Old 12-05-2019, 11:16 PM #1
levee-11's Avatar
levee-11 levee-11 is offline
Real Name: Levi
levee-11 is on a distinguished road
levee-11's Avatar
Real Name: Levi
Wiring leds to turn on when door open.
Hello everyone. This weekend I want to make led footwell lights that turn on when you open the door. I already have the led strip under the dash and I’ve made a cable that connects them to usb, and ran a low profile connector to the cigarette lighter so they turn on when the truck is on. However I want to make them only turn on when the doors are open. I could wire them into the dome lights I believe, or maybe the door switches, and I’ve seen other threads do this but they don’t give a real good answer as to how to do it. All I want is to connect the positive and negative from the leds to either a dome light or door switch. Does anybody know exactly where the wires are for one of these two things? Like I said I need a positive and negative not anything with grounding (I think there’s a difference, not super great with this stuff so correct me if I said that wrong). Any help would be appreciated, thanks.
levee-11 is offline   Reply With QuoteReply With Quote
Old 12-05-2019, 11:49 PM #2
fixxor fixxor is offline
fixxor will become famous soon enough
I tapped into the white/black wire (pretty sure thats it) coming down the driver side A pillar for mine. I found this thread talking about it: Where to tap the dome light?.
fixxor is offline   Reply With QuoteReply With Quote
Old 12-06-2019, 03:03 PM #3
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Exactly as stated above, in the drivers A pillar.
I put a second gen map light mirror with LEDs in mine and everything needed was found in the A-pillar. It has been several years but I believe you will find a permanent power wire and a door switched ground there that you can use. That should do it. I didn't run anything up to the roof light (that I can remember now)
Of course those wires are likely accessible in a better place under the dash, but I couldn't help with that.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 12-06-2019, 05:05 PM #4
The wiring is slightly different between '96-'98 and '99-'02 on the door / interior light wiring.
In either case, the driver's door switch is a switched ground signal that is all by itself. The earlier trucks have the other 3 connected together and the later ones have the front passenger door separate from the two rear doors.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
door , i’ve , leds , open , turn
Door Won’t open outside or inside. Help to manually open? brandon1 5th gen T4Rs 11 12-24-2018 12:51 PM
Anyone put LEDs in front turn signals on 96-98? alexb 3rd gen T4Rs 4 03-11-2012 08:16 PM
