Old 12-16-2019, 11:15 AM #1
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
How to remove Park Neutral Position Switch? *Pic*
I dropped my transmission over the weekend & having difficulty removing the park neutral position switch from my old transmission. How much force is needed to pull the switch off? In the first pic I circled my switch in yellow & you can see there isn't a nut or locking plate holding it in place but still unable to remove it (I did unbolt it). For whatever reason, mine did not have the nut and lock plate which I circled in red in the 2nd pic.
How to remove Park Neutral Position Switch? *Pic*-park-neutral-switch-2-jpg  How to remove Park Neutral Position Switch? *Pic*-park-neutral-switch-nut-washer-jpg
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 12-16-2019, 12:00 PM #3
fourfive's Avatar
fourfive's Avatar
I've seen those search results you posted. For removal they basically say to remove the bolt, nut & locking plate and it can be pulled off. I've done all that, the problem is I'm having difficulty trying to pull it off the transmission which is why I asked how much force is needed to slide it off or if there's something else that needs to be done to remove the switch.
Old 12-17-2019, 11:14 PM #4
bootown's Avatar
bootown bootown is offline
bootown is on a distinguished road
bootown's Avatar
if it's anything like my sequoia...a lot. you just really need to crank on it. wedge a big screwdriver or pry bar between the switch and transmission housing and pry from different directions. it will eventually slide off but you may have to use a decent amount of muscle. i thought i was going to snap my big flathead screwdriver in half (probably came super close) when doing this but eventually is starting moving a tiny bit at a time.
bootown is offline   Reply With QuoteReply With Quote
Old 12-18-2019, 08:35 AM #5
fourfive's Avatar
fourfive's Avatar
Thank you. That's exactly what I needed to know. I did feel like I was using a decent amount of force just pulling on it with my hands when I initially dropped my transmission but will go at it with pry bars this weekend.
Old 12-18-2019, 10:23 AM #6
Yo_Hec Yo_Hec is offline
Yo_Hec is on a distinguished road
That looks like the switch on my 2012. My rear camera is acting up and im wondering if this has somethign to do with it?
Yo_Hec is offline   Reply With QuoteReply With Quote
Old 01-13-2020, 05:25 PM #7
fourfive's Avatar
fourfive's Avatar
I was able to remove my park neutral switch using a small pry bar. Had to pry along the edges of the switch & gradually lever it off. I bought a new one in case I broke the original during removal. I now have the old one as back up.
circled , nut , pic , plate , switch
p1780 cel park neutral switch error with erratic dash indicator lights Mountain Fun 3rd gen T4Rs 3 11-14-2023 02:50 PM
Park / Neutral Safety Switch Circuit to Control an Accessory? blockhead 3rd gen T4Rs 1 04-01-2018 10:58 PM
High idle only in park and neutral mphillips_90 3rd gen T4Rs 14 02-09-2018 04:28 PM
Vibrations/Wobble in park and neutral skibummin101 4th Gen T4Rs 3 02-20-2015 11:09 AM
No load idle fluctuations in park and neutral HELP thedan12845 General Discussions 9 07-30-2014 10:40 PM
