Old 12-07-2019, 01:17 PM #1
fourfive's Avatar
fourfive fourfive is offline
fourfive will become famous soon enough fourfive will become famous soon enough
fourfive's Avatar
How to test a solenoid. Battery voltage question.
I'm wanting to test a transmission solenoid. The fsm says to apply battery voltage. My question is does it matter if I use a 9v battery, 12v car battery or a portable jump starter?
I've used a 9v battery to test a charcoal canister valve in the past because that's what I saw on a youtube video & it seemed to work but thinking about it now could using the incorrect voltage give inaccurate results?
How to test a solenoid. Battery voltage question.-20191207_121211-jpg
•Black 2002 SR5 4x4 3.4L V6
Suspension: Front: Toytec Boss coilovers/eibach 600#, SPC UCA, durobumps Rear: Bilstein/Superflex, SS adjustable panhard, durobumps Body Lift: 2" 4crawler Tires: 315/75/16 General Grabber AT2 Wheels: SCS F5 Matte black 16x8 3.5bs Armor: Custom bolt on rock sliders (no frame drilling)
•Black 2018 TRD Pro (wife’s)
Armor: Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 12-07-2019, 02:09 PM #2
Dieselchessy Dieselchessy is offline
Dieselchessy will become famous soon enough
Per your other thread I believe your testing for an intermittent failure to actuate. I wouldn’t be surprised if it passes your tests, but starving it of voltage, and more importantly current, may give false readings.
9v batteries are low current compared to a car battery, but I have no idea the solenoids current demands. The small wires to it would imply they are low.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 12-07-2019, 02:33 PM #3
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76 is just really nice brillo_76 is just really nice brillo_76 is just really nice brillo_76 is just really nice
MY GARAGE
brillo_76's Avatar
Real Name: Jon
MY GARAGE
Battery voltage would be car battery on fully charged jump box
1997 4X4 V6 5 Speed Sr5 4 Runner (97 5 speed )
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
brillo_76 is online now   Reply With QuoteReply With Quote
Old 12-07-2019, 02:40 PM #4
brillo_76's Avatar
Real Name: Jon
MY GARAGE
brillo_76's Avatar
Real Name: Jon
MY GARAGE
12v to 14v is battery voltage.
Old 12-07-2019, 02:59 PM #5
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar has a spectacular aura about LittleCaesar has a spectacular aura about
You should be able to use your Metabo battery, barring you know what is positive and negative. I have found that to test solenoids, motors that are 12v, it is good to use a source that is at least 12V, or close to it.
I think a whole solenoid kit for the A340s is less than $100.
Keep us posted.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 12-07-2019, 05:33 PM #6
fourfive's Avatar
fourfive's Avatar
Did you mean I can use a car battery or fully charged jump box?
Old 12-07-2019, 05:38 PM #7
fourfive's Avatar
fourfive's Avatar
Keep us posted.
Interesting, I'll take a look at my metabo battery to see if it has the + & - labeled. The price on the solenoid kits makes it tempting but I've usually had bad luck with non oem electrical parts.
Old 12-07-2019, 05:49 PM #8
brillo_76's Avatar
Real Name: Jon
MY GARAGE
brillo_76's Avatar
Real Name: Jon
MY GARAGE
Yes.
Battery voltage is 12v thru 14v. Mostly a fully charged lead acid is 13.8v. That is why I suggested a car battery or fully charged jumped box.
Old 12-07-2019, 06:21 PM #9
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt will become famous soon enough
jbtvt's Avatar
What' the Metabo battery for? A 12v tool? Love their 18v stuff.
You should definitely use 12v though. I've tried several circuits in the past that ended up not working because my 12v relay wasn't getting enough current to activate, and relay/solenoid both work on same principle. Whenever I'm testing I use jumper cables on battery with alligator clips on other end to pins/terminals/etc.
-'85 4Runner, 22re 5spd, built trailer queen
-'90 4Runner, 5spd, 3.4 swap
-'98 GS400 V8 1uz
-'07 GX470 V8 2uz
jbtvt is offline   Reply With QuoteReply With Quote
Old 12-07-2019, 07:41 PM #10
Wedgy's Avatar
Wedgy Wedgy is offline
Wedgy will become famous soon enough Wedgy will become famous soon enough
Wedgy's Avatar
I am still messing with my no start problem and am getting slightly less than battery voltage to the starter relay(pin 1, pin 2 is ground) and it won't activate so you may want to test with battery voltage or get bogus results and more work. The relay is good as I have swapped it back and forth with another and both relays work in that vehicle. Good luck !
Wedgy is offline   Reply With QuoteReply With Quote
Old 12-07-2019, 07:53 PM #11
fourfive's Avatar
fourfive's Avatar
It's actually an 18v so that probably wouldn't work but I do have a few milwaukee m12 batteries. I agree their 18v tools are impressive. Unfortunately I won't be testing the solenoids because I dropped the pan & saw big metal shavings on the magnet.
4runner pic to decorate this thread.
How to test a solenoid. Battery voltage question.-2002-4runner-jpg
Old 12-08-2019, 12:42 AM #12
I saw those shavings. Not good though I would say you may with a new solenoid and clean ATF get another five to ten out of it if needed.
I would be willing to wager that the solenoid, despite its country of origin, would probably work fine.
A voltmeter will take the guesswork of the battery connectors. You could use the M12 battery as well.
Keep us posted and good luck.
Old 12-08-2019, 12:46 AM #13
I would also with the new/ reman tranny recommend installing a Magefine tranny filter if you haven’t done such already.
Old 12-08-2019, 03:24 PM #14
fourfive's Avatar
fourfive's Avatar
I had the older plastic magnefine filter on for a few years. I would put on a new one yearly but thought they were discontinued because I didn't see them for sale anymore. I later realized they just came out with a newer version.
Old 12-08-2019, 05:04 PM #15
They went back with using an aluminum housing, which shouldn’t leak at the connections, which the plastic ones had a tendency to do. A little more $$$ in product development goes a long way.
battery , question , solenoid , test , voltage
Battery/Alternator issue. Voltage is OK greif07 3rd gen T4Rs 98 10-05-2019 04:04 PM
Voltage of Battery with Engine Running JP4RNR 4th Gen T4Rs 13 11-16-2017 12:46 PM
Battery Voltage Help The Jc2203 3rd gen T4Rs 3 06-05-2015 07:09 PM
What is your measured Voltage at the battery with the truck on? kman79 4th Gen T4Rs 8 09-03-2013 11:32 PM
Battery Corrosion Vs Voltage Reglator Lobo 3rd gen T4Rs 6 01-02-2006 01:29 PM
Copyright © 2019
