Originally Posted by SeaDug
How can I check on this? Does it require ripping off my fender?
Try spraying lots of water on and around your antenna and see if it tracks into the cab on the cable. If it does you would have to at least partially remove your fender to make a proper drip loop. Has your antenna ever been replaced? If not, it is doubtful this is the problem.
