Are talking just the limited flares are the doors , rockers and bumpers too.
As that is what I did on Tetanus 1. I changed all of it. Your front fender flares will just bolt on the door cladding will not. My parts rig was a limited so I swapped the the door. The rocker cladding will have silicone or glued on. The rear fender flares now those are interesting. As I bolted them on and drilled 2 holes for each side. Because I wasn't going to cut those several of those little squares to use the factory mounting.
I will say the large flares keep your vehicles a lot cleaner. I send you 2 side shots of mine as I dont have the rocker covers on yet nor the running boards back on so you can see how mine turned out.
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
