Old 12-16-2019, 12:42 PM #1
ASUMTNEER ASUMTNEER is offline
ASUMTNEER has a spectacular aura about ASUMTNEER has a spectacular aura about
Power antenna aftermarket radio wiring?
I've searched, but didn't find what I needed. I'm wiring up an aftermarket head unit on my dad's 99 4runner. The metra harness has a blue wire for the power antenna, but the radio harness doesn't have a corresponding blue wire to connect it to. Can I run it with the red power wires so it will go up when the car turns on?
ASUMTNEER is offline   Reply With QuoteReply With Quote
Old 12-16-2019, 03:10 PM #2
Dephcon's Avatar
Dephcon Dephcon is offline
Dephcon is on a distinguished road
Dephcon's Avatar
This isn't going to help you much, but the head unit you are swapping in should have a wire to trigger the power antenna. I would check the web for more information in that direction. Now, i can say I ditched the power antenna many moons ago and changed over to the Taco whip, less headache and not expensive.
1996 4Runner Limited - Evergreen Pearl
Front: Bilstein 5100\Toytec Eibach coilover kit
Rear: Bilstein 5100\ 8 wrap LC
Dephcon is offline   Reply With QuoteReply With Quote
Old 12-16-2019, 04:29 PM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I look at the electrical wiring diagrams for the power antenna. That tigger wire has to be there somewhere. Will be later tonight before I can look for it.
Old 12-16-2019, 05:00 PM #4
What radio is it?
Most aftermarket radios have both an "antenna" wire (on with radio only) and an "amp" wire (on when stereo is on, off when stereo is off).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 12-16-2019, 05:06 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I know my aftermarket radio worked with the power antenna. So now I wondering if harness just dosent have the wire marked on the kit he has.
Old 12-16-2019, 05:20 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
This is what was in my 1998 4 runner Tetanus 1. The wiring kit had the blue wire and the pioneer head unit wire was blue white. I included photos so you could see what pin on the larger connector corresponds to.
As you have to pull the wires off the factory amp and plug into them. If I am remembering correctly.
Old 12-16-2019, 10:05 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
OP did you find what your looking for or do you need the electrical wiring diagrams from the radio and power antenna?
Old 12-17-2019, 09:06 AM #8
I went ahead and wired the blue antenna wire from the metra harness into the red wires so the antenna goes up as soon as the car is turned on and down when it is shut off. Hopefully this is a good way to do it.
Old 12-17-2019, 09:14 AM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Should be fine. Glad you got it wired up.
Old 12-18-2019, 02:39 PM #10
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Only bad if you off-road on trails with low branches that eat antennas.
My Backyard Frame Swap
Old 12-18-2019, 03:20 PM #11
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Is a good way it works. I purchased the Y cable and adapter to plug in the convenience antenna and electric antenna
into head unit added a switch for electric ant. The only time I need to raise electric ant is when I'm out in the country, limbs tend to get in way.
antenna , blue , harness , power , wire
FREE!! Wiring harness for aftermarket radio with aftermarket amp fblainen11 3rd gen T4Rs 4 01-30-2019 05:16 PM
Aftermarket radio and power antenna problems ultimatt 3rd gen T4Rs 7 11-29-2015 11:04 PM
Aftermarket HU + Power Antenna Insilin Engines / Suspension / Wheels / Tires / Audio / Accessories 2 11-02-2011 04:02 PM
Power Antenna Wiring Help blarchitect 3rd gen T4Rs 4 12-24-2006 01:52 PM
Aftermarket Radio Wiring truckhigh Engines / Suspension / Wheels / Tires / Audio / Accessories 3 09-05-2004 01:58 PM
