12-06-2019, 03:06 PM
#16
Originally Posted by TCMach
FYI Tweak'd Performance can do the harness. I've already discussed it with them. I was looking at an LQ9 that was local to me at the time. 4L60 variant trans. Flipped Dana 300 or an old ford 205 if I could find one.
If you can afford, skip the LQ9 and get an aluminum block variant. It saves you 80lbs. Also, LQ4s are usually cheaper and the diff between that and the LQ9 is the piston tops. The LQ9 has like a half point extra compression. I have an built LQ4 block in my car. It's a hefty girl.
You can save a ton of money and get a factory harness and PCM from a chevy. Its super simple to adapt it to another car. Though your factory cluster integration is a diff issue. Just get a racepak for that if you have the scratch.
12-06-2019, 03:08 PM
#17
Awesome! Tweak'd is just below the OP and I in South Carolina.
Looks like they specialize in both Toyota and GM LSX, so the crossover knowledge makes sense.
I wonder how they'd price a harness mod for an LSX considering you can get an entire Holley Terminator X ECU to run an LS for $1,000 new these days. That termX is really a game changer.
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
12-06-2019, 03:09 PM
#18
Originally Posted by Bad Luck
It would probably take a few tries but they make a lot of different oil pan configurations. One of them should fit. The difficult part in my opinion is getting all the 4wd components to work. You'd need a driver drop transfer case so either a GM or Jeep transfer case. Then you'd have to make linkages to shift the transfer case and transmission (if it's auto). If I decide to do an LS swap I'll be doing it with a manual so I can use the adapter from marks4wd to keep the toyota transmission/transfer case.
Originally Posted by WeakSauz
For sure, let me know and we'll meet up!
From the limited research I've done, I believe the front DS will clear with a 1" body lift on a 4x4 LS swapped 3rd Gen
The batwing style oil pan on C5 vettes are wide and lower profile vertically than the car and truck pans, so they may be the way to go clearance wise.
12-06-2019, 03:15 PM
#19
12-06-2019, 04:16 PM
#20
Real Name: Tyler
Real Name: Tyler
Meh. Price was right on the LQ9 lol. Came attached to a relatively flat escalade too. IMHO I'd spend the money on a built harness and run stock gauges. Just like the idea of leaving that part stock. Don't get me wrong, racepaks are great, set one up in a F100 years ago.
They're great guys for sure. I can't remember if I got that far in the process or not. I'm in the middle of buying a house now so the fun stuff got put on hold.
2000 4Runner:Kings, 37s, lockers 2018 TRD OR:stock and staying that way
12-06-2019, 04:28 PM
#21
Real Name: Ed
Real Name: Ed
12-06-2019, 04:46 PM
#22
Real Name: Patrick
Real Name: Patrick
I was thinking the GTO style pan might fit. Too bad the mock blocks are so expensive. If it comes to it you could probably run a dry sump configuration
12-06-2019, 04:55 PM
#23
True. If I could find a used stock dry sump kit off an LS7 for cheap. I def. don't want to dump massive amounts of money into this project though. Aftermarket dry sump kits are $$.
I want to say the GTO pans are the same as the F-body pan I have bolted on the block now. Whenever I decide I want to test this idea out, ill prob try lowering in the engine with that pan first. It's already plumbed with a -12AN turbo drain, so i'm like 0.5% closer if I wanted to boost it. These engines can make up to 1000hp stock depending on how long you want it to last and as long as they dont predet
People are pulling those 5.3L from the junkyard, throwing them in fbody camaros with 80mm turbos and making 1000hp for like 5 track passes. They blow them up, then pull another motor for 150 bucks.
12-06-2019, 04:56 PM
#24
Originally Posted by Ed_C
Thats converted to 2wd
12-06-2019, 05:17 PM
#25
It never was 4WD, look at the interior shifter. There were lots of 2WD 4Runners in southern states.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
12-06-2019, 05:38 PM
#26
Official Vendor
Official Vendor
@ AssBurns
you might want in on this.
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
12-06-2019, 05:53 PM
#27
I legitimately thought the SR5s were only 4wd. I see in your sig you have yours swapped too.
12-06-2019, 09:00 PM
#28
Someone I know did one here on island. He ended up yanking out the diff to get it to fit. Doesn't mean you couldn't get it to fit, but 400 hp does not do you much good offroad in a basic 4runner. I will try to get some pics this weekend
1997 SR5 4x4
R150f swap E-locked 4.30 gears
Tundra 231 brakes LC 80 rims 285/75/16
2001 SR5 4x4
12-06-2019, 09:09 PM
#29
Originally Posted by eimkeith
@ AssBurns
will definitely want to chime in. Then we can see how much research he's actual done to back his "until I LS swap it" line. lol
I'm keeping my 5vz. With 5.29s it turns my 35's well enough and with dual cases it's got plenty of torque. lol
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
12-06-2019, 10:38 PM
#30
Oh man. I’m interested in understanding if he yanked the diff and went 2wd because he straight up couldn’t get it to work with it in. That is disheartening to hear if so. Would love to see some pics of that rig
