Old 12-12-2019, 08:35 AM #1
Spktyr Spktyr is offline
Spktyr is on a distinguished road
Radiator Replacement Questions
I'm about to tackle a radiator replacement on my 2000 and I've got some questions.
1. Since I am literally removing and replacing the radiator, do I still need to flush the cooling system? It's running Toyota Pink since before I got it, the coolant appears to be nice and clear of contaminants as best I can tell. I will be refilling with Toyota Pink as well as using a genuine Toyota radiator and hoses I picked up from the dealership, if that makes any difference.
2. I also want to replace the thermostat while I have the system drained as I am uncertain as to how long it has been since it was last replaced.
What all of this do I actually need to remove to get access to the thermostat?
3. My firewall-mounted heater control valve has apparently seized so I'll be replacing that at the same time. Any tips on this? I have the automatic climate control, but I do not have the optional under-seat heater core - just the standard in-dash one.
Thanks in advance!
2000 4Runner Limited - 2WD, 3.4L V6, Automatic - Bilstein 4600/Moog 'Tall' Springs, Manik brush bar, PowerStop Tundra Brake Upgrade w/ Stoptech SS Brake Lines, KC Hilites 6" Pro-Sport HID Spread Beam Pair Pack System w/ KC Lexan covers, 4th gen 17" wheels w/ Spidertrax and Rugged Ridge 1.25" spacers, oEdRo LED headlight bulbs, BMW E92 seats, ScanGauge II, Prodigy TBC
Spktyr is offline   Reply With QuoteReply With Quote
Old 12-12-2019, 08:45 AM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
1) I wouldn't but you can if you wish. Your basically flushing it by changing the antifreeze.
2) you just need to remove the 3 bolts in the housing to change the thermostat. Just put the jiggler at 6 oclock.
3) Those do get brittle. So be ginger around it.
Old 12-12-2019, 09:09 AM #3
How do you get access to the three bolts in the housing? It looks like the timing belt cover blocks access on mine.
Or are there access holes for tools in the cover that I'm not seeing? Thanks.
Old 12-12-2019, 09:20 AM #4
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Replace the radiator cap with an OEM one as well. It will be time.
There are three nuts that hold the thermostat housing to the block on studs. Not too hard to get to once the lower hose is removed. Tighten to 14ft pounds. Don’t forget a new thermostat gasket.
Just make sure when changing the valve that its setting is on COLD on the AC controller before changing it out. Also check to see that the cable moves freely.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 12-12-2019, 09:24 AM #5
I indeed bought an OEM cap and thermostat gasket based on some of the prior threads I read here and they are on my list of things to replace.
Just confirming - there's no need to pull the timing cover to get the housing out?
Old 12-12-2019, 09:38 AM #6
nissanh nissanh is offline
I did a radiator replacement on my friend's 03 Tacoma few days back. I opened the drain valve under the radiator and collected all and used it (not the very bottom residue).
Thermostat is located at the bottom inlet (near the alternator) and not at the top outlet. If possible install OEM radiator hoses and reuse OEM clamps (never apply any lubricant when installing the hoses.
Also clean the reservoir cap and make sure nothing is clogged in the cap.
Old 12-12-2019, 09:42 AM #7
bdjcl bdjcl is offline
bdjcl is on a distinguished road
no, you don't need to pull the timing cover. looking at the front of the engine, it's on the lower right.
'98 Corolla LE 193k miles
'98 4Runner Limited 215k miles
bdjcl is offline   Reply With QuoteReply With Quote
Old 12-12-2019, 09:50 AM #8
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Best access to the T-stat housing is form the Bottom side, not the top. Now, while this was a full belt and water-pump job, I'm more just trying to show the location of the T-stat housing:
It's at 5 o'clock, the darker metal pointed down and right in the frame (and has the lower radiator hose on it in this photo). 3 nuts, evenly spaced.
As for the rest, I always take the opportunity to run some coolant system cleaner/flush for a few days before doing a swap, then do one quick flush with distilled water (10 minute drive, just get to temp to open the T-stat). Overkill? Maybe. For the "cost" of about $10 and 10 extra minutes of time it just seems like a no-brainer to me. I go Much more in-depth when I first buy a used vehicle (multiple cleaning flushes, multiple "rinse" flushes over weeks of time) because you have no clue what some PO did, or didn't do. My 4-runner had green coolant, and gooey globs that flushed out.
Brian. is offline   Reply With QuoteReply With Quote
Old 12-12-2019, 09:54 AM #9
Bad Luck Bad Luck is online now
Real Name: Patrick
Real Name: Patrick
Here's a video from mtbtim. It covers a transmission cooler install (not what you asked for), but it also covers radiator and thermostat replacement.
YouTube
Bad Luck is online now   Reply With QuoteReply With Quote
Old 12-12-2019, 10:11 AM #10
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
No need to pull timing belt cover. Follow the lower radiator hose up to the engine. That is where the thermostat is. 3 nuts and the torque amount is in the thread here.
Old 12-12-2019, 10:12 AM #11
Flushing before swapping is unfortunately not a possibility with my truck at the current time. I had already been preparing to preemptively replace the radiator this month but both tanks lost containment in the parking lot last week; the vehicle won't hold pressure and will piss out most of the contents in minutes.
Old 12-12-2019, 01:28 PM #12
I forgot I also replaced both coolant lines going to and from the control valve. It looked like one had been leaking for some time. In 2013 they weren’t too expensive. If you plan to keep the 4Runner for some time it may be a wise investment.
Old 12-12-2019, 10:02 PM #13
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes might as well replace those hoses if you are replacing your control valve. Lots of heat coming off the engine around the control valve. I cant say I had one stick on me. I have heard of them busting on users. Though.
Old 12-14-2019, 12:54 AM #14
noisyboyy noisyboyy is offline
noisyboyy is on a distinguished road
radiator
Before you take everything apart drain radiator add distelled water and radiator flush . Do that twice then you know its as clean as you can get it, then add new parts , just a suggestion.also flush engine with both hoses off engine
noisyboyy is offline   Reply With QuoteReply With Quote
Old 12-14-2019, 02:04 AM #15
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
If you let the coolant dribble out of the petcock at the radiator bottom for about 20-40 extra minutes before undoing the thermostat housing, there'll be less coolant blurping out when you pull the thermostat housing. Once you pull the thermostat housing and the coolant that's in the engine all drains out, there will only be about a quart still left in the engine. Use distilled water if diluting. Just refill with the pink, or the diluted red, and you'll be huge.
pluton is offline   Reply With QuoteReply With Quote
control , heater , radiator , replacement , thermostat
How to radiator replacement Crashnrondo 3rd gen T4Rs 57 07-05-2018 01:14 AM
Radiator replacement - when? 4by4runr 4th Gen T4Rs 21 09-07-2016 11:40 PM
Radiator replacement sonjason 3rd gen T4Rs 11 02-23-2011 01:10 PM
Radiator replacement ryani 3rd gen T4Rs 12 01-10-2010 11:00 PM
Radiator Replacement how-to doggernaut 3rd gen T4Rs 5 04-11-2009 06:45 PM
