Originally Posted by nissanh
Shopping List so far:
Toyota 9036340020 BEARING (FOR REAR AXLE SHAFT), RH/LH 1 53.71$
2 107.42$
If you want to try an easier fix you might try and just replace the seals. I had the full bearing job done on my old 4Runner 3 times! The third time it lasted for about 5 years and then started leaking again, I caught it early and just did the seals and it was fine for the next 8 or so months until the 4runner was totaled. I was checking regularly until the accident and the abs sensors were nice and dry, so that might be an easier and cheaper fix, especially since your bearings are rather new.
