Old 12-13-2019, 05:06 PM #1
levee-11's Avatar
levee-11 levee-11 is offline
Real Name: Levi
levee-11 is on a distinguished road
levee-11's Avatar
Real Name: Levi
Noise when putting it in drive
I would say about 90% of the time I put my 4Runner into drive, and drive about 10-15 feet I hear this noise from under the truck. It kind sounds like a tire rubbing or something like that, but it's not. If i start it and go to reverse it won't do it, but once I go to drive it does it. If I have already driven, then gone into park, and back into drive it will not do it, only when you have just started it. It doesn't sound like gears, it sounds like some sort of creaking or rubbing noise. Anybody know what this is??
levee-11 is offline   Reply With QuoteReply With Quote
Old 12-13-2019, 05:38 PM #2
phattyduck phattyduck is online now
phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold
It could be the ABS pump doing its self-check. It needs the brakes to be released before it can do that.
'16 Honda Odyssey
phattyduck is online now   Reply With QuoteReply With Quote
Old 12-13-2019, 06:00 PM #3
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
ABS pump makes a kind of buzz moan sort of sound a half a second or so after you let off the brake pedal.
Drove my 99 for 15 years and never noticed it. Bought a 98 and was like what's that odd sound?
99 has lots more insulation in the engine bay than the 98.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 12-13-2019, 06:09 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light
brillo_76's Avatar
Real Name: Jon
I never heard the abs module in any of my 97 and 98. Hmm.. now I be listening for it.
1997 4X4 V6 5 Speed Sr5 4 Runner (97 5 speed )
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
Old 12-13-2019, 06:46 PM #5
JMat's Avatar
JMat JMat is offline
JMat is on a distinguished road
JMat's Avatar
What about if it's facing downhill on a driveway or something and you put it in to neutral and let it roll? The reason I ask is I had a chatter that happened unde the same circumstances and it turned out to be leaking rear axle seals. The brake shoes would grab and chatter but only on initial start up and not in reverse. Eventually all that oil causes the material on the shoes to swell and they don't want to let go.
1998 Toyota 4Runner 3.4 4x4 with 340,000 miles.
199mm TBU-Bilstein 4600-'99 Tall Springs(Rear).Almost Totally Stock
1997 Toyota 4Runner 3.4 4x4 with 247k miles-Project car
JMat is offline   Reply With QuoteReply With Quote
Old 12-13-2019, 07:27 PM #6
levee-11's Avatar
Real Name: Levi
levee-11's Avatar
Real Name: Levi
That doesnít make the noise. Only in drive.
- The 4Runner Newbie
1998 Desert Dune SR5 3.4L 4x4 A/T
Old 12-13-2019, 07:34 PM #7
I suspect you could pull the ABS relay under the hood and see if the noise stops.
drive , noise , rubbing , sounds , started
Difficult putting in drive: 2001 3.4 automatic. poser 3rd gen T4Rs 3 04-17-2017 11:28 AM
Drive shaft noise or U joint noise (LEXUS 4/06 TSB page 18) aka Driveshaft thump/bump rorad Problems & Warranty Issues 764 08-16-2016 08:49 AM
Popping noise after starting and putting in reverse Y2KSR5 5th gen T4Rs 4 05-08-2014 02:42 PM
Slight hesitation when putting into drive? rotorhead6 5th gen T4Rs 19 03-27-2013 07:40 PM
Putting the car in Drive, while still backing up hellrider 5th gen T4Rs 7 10-18-2011 05:15 PM
