Old 12-06-2019, 09:15 PM #1
zazzomicron zazzomicron is offline
zazzomicron is on a distinguished road
Oil smells like gas...
Just rolled over 350,000km and did an oil change. I am continuously amazed by this engine. I put in 5.5Q last time and I pulled out 5.5Q! So I'm not burning an oil but the oil has a strong smell of gasoline. No cloud of smoke coming out the exhaust or anything either.
Should I be worried? Anything I should check/test? Not throwing any codes, MAF is clean..
2000 SR5
zazzomicron is offline   Reply With QuoteReply With Quote
Old 12-07-2019, 12:20 AM #2
spartacus's Avatar
spartacus's Avatar
Some minute amount of gas can get passed the piston rings and end up in the oil when the rings get worn down but it will evaporate when at operating temp. If it's a strong smell then it could indicate a rich fuel mixture which could be a bunch of things faulty injector, dirty MAF sensor, faulty O2 sensor, coolant temp sensor not working properly, damaged piston rings which is rare. Have you seen a drop in your fuel mpg recently. pull the codes via obd and see if you have any pending codes and look at air fuel ratio also if the coolant level is good.
Old 12-07-2019, 02:45 AM #3
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
A lot of short trip driving will allow the contaminants to build up in the oil...could be that.
pluton is offline   Reply With QuoteReply With Quote
Old 12-07-2019, 11:50 AM #4
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
Very true. Short trips with a cold engine means the engine runs in a very rich condition much more per mile than, say, on longer commutes or trips. Some of that gas is bound to get into the oil.
I say monitor the oil but don't be concerned at this point.
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 12-07-2019, 01:18 PM #5
negusm negusm is offline
negusm will become famous soon enough
He said "strong smell" of gas. I would do a compression check and pull plugs and see if anything is out of the ordinary.
2002 4Runner 4WD SR5 - Original Owner
negusm is offline   Reply With QuoteReply With Quote
Old 12-07-2019, 01:46 PM #6
JMat's Avatar
JMat JMat is offline
JMat will become famous soon enough
JMat's Avatar
Since you said the truck has 350,000km I'm going to assume you're up in Canada. With cold temps this time of year engines have to run a lot longer to burn off moisture and small amounts of gasoline that find their way in to the crankcase... How far do you generally drive the Runner? Do you use it for short trips or stop and go driving? Also agree that a compression test would be a good thing.
1998 Toyota 4Runner 3.4 4x4 with 340,000 miles.
199mm TBU-Bilstein 4600-'99 Tall Springs(Rear).Almost Totally Stock
1997 Toyota 4Runner 3.4 4x4 with 247k miles-Project car
JMat is offline   Reply With QuoteReply With Quote
Old 12-07-2019, 03:34 PM #7
Wedgy's Avatar
Wedgy Wedgy is offline
Wedgy has a spectacular aura about Wedgy has a spectacular aura about
Wedgy's Avatar
Send some oil to Blackstone for analysis;
Free Test Kits | Blackstone Laboratories
Wedgy is offline   Reply With QuoteReply With Quote
Old 12-07-2019, 03:43 PM #8
In my experience gas smell in the oil in order.
1) dripping fuel injector or injectors when engine is turned off.
2) bad pre-cat O2 sensor. The sensor side hardly ever codes unless the heater circuit shorts to it.
3) very short trips and lots of them. Do you have a light coffee looking slime under your oil fill cap?
Old 07-09-2020, 12:10 AM #9
Hi everyone. Thanks for the responses!
Still dealing with this. I had a compression test and discovered a burnt valve.
I've also cleaned the MAF as it was filthy and this made a big difference. Next is O2 sensors..
2000 SR5
Old 07-09-2020, 11:12 AM #10
You fixed the head I’m assuming?
5.5q , cloud , gas , gasoline , oil
Speaking of Smells... Sonoran_Desert 5th gen T4Rs 20 11-05-2019 10:59 PM
AC smells like vinegar, anyone else? MadeInMaine 5th gen T4Rs 21 06-16-2018 09:36 AM
98 Limited smells hot...... WenatcheeSkier 3rd gen T4Rs 10 06-05-2017 10:44 AM
98 4Runner 3.4 smells?? 4runner269 3rd gen T4Rs 7 08-08-2013 09:44 PM
4th gen AC smells bad Deaner9505 4th Gen T4Rs 7 06-25-2007 04:55 PM
