Old 12-07-2019, 03:07 PM #16
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
Originally Posted by seen20 View Post
So it depends on the year and if you have the electronic or manual climate control. But on my 2000 I disabled the auto a/c with defrost. You just have to unplug an electrical connector right behind the climate control bezel. Best part is you can still push the A/C button if you need extra help defrosting. Heres a picture
I like this idea...push a/c button if and when needed for extra defrost drying plus I can hit it occasionally to kick it on so it "lubricates" the compressor.
plus I have a few bulbs in that area that need replacement and have been stalling on it.
I have the dial style heater like you pictured in your post
then again....cant remember when the last time I used a/c
Old 12-07-2019, 03:09 PM #17
Real Name: 3 Bears
Real Name: 3 Bears
Originally Posted by spartacus View Post
coutesy of @TheDurk ; "Clutch relay is behind glove box, left side about knee high. It has a dark gray 2-row 10-pin pin plug". if you disconnect the relay the compressor is not going to come on. .
this looks easy enough as well.
Nice to have options
Old 12-07-2019, 03:35 PM #18
Riceye Riceye is offline
Riceye will become famous soon enough Riceye will become famous soon enough
I am not certain, but if the relay is disabled I don't think the a/c button will engage the clutch. This may well disable the a/c altogether.
The simplest method is to unplug the wires that are switched by the "defog" or "defog/ feet" position of the control. On my 2000 with the basic heat this is the pair of blue wires described by Charlie and myself.
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
Riceye is offline   Reply With QuoteReply With Quote
Old 12-07-2019, 05:12 PM #19
alumarine alumarine is online now
alumarine has a spectacular aura about alumarine has a spectacular aura about
yep...bit chilly....got to minus 26 yesterday high of -13. today only supposed to get to 5 for a high
if there is a limit switch to keep it from kicking on if too cold outside....its not working.. or maybe has to get to minus 30
Have you looked at the A/C clutch to see if it's actually engaging?
It sounds like you have more of a blend problem.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is online now   Reply With QuoteReply With Quote
Old 12-07-2019, 06:13 PM #20
Real Name: 3 Bears
Real Name: 3 Bears
well to be honest...no
but it sounds like it is and the engine idle goes up and down when it sounds like it kicks in. jumps from just under 700rpm to about 1100 rpm
Old 12-07-2019, 06:19 PM #21
Real Name: 3 Bears
Real Name: 3 Bears
this is most likely the route I will take. then I can use the ac button when needed for "extra" defrost...and exercise the compressor occasionally, like exercise the 4wd like we are supposed to in off seasons.
if it helps with mpg...that's good...this time of year I go from 18mpg to 11 or 12...in part because I have to let it warm up for a while outside even though I have block, pan and tranny heaters and im in 4wd all the time
Old 12-09-2019, 08:17 PM #22
There is a thermistor for the AC system that should engage/disengage the AC compressor clutch when the AC is "ON" (button depressed or either defrost setting selected). The compressor shouldn't engage until the air coming past the AC evaporator is above freezing - the thermistor is there to avoid freezing up the evaporator core in humid conditions. The AC amplifier may still turn on the AC compressor for periods of time despite the temp though - I haven't tested that.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 12-10-2019, 12:11 PM #23
Had a chance to test mine.
At 28F the compressor cycles occasionally.
At 3F compressor never comes on.
Old 12-10-2019, 12:30 PM #24
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
just interrupt the circuit at the compressor clutch. wire in a switch at that connection. you will have instant and ultimate control at the flip of a switch.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 12-10-2019, 01:22 PM #25
Real Name: 3 Bears
Real Name: 3 Bears
ok so mine is a 2000 with the dial slide havac like you have pictured, however, I went into it yesterday and there is no easy to find plug behind it. and not one with 2 blue wire did not want to start removing screws as it looks like it is mounted behind dashboard.
so closed it up....ran out of time...today I guess I will go for the relay behind glove box
Old 12-10-2019, 01:30 PM #26
Real Name: 3 Bears
Real Name: 3 Bears
well I could not get to the wire mentioned in one of the other replies..today if time I will pull the relay..
if I don't I will try to see if it does indeed cycle on in really chilly weather. yesterday it was above 20 and it was kicking on all the time. Today it is already
above 20 and it was cycling when I went to take my grandkids to school
maybe just need to get used to being in a chilly car when it is like minus temps outside
Old 12-10-2019, 05:01 PM #27
Check the picture on the first page of the thread. You'll need a pick or tool to remove the plug, but you don't have to remove the HVAC controls at all.
Old 12-10-2019, 09:37 PM #28
Real Name: 3 Bears
Real Name: 3 Bears
ok...thats a different picture from the picture on the first page. from the picture on first page I was thinking it was more visible...male and female and towards the upper back..i did kind of see a plug with wires going to the lower right corner of the heater controls and maybe a bit difficult to get to.The colors looked different too...but that could have been poor lighting. I was afraid to pull it as it looked like it would be difficult to put back if I was wrong...and like I said...I was looking for something to the upper right and more visible
Old 12-10-2019, 10:22 PM #29
rallypoint_1's Avatar
rallypoint_1 rallypoint_1 is offline
Real Name: Bill
rallypoint_1 is on a distinguished road
Real Name: Bill
For me it was easier to pull AC control panel. Just a few screws. I couldn’t get my fingers in there with it on.
1998 T4R SR5 V6 2wd Evergreen Pearl OME 880 Toytec 1/4" spacer OME 906w/OME20mm(10mmx2)spacers Bilstein 5100 BFG KO2 31's Satoshi mod 1.5" BL(Fat Pats)
My 4Runner build:
http://www.toyota-4runner.org/3rd-ge...8-sr5-2wd.html
rallypoint_1 is offline   Reply With QuoteReply With Quote
Old 12-11-2019, 05:06 AM #30
seen20's Avatar
seen20 seen20 is offline
seen20 is on a distinguished road
seen20's Avatar
Its not always as easy to see as the pictures make it out to be. I remember mine being kinda hard to get to. Also its not necessarily a blue wire. Pretty sure mine actually looked like this. It should be there though if you have a 2000 with the dial controls. White connector on the right side of the controls
dont want ac compressor to kick on-acdef-jpg
2000 Imperial Jade Mica 4runner, 3.4 auto, the workhorse
2000 Horizon Blue Metallic Tacoma, 3.4 ext cab 5-speed, the adventure build -
https://www.tacomaworld.com/threads/...#post-19751873
seen20 is offline   Reply With QuoteReply With Quote
air , compressor , days , defrost , hot
A/C compressor kick on V8? Samm25 4th Gen T4Rs 26 04-14-2018 09:45 AM
a/c compressor "screech" wen compressor engages or cycles? xspsi6 3rd gen T4Rs 9 06-14-2014 04:51 PM
DAC won't kick in! Jan777 4th Gen T4Rs 20 12-27-2013 03:31 PM
Will I kick myself??? Woodsie8 3rd gen T4Rs 19 12-21-2011 06:52 PM
strut compressor vs. spring compressor jmrwd3 3rd gen T4Rs 6 05-19-2008 03:03 AM
