Old 03-04-2020, 01:00 PM #1
Gruelin's Avatar
Gruelin Gruelin is offline
Gruelin is on a distinguished road
Gruelin's Avatar
Question 2001 Body Mount Bolts
Hi friends,
Looking at dropping new poly body mount bushings into the truck this weekend, and figure I should just replace the bolts and nuts too. After searching for a while I can't find the answer to this question:
Does anybody know the OEM specs on those bolts (so I can find replacements), or should I just go straight to OEM?
TY
2001 T4R SR5 3.4L straight up stock (for now)
Gruelin is offline   Reply With QuoteReply With Quote
Old 03-04-2020, 04:31 PM #2
rexassian rexassian is offline
rexassian is on a distinguished road
I think you'll find the info on 4crawler's site:
4Crawler Offroad - Custom Body Lift Kits
yes it's body lift specific but there's a lot of info and good pics there.
rexassian is offline   Reply With QuoteReply With Quote
Old 03-04-2020, 09:41 PM #3
Mtn. Runner Mtn. Runner is offline
Mtn. Runner is on a distinguished road
What’s your reasoning for doing poly body mounts?? I considered doing them while I was installing the 1” body lift but decided against it because it makes your ride more stiff and more vibrations. I didn’t want that rough road feeling even though it’s not my DD but if it’s just a rock crawler or off roading truck I would say go for it.
Mtn. Runner is offline   Reply With QuoteReply With Quote
Old 03-05-2020, 01:19 AM #4
Gruelin's Avatar
Gruelin's Avatar
Thanks all for replies so far, and great question @Mtn. Runner .
I need to put rear bushings in to accommodate a 4xI bumper I have on order. So I figured I'd just do them all while I'm spending the time.
In my definitely incomplete reading I can't find anything that clearly says poly bushings at OEM height leads to a meaningful change in the ride.
Not a DD, and not a rock crawler either. With the suspension I plan to put in, I'm hoping any slight increase in stiffness can be offset. Happy to hear if I am wrong, since I haven't put them all in yet!
Old 03-05-2020, 03:11 AM #5
Agreed. I am still considering doing the rear mounts to poly for when I upgrade my rear bumper. Whole poly kit is 215 vs 85 for just rear bushings.. Keep us updated on ride quality. As for the bolt size I can’t quite tell you because I run extended bolts with the 1” body lift. But what I can tell you is that once I installed the bolts I ended up cutting off about two inches that hung down toward the bottom. Reason being two of my stock body mount bolts were bent sideways at the bottom from rocks on the trails, so I took a precautionary measure and trimmed them down
Old 03-05-2020, 04:23 AM #6
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
No real reason to replace them unless rust is an issue. I've never pulled a body mount bolt out of any Toyota of the era that had any abnormal wear on it.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 03-05-2020, 08:10 AM #7
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
I did all poly body mounts last fall. energy suspension kit.
I will be pulling the poly out and going back to OEM. The ride on the poly mounts is noticeable more harsh in cold weather. Once the temp lets down to 20 deg the poly mounts are like riding on a board. As the temp goes up the ride improves, so if you live someplace where it gets cold don’t do it. I think overall in all temps the poly is much harsher. I'm now satisfied that I will no longer be using poly on any mounts in the future. I don't think you can compensate for vibration with suspension, I used to have that assumption as well.
It is true the Toyota mounts will run you a lot more than the poly bushings
the only real advantage to poly IMO is it's potential to last, but the OEM stuff last for 15-20 years.
good source of reading to help you make the decision.
Rubber vs Polyurethane Suspension Bushings | Suspension.com
Why Use Polyurethane Bushings? | Suspension.com
Old 03-05-2020, 09:44 AM #8
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
I have both front and rear 4X4innovations bumpers. After the bumper install, I installed Energy Suspension poly body mounts, the black ones, not the cute red ones. The front bumper was touching fenders after, and the rear bumper was on flex on right quarter on flex (right quarter was tweaked a little from former body work, but not noticeable). Not sure if rear quarter flex touching before new poly mounts, but may have. For front I even backed the the nuts off all the way so no down force other than body weight, still touched or almost touched, but def on flex.
So I ended up giving it a Toytec 1 inch body lift (which comes with new longer bolts). No problem after that. I don't have any problem with the ride quality and I'm in colder climate. Also I actually like the look of a little bumper gap better, and also 1 inch taller is nice.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 03-06-2020, 12:15 AM #9
Gruelin's Avatar
Gruelin's Avatar
Thanks so much all for the great info.
@sleepydad interesting story about the ride. I live in the Denver area so nowhere near as cold as where you are, but still making me consider options here. And it makes sense that the suspension can't make up for vibration and noise. Thx for the additional reading.
@dogtail that sucks about the bumper contact. The body on this one is pristine and I'm not yet planning on replacing the front bumper at all. I'll hope that I don't have to follow up immediately with a body lift to keep it off the bumper.
@UnderFire good to know about the bolts. Will plan to re-use unless something happens on extraction. We are lucky to have an exceptional hardware store here in town, which stocks class 12.9 metric bolts I can use if I need to replace the ones that are in there.
Between now and the weekend I'll be debating with myself whether to replace them all, knowing that I might want to pull them out and put OEM's back in, or just doing the rear. Something to occupy all this dead space in my mind.
This is the first step
Old 03-06-2020, 12:31 AM #10
Thumbs up
I would recommend to do the rears if you plan on putting a rear tube/plate bumper on and going off-roading and getting flexy. If your keeping it mostly stock and not pushing the truck off road just leave the OEM bushings on.
Old 03-09-2020, 11:12 PM #11
Gruelin's Avatar
Gruelin's Avatar
Decided I needed to use my garage time over the weekend to brew some beer, so didn't get to this. But I'll update on ride etc when I do it. How many I replace may depend on the conditions of the OEM ones in there.
body , bolts , find , mount , oem
WTB: 3rd Gen (2000) Stock body mount bolts STI_MECE Want to Buy/Trade 1 08-17-2019 11:15 PM
Wanted: 4th gen stock body mount bolts jay22 Want to Buy/Trade 0 06-27-2019 08:26 PM
WTB: 4th gen body mount bolts 4gin007 For Sale: T4R Items 0 07-08-2018 08:46 PM
FS: Toyota Body Mount Bolts TN $32 TNRunner99 For Sale: T4R Items 7 06-20-2017 12:43 PM
Body mount bolts? Tlowe 5th gen T4Rs 6 12-12-2016 05:47 PM
