Old 12-13-2019, 02:44 PM #16
EvilMole EvilMole is offline
EvilMole is on a distinguished road
Originally Posted by Bad Luck View Post
99 springs are taller than other model year springs so the height difference in factory suspension is in the spring height not the strut. 96 strut is interchangeable/same part. If you're looking to add height without changing springs you can try a top hat spacer (goes between top of the top strut mount and the frame where the top strut mount bolts to) or a preload spacer (goes between the spring isolator and the strut top mount).
Got it. For some reason I was thinking a taller spring might require a longer strut. I'm not looking to add any height at this time. Just looking to get the truck back on the road as fast and as reasonably priced as I can. I'm going to go with the KYBs for the struts and mounts. KYB has a $25 rebate if I felt like doing the rears as well, but I don't think I need to do that at this time.
1996 SR5
EvilMole is offline   Reply With QuoteReply With Quote
4runner , fine , inexpensive , side , struts
Anti-Seize AE1M 4th Gen T4Rs 15 04-29-2020 09:02 PM
Brakes seize when applying slowly AntleredRuin 3rd gen T4Rs 12 04-11-2019 01:37 PM
Anti-Seize... Worth it? hamburglar210 5th gen T4Rs 26 01-02-2019 06:49 PM
Parking brake seize, need help GabrielM 5th gen T4Rs 4 10-17-2015 09:01 PM
Used Dielectric Grease instead of Anti Seize...help! dilip4runner1 3rd gen T4Rs 4 05-26-2014 11:20 AM
