $42?? unless someone likes to over pay for stuff lol
Idk... That ARB logo is pretty temping... The only reason to pay the extra is if you are an ARB fanboy or don't know about the cheaper only.
I get it Monday. I'll update with my impressions of the quality. I can almost guarantee it'll be comparable. It's just quick push fitting, ptfe hose, and an aluminum manifold. ARB wasn't reinventing the wheel with their product.
Mackalicious is offline   Reply With QuoteReply With Quote
Old 12-05-2019, 01:25 PM #17
Originally Posted by mtbtim View Post
So, technically the rear breather at the back end of the transmission over is the breather for the transfer case.
The transmission has its own breather, like you said. The u-shaped hose goes between the transfer case adapter and the transfer case itself. The transfer case adapter is just an empty area inside (no gear oil, no trans fluid, etc.) that houses the coupler between the trans output and the transfer case input. Just a semantic issue, I suppose...
If you are planning on getting water up to the top of the transmission or higher, then I understand putting together a breather system... But otherwise, only the rear diff breather is low enough to be an issue. Even the front diff breather is extended up to the inner fender from the factory.
Also, I don't believe there is any one-way valve on the rear diff breather. It is just a loose fitting cap, slightly crimped so it can't fall off. It does allow air to go out of the diff easier than in, but it should never be sealed in either direction.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 12-05-2019, 02:39 PM #18
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
This was my thought also with extending the breathers for the transmission and transfer case. It's only if you plan on fording some pretty deep crossing that you would have to worry about getting water sucked into your transmission. Water getting into the void between the trans and transfer case wouldn't be ideal but it wouldn't be as bad as getting water into your auto trans which we all know could be disastrous.
Taking a look at my 98 that has a suspension lift, I'm guessing I could ford through around a 2 1/2 foot deep creek or river crossing before I'd have to start worrying about having my breathers submerged. At that depth, water would be around 9-10 inches above the bottom of my doors.
I guess it also depends if you're able to cross without having to stop. Even if water did come over the top of the trans, I bet if you're moving and the trans is under positive pressure from the heat being generated, water isn't going to sneak it's way in. But, if you stall in deep water or are sitting there stuck and need to be pulled out, the chances go up dramatically that water is going to get in. I think if I have a trip planned with known deep creek crossings, I'm going to probably extend the breathers for my trans and transfer case.
Old 12-06-2019, 02:17 PM #19
Originally Posted by pluton View Post
I bookmarked it, in case it's good, but will reserve judgement right now. 'Polyethylene tubing' sounds janky, if that's what it really is.
Please let us know what you think, with photos if possible!
Here's pics of it. I 100% recommend it. Quality is fine for this purpose. It has a couple burrs I plan to knock off from the manifold port threading process. It includes a quality sintered bronze filter like the ARB.
Better than the DIY diff breather mod!-img_20191206_130150__1575655983_68-20-10-99-jpg  Better than the DIY diff breather mod!-img_20191206_130016__1575655973_68-20-10-99-jpg  Better than the DIY diff breather mod!-img_20191206_125925__1575655964_68-20-10-99-jpg  Better than the DIY diff breather mod!-img_20191206_125850__1575655951_68-20-10-99-jpg  Better than the DIY diff breather mod!-img_20191206_125828__1575655939_68-20-10-99-jpg  Better than the DIY diff breather mod!-img_20191206_125814__1575655913_68-20-10-99-jpg
Old 12-06-2019, 09:54 PM #20
04rnr's Avatar
04rnr 04rnr is offline
04rnr is a jewel in the rough 04rnr is a jewel in the rough 04rnr is a jewel in the rough
04rnr's Avatar
Thanks for taking the time, to snap some pix and sharing them.
2007 Sport.
"Colorado is FULL, try N.M."
"Everyone is an expert"
04rnr is offline   Reply With QuoteReply With Quote
Old 12-06-2019, 10:07 PM #21
No prob. Happy to help a fellow car enthusiast.
Not sure how long they will be on amazon, so i'd pull the trigger sooner than later. The listing even has the ARB part number in the title lol.
breather , diy , kit , tcase , tubing
Diff breather done dylans 5th gen T4Rs 4 08-07-2017 03:07 PM
Arb diff breather kolelt 3rd gen T4Rs 14 09-25-2016 08:08 PM
my diff breather jacal Engines / Suspension / Wheels / Tires / Audio / Accessories 10 07-18-2006 10:32 AM
diff breather 86runner-sas Off-Roading 4 11-04-2004 06:17 PM
