Old 12-12-2019, 10:52 AM #1
sdb999 sdb999 is offline
sdb999 is on a distinguished road
Rear Suspension, Lower Control (Trailing Arm) bushings
99' sr5, manual, 280k miles.
The Rear Lower Control (Trailing) Arm has two large serviceable bushings, one on each end. I can't tell without pulling it out whether the bushings are the same part number front and rear. I want to order and replace all of them.
The parts diagram shows a part number for the rear (4870235070), but not the front. Does anyone know if these are actually the same part number?
Thanks, S.
sdb999 is offline   Reply With QuoteReply With Quote
Old 12-12-2019, 11:04 AM #2
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
The parts diagram says "4 Required", so since there are four bushing for the two sides, it would be the same part number.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 12-12-2019, 11:08 AM #3
spartacus's Avatar
spartacus's Avatar
Thanks, S.
front upper qty 4 48632-35080
front lower qty 2 Lh 48061-35040
front lower qty 2 rh 48061-35050
rear lower qty 4. 48702-35070
Old 12-12-2019, 11:13 AM #4
nissanh nissanh is offline
Go to partsouq.com and enter your VIN number, then look at the parts diagram. I bought all 5 OEM control arms for my 2000 LC from them and it is on the way to me(4-5 days to receive). Check their prices and you will see those are about 40-50% less than what we get here in the US. Even with shipping, it still be cheap. Add some parts that you might need in the future. For example: rear OEM axle bearing is $53 and here is it $80.
NEVER install aftermarket bushings.
Old 12-12-2019, 02:30 PM #5
Thanks guys, the Toyota parts diagrams I have used until now don't have quantities listed so I called the dealer they are attached to. Apparently they don't understand theier own data as they insisted that the forward bushing could not be replaced, only the rear. I'm good on the Front, no issues.
Now back to the Rear: The upper short arms, does any one have an OEM bushing part number/source for those?
Thanks again.
Old 12-12-2019, 02:36 PM #6
Real Name: Leon
Real Name: Leon
I don't see those bushings on the parts diagram, you might have to get the whole arm, or go aftermarket.
Old 12-12-2019, 02:55 PM #7
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
Just so you know too, it's 44mm outside diameter of the bushing sleeve and 56mm outside diameter for the tube they slide into on each end of the LCA. :-D I know because I'm working on a video of press my old ones out right now.
weekendclimber is offline   Reply With QuoteReply With Quote
Old 12-12-2019, 02:58 PM #8
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
You can just use aftermarket poly bushings too. Whiteline makes replacement bushings for both upper and lower rear control arms.
From my experience pressing out the OEM bushings out of the rear lower control arms, they did look like the same exact bushing front and rear.
Old 12-12-2019, 08:45 PM #9
I’m set. Although I’m staying oem I appreciate the links to poly bushings.
It looks like the upper control arms and Transverse link (panhard rod) do not contain serviceable bushings. If anyone has oem replacements for those bushings that have alluded me it would be greatly appreciated.
Thanks again, love this place!
Old 12-13-2019, 12:14 PM #10
Real Name: Scott
Real Name: Scott
Uppers are definitely serviceable, as I have done it. I replaced them with StrongFlex bushing from Sonoran Steel though, so not sure if you'll find an OEM replacement part. Also, not sure about the panhard bar, as I've got a SS adjustable back there and I tossed the old one (should have kept it). #notmuchhelp
bushings , front , number , part , rear
Rear lower control arm bushings - where to buy? Luke325i 3rd gen T4Rs 2 07-28-2019 12:23 PM
WTB: 3rd gen upper/lower control arms/rear trailing arms BADCLOWN Want to Buy/Trade 2 05-24-2017 03:11 PM
FS: Energy Suspension 4th Gen 4Runner Lower Control Arm Bushings - NEW. $80 ATL 04RunnerLimited For Sale: Suspension/Wheels/Tires 2 12-13-2016 11:20 PM
95 4x4 upper & lower control arm bushings replacement HELP!!! and rear bushings??? mark808 Classic T4Rs 18 07-08-2013 01:11 AM
Rear Lower Control Arm Bushings Maritimer 3rd gen T4Rs 3 02-11-2012 12:19 PM
