Old 12-15-2019, 11:11 PM #1
thattomguy thattomguy is offline
thattomguy is on a distinguished road
Auto window up/down
My '97 has the drivers window auto up/down. It doesn't work. I have to hold the switch. Any suggestions on how to make it work?
thattomguy is offline   Reply With QuoteReply With Quote
Old 12-16-2019, 10:53 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
It's likely the switch. From a 2000 EWD description:
8. AUTO DOWN OPERATION (DRIVER’S WINDOW)
With the ignition SW on and with the auto SW of the power window master SW in DOWN position, current flowing to
TERMINAL (A) 10 of the power window master SW to TERMINAL (A) 2 to TERMINAL 2 of the power window motor front LH
to TERMINAL 1 to TERMINAL (A)1 of the power window master SW to TERMINAL (A) 4 to GROUND, causing the motor to
rotate towards the down side. Then the solenoid in the power window master SW is activated and it locks the auto SW being
pushed, causing the motor to continue to rotate in auto down operation. When the window has completely descended, the
current flow between TERMINAL (A) 1 of the power window master SW and TERMINAL (A) 4 increases. As a result, the
solenoid stops operating, the auto SW turns off and flow from TERMINAL (A) 10 of the power window master SW to
TERMINAL (A)
2 is cut off, stopping the motor so that auto stop occurs.
10. AUTO UP OPERATION (DRIVER’S WINDOW)
With the ignition SW on and with the auto SW of the power window master SW in UP position, current flowing to TERMINAL
(A) 10 of the power window master SW to TERMINAL (A) 1 to TERMINAL 1 of the power window motor front LH to
TERMINAL 2 to TERMINAL (A) 2 of the power window master SW to TERMINAL (A) 4 to GROUND, causing the motor to
rotate towards the up side. Then the solenoid in the power window master SW is activated and it locks the auto SW being
pulled, causing the motor to continue to rotate in auto up operation. When the window has completely descended, the
current flow between TERMINAL (A) 2 of the power window master SW and TERMINAL (A) 4 increases. As a result, the
TERMINAL (A)
1 is cut off, stopping the motor so that auto stop occurs
Old 12-16-2019, 12:35 PM #3
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
Hey I've had this happen with a number of my cars that have had higher mileage or were subjected to more dirt/dust and I've on occasion had success in cleaning the contacts but it's hit and miss.
On my 97 I gave up on cleaning it (plus it was 340k miles old at the time) and just bought a new switch unit: for the price it was the best way to go and least time requirements:
Toyota Front Driver Side Master Power Window Switch - 1AWES00085
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 12-16-2019, 01:04 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Mostly if the switches test out good. It could be a broken wire that breaks in the door jam. Those wires flex every time the door is opened and closed. The drivers door and the hatch tailgate are mostly the first areas to break. However, all doors will in time.
Old 12-16-2019, 01:16 PM #5
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
If I read correct, that the switch will work if you hold it down. If that is true then you have power to the switch and is most likely the switch.
Do other windows operate. does the auto up down work on pass side ?
Old 12-16-2019, 03:39 PM #6
All of the windows work. It's just the auto up down that doesn't. I don't think the passenger side has the auto up down. Sounds like the switch is bad.
Thanks for the replies.
Old 01-14-2021, 03:02 PM #7
Real Name: 3 Bears
Real Name: 3 Bears
I got the dancing window now.
so my new to me 2001 started this game yesterday,using auto up, go to put window up, goes up, then back down, then up, then down then stops down. If the window is in the half way down postion, it will go up and stay up using the auto up.
is it the switch ?
Old 01-14-2021, 04:56 PM #8
5VZ-FE's Avatar
5VZ-FE 5VZ-FE is offline
5VZ-FE will become famous soon enough 5VZ-FE will become famous soon enough
5VZ-FE's Avatar
is it the switch ?
I was having the same issue, but it would go auto up, then back down to halfway. The issue was because I switched from manual windows to electric, and when I put the new regulators in I didn’t know about setting the safety feature for auto up. My cousin has had the same issue in a few Lexus’s (Lexi?). This was recommended to me a while back, but I haven’t done it.
https://www.toyota-4runner.org/attac...rol-system-pdf
Hope it helps, I know how annoying window issues can be.
‘98 T100 SR5 4X4 5spd (sold)
‘99 4Runner SR5 4x4 5spd E-Locker Unicorn
5VZ-FE is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 06:46 PM #9
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Here is the rest of the trouble shooting from the FSM.
http://www.teamtoyota4x4.org/archivi...pwcsy/trou.pdf
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 07:06 PM #10
Real Name: 3 Bears
Real Name: 3 Bears
sucks...if im reading this right I have a lot of work to do, like pull the window motor. think I will wait till spring and use it as little as possible till then. no garage, and in chilly alaska
auto , drivers , up/down , window , work
All window auto down hockeyman 3rd gen T4Rs 0 09-08-2014 11:01 AM
window is not rolling down on auto leeak47 Maintenance/Detailing 3 10-29-2011 06:54 PM
Auto window search gledhill 4th Gen T4Rs 3 06-15-2009 01:40 AM
Auto Down Window Dahlonega 3rd gen T4Rs 9 05-27-2008 09:09 PM
